Home » Language IDEs » ServerTools (WTP) » ClassNotFoundException with JAR already in WEB-INF/lib !!! WTP 0.7
ClassNotFoundException with JAR already in WEB-INF/lib !!! WTP 0.7 [message #130642] Sun, 07 August 2005 22:57 Go to next message
Originally posted by: cgaviao.pop.com.br
Hi people, I pass this weekend trying to resolve this problems but i
couldn´t...
I´m using WTP 0.7 with Tomcat 5.5.9 and I´m using Derby as DB.
I put derbyclient.jar(the driver jar) in WEB-INF/lib and it was
recognized by WTP (it appears in Web App Libraries and it was copied to
..deployables\xxxx\WEB-INF\lib).
I even have tried to put it as a dependency at .wtpmodules file:
<dependent-module deploy-path="/"
handle="module:/classpath/var/MAVEN_REPO/derby/jars/derbyclient.jar " />
My context.xml file has:
<Resource name="jdbc/impsisso" type="javax.sql.DataSource"
driverClassName="org.apache.derby.jdbc.ClientDriver"
url="jdbc:derby:net://localhost:1527/xxxx" username="ttt" password="x"
maxActive="50" maxWait="-1" maxIdle="10" removeAbandoned="true"
logAbandoned="true" />
Every time that I try to connect to datasource it throws this exception:
org.apache.tomcat.dbcp.dbcp.SQLNestedException: Cannot load JDBC driver
class 'org.apache.derby.jdbc.ClientDriver'
org.apache.tomcat.dbcp.dbcp.BasicDataSource.createDataSource (BasicDataSource.java:766)
org.apache.tomcat.dbcp.dbcp.BasicDataSource.getConnection(Ba sicDataSource.java:540)
Caused by: java.lang.ClassNotFoundException:
at java.net.URLClassLoader$1.run(URLClassLoader.java:200)
I´m missing something??
best regards for all...
Cristiano
Re: ClassNotFoundException with JAR already in WEB-INF/lib !!! WTP 0.7 [message #131852 is a reply to message #130642] Wed, 10 August 2005 19:41 Go to previous message
Originally posted by: nospam.ronald_vankuijk_net.remove
> couldn´t...
> at
> at
> Cristiano
I had the same thing if the url is not configured right (e.g. to an
unexisiting host, schema etc.). Then you get this strange error. Maybe
it is the same with you
Previous Topic:How to install WTP applications ?
Next Topic:EclipseXSLT 1.0.3 released
Current Time: Sun Jul 27 01:37:59 EDT 2025
Powered by FUDForum. Page generated in 0.03707 seconds
