Is there a place for another modeling plugin? [message #130566] |
Mon, 28 May 2007 03:34  |
Originally posted by: danijel.zecevic.siol.net
I made a plugin for modeling-like editors that simlyfies a code generation.
It is small, robust, fast, easy to extend and supports nested editors (two
way coding), outlines, grid and rullers, zoom, tree diagram representation
with easy tree cell definition... It is not based on EMF. It supports
generating of java and XML (as separate plugins which also include nested
editors that display code and model), for now, but can be easely extended to
support other languages. Process of extending a plugin is following: define
a model and interactions between model parts, define visuals and palette,
define how to persist model(generate code), in future this will be defined
in XML. If you see a nead for plugin like this, please reply.
Thanks, danijel
FUDForum. Page generated in 0.51820 seconds
