Home » Eclipse Projects » Dynamic Languages Toolkit (DLTK) » Language constraints?
Language constraints? [message #991] Tue, 03 April 2007 05:49 Go to next message
Hi, I'm not familiar with DLTK yet. As I understand DLTK is positioned as
LTK for _dynamic_ languages.
So the questions are:
1. What are the main obstacles to implement IDE for strongly typed languages
like Java or C/C++ with help of DLTK?
2. What kind of requirements must language comply with to implement IDE for
it with help of DLTK?
Sergey Gomanyuk
Re: Language constraints? [message #1023 is a reply to message #991] Tue, 03 April 2007 06:27 Go to previous messageGo to next message
Hello Sergey,
In fact there are no obstacles to use DLTK for strongly typed languages.
I believe some performance-oriented folks may found that internal
structures, facilities and architecture might be optimized if we would
be oriented on strongly typed languages only, but I think such
performance gains as well as differences would be quite minimal.
According to the above I'd like to expand DLTK acronym as Draft LTK, or
something like that :) ... Definitely one of DLTK main goals is to
propose some facilities to the LTK layer in the future.
As for your questions
1) There are no obstacles to use DLTK for Java or C++ IDEs
2) Hmm... your question triggered hot discussion here :) Short answer
is: we think that any kind of language could benefit from the DLTK
including declarative and functional languages, however some DLTK Core
Framework facilities will be useless for some languages...
Kind Regards,
Andrey Platov
> Sergey Gomanyuk
Re: Language constraints? [message #2367 is a reply to message #1023] Thu, 03 May 2007 12:08 Go to previous messageGo to next message
In several slides you say, that Lisp, Prolog and Scheme don't fit. What's
the criteria here?
Perhaps, so it will become clear for us, which languages fits good.
Teddy
Re: Language constraints? [message #2426 is a reply to message #2367] Mon, 07 May 2007 05:14 Go to previous messageGo to next message
Hi Teddy,
I suppose any language could use DLTK.
But some of DLTK core elements such as Model Outline, Search, etc. are
designed for structured languages such as Python, Ruby, Java, etc.
So if it possible to map languages elements to selected structure, then
DLTK will fit good. But if not, it also could be used for project
management, etc.
Thanks, Andrei.
> What's the criteria here?
> Teddy
Re: Language constraints? [message #6365 is a reply to message #2426] Thu, 07 June 2007 11:43 Go to previous message
as I understand if my language model can be mapped to DLTK core language
model then all is good and DLTK Core is the best solution to integrate my
language into Eclipse.
Well, lets consider two another situations:
first: language model is very similar to DLTK Core model but contains
additional aspects, so is the a way to extend and reuse existing model and
customize feature implementations provided by DLTK Core?
second: language model is completely different from DLTK Core model. Can I
replace DLTK Core model and reuse features which implementation is dependent
from DLTK Core model?
Another question:
could you enumerate (in general) and divide DLTK Core features (presented
now) by language model dependent and independent?
"Andrei Sobolev" <andrei.sobolev@xored.com> wrote in message
news:f1mqjm$taq$1@build.eclipse.org...
> Hi Teddy,
> management, etc.
> Thanks, Andrei.
> > Teddy
Previous Topic:DLTK Webinar
Next Topic:Python exemplary IDE
Current Time: Mon Jul 21 21:39:13 EDT 2025
Powered by FUDForum. Page generated in 0.36071 seconds
