Home » Archived » Riena » What about Linux?
What about Linux? [message #11933] Fri, 19 September 2008 08:26 Go to next message
I have searched for this, but have come up (surprisingly) empty handed.
Is there a reason that the Riena project does not support Linux? Is
this expected to change in the near future?
Joel
Joel Rosi-Schwartz
Etish Limited [http://www.etish.org]
/ o,o \ The proud parents of Useme & ORMF
|) ::: (| Open Requirements Management Framework
====w=w==== [http://www.eclipse.org/ormf/]
Re: What about Linux? [message #12024 is a reply to message #11933] Sun, 21 September 2008 14:10 Go to previous messageGo to next message
Joel Rosi-Schwartz schrieb:
> Is there a reason that the Riena project does not support Linux? Is this
> Joel
We havnt tried Linux yet. However there are currently no platform dependant bundles in Riena. There used to be one
platform dependant bundle in M3 but in M4 this problem went away due to some enhancements in 3.4 of Eclipse.
So yes we like to support Linux and if you find issues why it doesnt work there, file them as bugreports. If you have
solutions, add a patch (even better).
Currently no one asked for Linux support so thats why we rather fullfilled the requirements of the existing userbase.
regards
christian campo
Re: What about Linux? [message #14170 is a reply to message #11933] Mon, 13 October 2008 18:41 Go to previous messageGo to next message
Joel Rosi-Schwartz wrote:
> Joel
I'm working with Riena on Linux and it works fine. I only modified an
installation procedure a bit (I use Eclipse 3.4.1): I did not change a
target platform (as it is suggested on wiki), but instead I put unzipped
riena M4 features and plugins into eclipse/dropins/riena folder. After
that I removed from that directory all features/plugins which exist in
other dropins folders.
Robert
Re: What about Linux? [message #14253 is a reply to message #14170] Wed, 15 October 2008 03:16 Go to previous messageGo to next message
Hi Robert,
cool to hear that you are using Riena on Linux. I would be interested to hear what parts of Riena you are using (only
communication, ridgets, navigation, everything) and for what kind of application. And how you are doing ? Any problems,
suggestions ?
Feedback is always welcomed
christian campo
>> Thanks,
>> Joel
> Robert
Re: What about Linux? [message #14270 is a reply to message #14253] Wed, 15 October 2008 08:21 Go to previous message
Hi, Christian
I'm working on a system for automatic generation of model-based
applications (for a purpose of other projects).
So, basically, there is a standard tree-based model (EMF) with some
specific annotations. This model is used for generating a server part
(EJBs), WSDL interfaces (for external clients) and UI (currently RCP
application). As you can see Riena fits well into some parts (UI,
client-server communication in a "SOA" manner) and that's why I decided
to take a look at it.
Currently (for a week or so) I've been implementing a generator for UI
parts (using ridgets, navigation) and the next step is using Riena
communication API to get/put objects from/to server side. So, in other
words, I'm interesting in all aspects of Riena :-).
Robert
Christian Campo wrote:
> Hi Robert,
> hear what parts of Riena you are using (only communication, ridgets,
> are doing ? Any problems, suggestions ?
> christian campo
>>> Hi,
>>> Thanks,
>>> Joel
>> Robert
Re: What about Linux? [message #575040 is a reply to message #11933] Sun, 21 September 2008 14:10 Go to previous message
> Joel
regards
christian campo
Re: What about Linux? [message #576070 is a reply to message #11933] Mon, 13 October 2008 18:41 Go to previous message
> Joel
Robert
Re: What about Linux? [message #576205 is a reply to message #14170] Wed, 15 October 2008 03:16 Go to previous message
Hi Robert,
suggestions ?
christian campo
>> Thanks,
>> Joel
> Robert
Re: What about Linux? [message #576218 is a reply to message #14253] Wed, 15 October 2008 08:21 Go to previous message
Hi, Christian
Robert
> Hi Robert,
> christian campo
>>> Hi,
>>> Thanks,
>>> Joel
>> Robert
Previous Topic:Why are we all creating our own OSGi server with remoting capability?
Next Topic:ITableRidget - nested properties
Current Time: Sat Jul 26 16:03:15 EDT 2025
Powered by FUDForum. Page generated in 0.04504 seconds
