Language constraints? [message #991] |
Tue, 03 April 2007 05:49  |
Hi, I'm not familiar with DLTK yet. As I understand DLTK is positioned as
LTK for _dynamic_ languages.
So the questions are:
1. What are the main obstacles to implement IDE for strongly typed languages
like Java or C/C++ with help of DLTK?
2. What kind of requirements must language comply with to implement IDE for
it with help of DLTK?
Sergey Gomanyuk
Re: Language constraints? [message #2426 is a reply to message #2367] |
Mon, 07 May 2007 05:14   |
Hi Teddy,
I suppose any language could use DLTK.
But some of DLTK core elements such as Model Outline, Search, etc. are
designed for structured languages such as Python, Ruby, Java, etc.
So if it possible to map languages elements to selected structure, then
DLTK will fit good. But if not, it also could be used for project
management, etc.
Thanks, Andrei.
Teddy Walker wrote:
> In several slides you say, that Lisp, Prolog and Scheme don't fit.
> What's the criteria here?
> Perhaps, so it will become clear for us, which languages fits good.
> Teddy
Re: Language constraints? [message #6365 is a reply to message #2426] |
Thu, 07 June 2007 11:43  |
as I understand if my language model can be mapped to DLTK core language
model then all is good and DLTK Core is the best solution to integrate my
language into Eclipse.
Well, lets consider two another situations:
first: language model is very similar to DLTK Core model but contains
additional aspects, so is the a way to extend and reuse existing model and
customize feature implementations provided by DLTK Core?
second: language model is completely different from DLTK Core model. Can I
replace DLTK Core model and reuse features which implementation is dependent
from DLTK Core model?
Another question:
could you enumerate (in general) and divide DLTK Core features (presented
now) by language model dependent and independent?
"Andrei Sobolev" <andrei.sobolev@xored.com> wrote in message
news:f1mqjm$taq$1@build.eclipse.org...
> Hi Teddy,
> management, etc.
> Thanks, Andrei.
> > Teddy
FUDForum. Page generated in 0.04344 seconds
