Home » Eclipse Projects » Remote Application Platform (RAP) » Questions on session invalidate process
Questions on session invalidate process [message #130612] Tue, 28 April 2009 10:43 Go to next message
Hi all,
When session is unvalidated (thanks to time out or
RWT.getSessionStore().getHttpSession().setMaxInactiveInterva l(1)) the
Workbench is closed thanks to a SessionStoreListener.
But the process is not exactly the same as when it is closed thanks to the
workbench red cross button. I've observed 2 differences.
- First of all the ServiceContext is not disposed so that it still
contains the stateInfo.
- Then the stateInfo have in its attributes the WorkbenchThemeManager
whose the manager still has, in its listenerList, references to
ThemeManagerAdapter.
These references are still available because in case of invalidation there
is no phase and listeners are not detached (see TypeEvent.processEvent()).
Are these behavior wanted ? Can they be changed ?
The main problem behind is that sometimes the ThemeManagerAdpater have
reference to the EditorStack and so to the WorkbenchWindow and so to the
Workbench and its Advisors...
And in my application I use BIRT which uses EMF XMLTypeUtil classes which
can hold static reference on the same Thread as the one holding the not
disposed ServiceContext... a huge memory leak happened, nothing of my
application is garbage collected !
Do you have suggestion in order to avoid it ?
Loïc
Re: Questions on session invalidate process [message #130783 is a reply to message #130612] Wed, 29 April 2009 08:31 Go to previous messageGo to next message
I try to find a workaround by adding the following code in my
WorkbenchAdvisor.preShutdown() method :
if (ContextProvider.getContext() != null && CurrentPhase.get() ==
null)
ContextProvider.getStateInfo().setAttribute(
CurrentPhase.class.getName() + "#value",
PhaseId.PROCESS_ACTION);
Not very nice and not efficient.
Well, the WorkbenchThemeManager releases its references to
ThemeManagerAdapter but what I didn't realize is that the
ServiceContext.stateInfo has directly in its attribute the Workbench.
So as long as the ServiceContext is not disposed all the application
classes are not released because of the XMLTypeUtil link to the Thread.
I try to call ContextProvider.disposeContext() during
WorkbenchAdvisor.preShutdown() but then I get "No context available
outside of the request service lifecycle" error during
serviceLocator.dispose() and workbenchActivitySupport.dispose()...
The best way to solve my problem is to call
ContextProvider.disposeContext() at the end of UIThread.processShutdown()
but it's a RAP class and I don't know if it may involve regression.
Does anybody have an idea how I can solve this problem ?
Loïc
Loïc Bertholet wrote:
> Hi all,
> Loïc
Re: Questions on session invalidate process [message #130949 is a reply to message #130612] Sun, 03 May 2009 13:24 Go to previous messageGo to next message
Loïc,
please see my comments below.
Rüdiger
> Hi all,
> the workbench red cross button. I've observed 2 differences.
Not sure if I understand the case correctly. As only the terminated
UI thread holds a reference to the state info, it should be garbage
collected. If you disagree of I am missing something, feel free to
file a bugzilla.
> there is no phase and listeners are not detached (see
I would regard this a bug. The session shutdown should probably
behave like the PROCESS_ACTION phase. Feel free to file a bugzilla.
> which can hold static reference on the same Thread as the one holding
> the not disposed ServiceContext... a huge memory leak happened, nothing
> of my application is garbage collected !
> Loïc
Re: Questions on session invalidate process [message #131622 is a reply to message #130949] Wed, 06 May 2009 12:12 Go to previous messageGo to next message
Rüdiger,
Thanks for your answers.
You are right, as only the terminated UI thread holds a reference to the
state info, it should be garbage collected.
But as I said, my application uses BIRT which uses EMF XMLTypeUtil class
which sometimes holds a static reference on this terminated UI thread. So
it is not garbage collected and as the ServiceContext is not disposed
nothing of my application is garbage collected (state info hold a
reference to the Workbench).
I was wondering if there was a reason not calling
ContextProvider.disposeContext() at the end of UIThread.processShutdown(),
just like it is done at the end of RWTDelegate.doPost().
It is the only workaround I found but I don't know if it may involve
regression.
Concerning the second point, you've just fixed it thanks to the last
commit resolving the Bug #262220 (Invalid Thread Access).
Loïc
Rüdiger Herrmann wrote:
> Loïc,
> Cheers,
> Rüdiger
>> Hi all,
> file a bugzilla.
>> Thanks,
>> Loïc
Re: Questions on session invalidate process [message #131697 is a reply to message #131622] Thu, 07 May 2009 05:45 Go to previous messageGo to next message
> Rüdiger,
> So it is not garbage collected and as the ServiceContext is not disposed
> UIThread.processShutdown(), just like it is done at the end of
> regression.
I see that in your case this might cause a memory leak. Please open
a bugzilla in order to consider how to fix this.
> Loïc
>> Loïc,
>> Cheers,
>> Rüdiger
>>> Hi all,
>>> to the workbench red cross button. I've observed 2 differences.
>> Not sure if I understand the case correctly. As only the terminated UI
>> file a bugzilla.
>> I would regard this a bug. The session shutdown should probably behave
>>> have reference to the EditorStack and so to the WorkbenchWindow and
>>> so to the Workbench and its Advisors...
>>> nothing of my application is garbage collected !
>>> Thanks,
>>> Loïc
Re: Questions on session invalidate process [message #131753 is a reply to message #131697] Thu, 07 May 2009 12:29 Go to previous message
Done : https://bugs.eclipse.org/bugs/show_bug.cgi?id=275332
>> Rüdiger,
>> regression.
Previous Topic:Icons in TreeViewer
Next Topic:JFace OpenStrategy
Current Time: Sun Jul 27 06:53:51 EDT 2025
Powered by FUDForum. Page generated in 0.26636 seconds
