Home » Modeling » GMF (Graphical Modeling Framework) » How can I render a figure like Rational Rose style?
How can I render a figure like Rational Rose style? [message #130419] Sat, 26 May 2007 13:36 Go to next message
Originally posted by: zhanglei07.sei.pku.edu.cn
Re: How can I render a figure like Rational Rose style? [message #130445 is a reply to message #130419] Sat, 26 May 2007 15:06 Go to previous messageGo to next message
What is more,
If I just want to set a GIF picture as a figure element.
How can I do this?
In the GMFGraph, create a new "Custom Figure" under my palette.
It seems that I should write an budle to do this....
and I don't know HOW:(
Any suggestion?
Thank you very much:)
zhanglei
"zhang lei" <zhanglei07@sei.pku.edu.cn> wrote in message
news:f39r7r$b41$1@build.eclipse.org...
> Today, I trail IBM Rational Rose which is built with GMF technology.
> The amazing appearance is quite fascinated. I captured a picture and
> attached here.
> As far as I know, by set "Forground RGB color", we can change the color of
> the figure.
> If I want to achieve the effect like Rational Rose, how can I make it?
> I hope it will not be so complicated:)
> Any suggetstion?
> Thanks is advance.
> Best wishes to every GMF programmer~ ~
> zhanglei
Re: How can I render a figure like Rational Rose style? [message #130471 is a reply to message #130445] Sun, 27 May 2007 02:40 Go to previous messageGo to next message
Originally posted by: khai.n.situvista.com
I don't know specifically about how Rational implement its figure but if
you can already create your own figure then getting GMF to use it is
pretty simple.
In .gmfgraph create a new Figure Gallery.
In the gallery's properties set:
Implementation Bundle = [the name of the plug-in where your custom
figures are]
Name = just any name you want
Then from your new custom gallery create a new custom figure.
In the figure's properties set:
Bundle Name = just use the same as Implementation Bundle from above
Qualified Class Name = full path to your existing custom figure such as:
xxx.yyy.xxx.MyCustomFigure
And then just use this figure like any other figure in .gmfgraph
The Rational examples you attached seem like they are simply custom
figures drawn using a gradient. If you need help in using draw2d to
draw your custom figure or to put an image as a background of your
figure then look in the GEF newsgroup; there are plenty of topics about
that there.
BTW: I'm talking about GMF 1.0.1 which may be different than the later
versions.
-- Khai --
zhang lei wrote:
> What is more,
> How can I do this?
> Any suggestion?
> zhanglei
>> attached here.
>> color of
>> the figure.
>> Any suggetstion?
>> Thanks is advance.
>> zhanglei
Re: How can I render a figure like Rational Rose style? [message #130487 is a reply to message #130471] Sun, 27 May 2007 04:49 Go to previous messageGo to next message
------=_NextPart_000_0027_01C7A07E.F76A22C0
Content-Type: text/plain;
format=flowed;
charset="gb2312";
reply-type=original
I am a beginner of GMF... and your solution seems too hard for me.
I will learn more about GEF, and then try to understand your reply:)
As for "Gradient" property, I tried it on my figure, and there is no effect.
(all i want is to making my figure render like Rational ROSE's apprence)
Can anybody give some clues?
thanks in advance:)
zhang lei
"Khai M Nguyen" <khai.n@situvista.com> wrote in message
news:f3b94h$qr4$1@build.eclipse.org...
> pretty simple.
> figures are]
> that there.
> versions.
> -- Khai --
> zhang lei wrote:
>> What is more,
>> How can I do this?
>> Any suggestion?
>> zhanglei
>>> attached here.
>>> color of
>>> the figure.
>>> Any suggetstion?
>>> Thanks is advance.
>>> zhanglei
Content-Type: image/jpeg;
name="gradient_property.jpg"
Content-Disposition: attachment;
filename="gradient_property.jpg"
/9j/4AAQSkZJRgABAQEAYABgAAD/2wBDAAgGBgcGBQgHBwcJCQgKDBQNDAsL DBkSEw8UHRofHh0a
HBwgJC4nICIsIxwcKDcpLDAxNDQ0Hyc5PTgyPC4zNDL/2wBDAQkJCQwLDBgN DRgyIRwhMjIyMjIy
MjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjL/ wAARCAMABAADASIA
AhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcICQoL/8QAtRAA AgEDAwIEAwUFBAQA
AAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS0fAkM2JyggkKFhcY GRolJicoKSo0NTY3
ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqDhIWGh4iJipKT lJWWl5iZmqKjpKWm
p6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uHi4+Tl5ufo6erx8vP0 9fb3+Pn6/8QAHwEA
AwEBAQEBAQEBAQAAAAAAAAECAwQFBgcICQoL/8QAtREAAgECBAQDBAcFBAQA AQJ3AAECAxEEBSEx
BhJBUQdhcRMiMoEIFEKRobHBCSMzUvAVYnLRChYkNOEl8RcYGRomJygpKjU2 Nzg5OkNERUZHSElK
U1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6goOEhYaHiImKkpOUlZaXmJmaoqOk paanqKmqsrO0tba3
uLm6wsPExcbHyMnK0tPU1dbX2Nna4uPk5ebn6Onq8vP09fb3+Pn6/9oADAMB AAIRAxEAPwD0LQtD
06fSbfUNRtoL26vIlnZrhBIqKwDKqq3AwCOcZzmtFdD0Fjj+xNL/APAOP/4m qWjSP/wjOkY/6B9v
/wCilrO1i6kksprcI29s4cRyNj8VU10wheyM0r3bZ0P9gaF/0BNL/wDAOP8A +JpRoGh/9AXTP/AO
P/4mvNdFuNW0zX7YLM5tpZBHJGbecAgnGcmPA69SRXo19LIuk3roxV1gcqyn BB2nkUV4qim9xRXM
7Jk//CPaIRxoumf+Acf/AMTSHw7o3/QF0z/wDj/+JrmIPGsunto1k1qLxJo7 SKedZJWeKSUKBvxE
Yxyyn5pAxBzg8Z018bRvZGQWkUdxFbyyXUc05CwSJJ5QjJVGZizhguFydvAJ IFRKy/H8AinJJ97f
iaY8PaNnnRdM/wDAOP8A+JqYeHNDI/5Ammf+Acf/AMTVXwv4gbxFY3ks1i9n PaXBt5YiJOoVXBAk
RH6OOqA/UYJ0rDVrW/s5rmJLuOOLO77TZy27cDPCyKpI9wMUm0txpNlf/hG9 D/6Ammf+Acf+FH/C
N6H/ANATTP8AwDj/AMKyY/GF5HaQXt7o8UNpeW0lxZNHeeY7bUMgWRdgCEoC flLgEEZ6ZB4q1mVN
tvoFu1ylmL6aF9Q27ImzsUERkNIdr5HCjA+Y5pOSV79P6/QEm9v62/zNb/hG 9D/6Ammf+Acf/wAT
R/wjeh/9ATTP/AOP/CqGpeLxYeHNI1KPT5J7nVPLEFsgkcBmjMhyY43fAVTy EPbgDJEdj4q1LVvJ
t7HQgl/5RmuIb+aS2WNN7IpUmIu24oxGUXjk4PFN6Ple4JXXN0NP/hG9D/6A mmf+Acf/AMTTf+Ec
0T/oCaZ/4Bx//E1gwa21lcXEtwtxcyRXGovHm7dVVY8HYV6MOwyPl7datL4s 1NAFuvDwSaexa9tI
oLvzS6qVDLJ8g2sPMU4TzMjdjJABmM1Jadk/vVx8jvbza+52NT/hHNE/6Amm f+Acf/xNJ/wjmif9
ATTP/AOP/wCJrAu/H8sUdqllpkOp3MkBuJRp0s9zCqb2RQskUDZYlW4ZUAII zW9qOtXEMmnWun2C
z318jSpFdSm3WNFCli7BWIILKMBScntg1fMieV3sL/wjuif9ATTP/AOP/wCJ o/4R3Rf+gJpn/gHH
/wDE1gx+ONRuorVLTw/G93NFeyPFJfbVj+zTCNhuCHO7PHHXA6citrHi7VLv wxqUlpp32GaXTRe2
cj3Y8zymO1mbajBHGQQAWzkcqcgDfl/Wv+T+4Grbv+tP8zpv+Ed0X/oC6Z/4 Bx//ABNH/CO6L/0B
dM/8A4//AImqGqa5L4Y0nS7VdPlur+4GxYVmuLkLtXLFpFieRgOBkpkkjOKg XxpN5+l2s2izQXmq
xg2kUzsmZFJ81X3ICgVcMCRlgegPFCabshWdrmofD2jD/mC6Z/4Bx/8AxNN/ 4R/R/wDoDaZ/4BRf
/E1gT/EQwTaqraWssNpZ3N3bzQyy7LgQsARueFV53DlDIBzz0zZk8X6nbS3S XXh9IhZ+TLcOL4Mq
wSHAI+TJkHzZTAX5fvnjLurJ2BprdmqfD+j/APQG0z/wCi/+Jpp0DSP+gNpn /gFF/wDE1RbxVepc
ySvoyDTItRGnvcC7zLuLhA6x7MFdzKDlgRzgHAziW3jW607TbW1h0271a7EU lxOQs7tt811RQY4p
MsdjABig4HPpKnHR23/4cfLK9v67HUf2DpP/AEBtM/8AAKL/AOJpv9g6T/0B 9M/8Aov/AImn2msy
XPiCTTpLaC2QRebGJrki4kHHzCLbjZzgnfkEYIFZd34tvoNSnhh0A3FrDqC6 eZVu1V2kZAykIygb
csATuyOwPSmpR7f1t+egrO17/wBbl6TQtLA40fTP/AKL/wCJqBNE00tzpGmf +AMX/wATVC58VeWo
ubnTWW7tba/eSKO9YxhrcrkfdAcNkEMVyvpyacniu7jkkt7rRUivnS3e1hW7 DiQTMyqHbaNhBU7s
BhjoW6UKcX/XfYbhJK721/Dcu3Wi6YsOV0fTM4/58Yj/AOy1z0+mWwlIXStK x/2DYP8A4ipRr+rW
d9qUVxpqz3c+qxWcVst6TFFm1V9wcpnblST8oPJOCeCy08SvcXFv9t0tLOCW aa2Mr3QbE0QctjC/
6vEbfMSDx93HNdFGpC12jCtSnpZkQ023/wCgVpX/AILYP/iKcNMtv+gVpX/g tg/+Iqrb+M3lguSd
FzPG9qsaLJIiyieTYpBliQ8EZ+6QfX00Z9Uu5LO+sXtI7TVlkjtohFL5yZlH yuCQpIUbiQQD8hrV
1YW+FfcY+zmnZyZGNMtv+gVpX/gug/8AiKcNLtf+gTpX/gug/wDiKY+v3Nlc vawaI9za294un+cb
wea7mMMrYYcjJAJLZ74NWINdvLt4rO00m3bUt0wmjlvCkUYicISJBGS2SVwN g4znGOV7am9l+A/Z
z6y/H+uw0aVaf9AnSv8AwXQf/EU8aTZ/9AnSv/BdB/8AEVWn8R3OoafcrpOl hpobIz3QluvKaEku
m1CFYOwaN+6jgc88RWniyRJLKxh0m7vhHHbR3U6RzMwd0UkjbEyHAYMdzqev tle1hdrl7fjf/Ifs
59/x9P8AM0BpNl/0CdK/8F8P/wARVa7s7KFCV0nSs/8AYPh/+IqOyuZ7vSLW xFxMbi61K7Dy+Yd6
QRXD55znGAkfHTePSqI8SX1/LAsehLtuvNFuxvAOY2wS/wAvyqexG4+wqJ1o R0sjSNKd9zMvZCGI
i0zSh/3DLc/+yVnlbtzxp+k/+Cm2/wDjdah1q2eM30GnSyvJbWkixm4IB86R kCgH5QQe/f2xWla3
80sxsE0mA6qtw0LRG6IhAVFkL+ZszjDqMbM5PpzWTkuxtySRy7Q3Y66fpH/g otf/AI3TNt0P+Yfp
H/gotf8A43W7YX16lrDbrpa3V7PLfSES3e1YhFNjbu2nIwwA47DgDoRa3DLa fapdOS1imsxd2vnT
5MikgYcKrbSSy4C7icjgHilzLt/X9JjcWmYW26/6B+kf+Ci1/wDjdLtuf+gf pH/gotf/AI3Wtaa2
16kccOjj7Y929qY5JXjVSI/M3EvGGxgjqgPsavi+hXRJb2Wx23McxtjbiQEG XfsAD4+6SRzjoena
jmW1hWfc5oC6H/MP0j/wUWv/AMbqzA84YBtN0k/9wq2/+N1pS6pPatcwXOjR /aopbeNUhut6yeax
UEMUBAGOcj1+psadqM811HFNoqQj7W1nI/2oMolAJXbhclSAMkhSM9DS512/ r+mgaff+v6RNY2yT
KN+laV/4LoB/7JWj/Zltj/kFaV/4LoP/AIisjw7qGpQ2ccQsIrm/uWmuZDLq L7FjV9vGYztOeAij
bgZJBOK0tP8AFj3/ANnYabDDA2npf3E092FSBW3jb905Py9eBjPTAB2hXhbV L+v+GMZUpu7i2POm
W3/QK0r/AMF0H/xFMOm2/wD0CtK/8FsH/wARUdr4vmuYJQNE/wBLW4ghSIyS Rq4lztbMsSMACDn5
enQnpTbnVtRn1SxtYtPSO/gvXt57dbs+S+YDIp8zbkrgg/cyCOnetfbU/wCX 8PT/ADMvZz/m/Eed
Og/6Belf+C2D/wCIph0+H/oF6V/4LYP/AIit7T72G90JNSltpIiFbzYY1aZl ZSVYKFGW5BxgZPpV
XWpopvBuqX1p9ohZbOZo2kieCRSFbnawDDkccU3VppN8q0CNKcmlzPUyTp8X /QL0r/wWwf8AxFMN
hH/0C9K/8Flv/wDEVYsXOn2FtHb6TqAvb2QJFFqeobw2ELF94eXauAeAMk44 71XurqW2126W+iY/
Lpq+RBduEjeSeRCQwAJHTIwNwGDVqcL25V9xHs5tX5n9402Mf/QM0r/wWW// AMRSfYU/6Bmlf+Cy
3/8AiKuW2uzzvFNJo6pYy3klksq3QaTerugOzaBtJXH3sgnpjmoJ/Exgswx0 6KS8e5NulrBNJM0Z
Clj5oSIshAB4Ct1HODml7al/Kvu/ruL2VS9uZ/eRfYk/6Bmlf+Cy3/8AiKT7 En/QM0r/AMFlv/8A
EVsILrW/Css1rBLp1/NG6osyshRwSM/MoIBxkErnBBx2rFkgtWsYLKM6raTN fwR3VtPeSNLGG9JQ
5JVgOqsRwehyKHVgnblXT8XYfs5pXcn/AMMOFkmedM0r/wAFlv8A/EUv2SEd dL0n/wAFlv8A/EVU
1trjRBqVnYyXd0lubKeKNpy0oaScq0W9juIYL/ET94jpgDa0WGOfSVvzdm6k uyZXbLbEboUVT90L
jbjAOQc85pwqQl9lfcE6VSKvzP7zKeG3X/mFaT/4LLf/AOIqIi2/6BWkf+Cy 3/8AiK1LyNVJxWW/
DV2Qp02vhX3HHKpUT+J/eLi1/wCgVpH/AILLf/4il22v/QK0j/wWW/8A8RTB Siq9jT/lX3E+1qfz
P7x+20/6BWkf+Cy3/wDiKXZaf9ArSP8AwWW//wARTRS0vY0/5V9w/a1P5mO8 u0/6BWkf+Cy3/wDi
KPLtP+gVpH/gst//AIikFLR7Kn/KvuD2s/5mL5dn/wBAnSP/AAWW/wD8RS+X Z/8AQJ0j/wAFlv8A
/EUlLS9lT/lX3D9rP+Zh5dn/ANAnSP8AwWW//wARTo4rMuAdJ0j/AMFsH/xF Np8X+sFJ0qf8q+4f
tZ92dTpWk6TMgMmjaUfpYQj+S1q/2Bon/QE0v/wCi/8AiaraN/qxW1XnVIxU tj0acny7md/YOif9
ATS//AKL/wCJpDoOi/8AQF0v/wAAov8A4mtGis+VdjS7Mw6Fo3/QF0v/AMAo v/iaQ6Ho3/QF0v8A
8Aov/ia0iKYafKuwczM46Jo//QF0v/wCi/8AiaYdF0f/AKA2l/8AgFF/8TWk aYRRyrsLmfcz/wCx
tI/6A2l/+AUX/wATSHRtI/6A2l/+AMX/AMTV8000cq7BzPuUf7H0n/oDaX/4 Axf/ABNKuj6RnnRt
L/8AAKL/AOJq2aSjlXYOZ9xF0LRCP+QLpf8A4BRf/E0v9g6L/wBAXS//AACi /wDiaswv2qejlXYO
Z9zN/sLRf+gLpf8A4BRf/E006Ho3/QF0v/wCi/8Aia0jTSKOVdg5n3M06Jo/ /QG0v/wCi/8AiaYd
G0j/AKA2l/8AgFF/8TWkRTCKOVdg5n3M46PpP/QG0v8A8AYv/iaT+yNJ/wCg Ppf/AIAxf/E1fIph
o5V2DmfcqLpGkE86Npf/AIAxf/E1YTQ9Fb/mC6X/AOAUX/xNOBwasRPzRyrs HM+5B/YOi/8AQE0v
/wAAov8A4mj+wdF/6Aml/wDgFF/8TV8HIpaOVdg5n3M/+wdF/wCgJpf/AIBR f/E0f2Dov/QE0v8A
8Aov/ia0KKOVdg5n3M/+wdF/6Aml/wDgFF/8TR/YOi/9ATS//AKL/wCJrQoo 5V2Dmfcz/wCwdF/6
Aml/+AUX/wATS/2Don/QE0v/AMAov/iav0Ucq7BzPuUP7B0T/oCaX/4BRf8A xNL/AGBon/QE0v8A
8Aov/iav0UuVdh8zKH9gaJ/0BNL/APAKL/4mj+wNE/6Aml/+AUX/AMTV+lo5 V2DmZmvoGigZGiaX
/wCAUX/xNMGh6L/0BdL/APAKL/4mtXqMVARtODRyrsF2UxoWi/8AQF0v/wAA ov8A4mlGg6J/0BNL
/wDAKL/4mrgNPBpcqC7KQ0DRP+gJpf8A4BRf/E0v9gaJ/wBATS//AACi/wDi avA0tLlQ7so/8I/o
f/QE0v8A8Aov/iaX/hHtD/6Aml/+AUf/AMTV8GlBo5UF2Z//AAj2h/8AQE0v /wAAo/8A4mqcmg6I
uu2aHRtNEbWtwzL9kjwSHhwSMdRk/ma3ax9X3jVLEoSCbe4UYPU7oTj8lJ/C plFFRZa/sDw9/wBA
TS//AADj/wAKP7A8Pf8AQE0v/wAA4/8ACuflE4v3a4tL+7gMSCMW90YtjAtu ziRM5BX16dqZL5jh
BaabqltN5qHzZr9nUKGBbIMzZyuR0PX8ai2pdzZudB0EXNiF0bTAGnIYC0jG R5Uh549QD+FQ32m6
Nb3McFv4e0N2MMk7vcRRwoiIVBJYRt/fHbGAeagk8/z7TLv/AK5sc/8ATGWq l9FcPOS8FxcQy2k9
rIIWQOvmFORvIHRT+lPlBMcRo5trmeLQ/CN0ttC08qWtxHI+xRkkAQ/zIGSO a0NY0TQodPDx6Ppq
sLiAZW0jHBmQEdO4JFYc0V3JBdD7Pq8801pLaxm5a22J5gGT8hB6qPWrWs/a DpmN7/8AHzbd/wDp
vHUST5WzSnZzivMhEekn/mE6V/4Aw/8AxNMuv7Jt7ZpV0bSnK44NjHgDOCTh CcDqcAnjoa45LbUP
+fib/vo1P9n1DbxPP1GcHJAzyQCQCfbIrzvbSuj3/qlHlb0+46+WwSCKWaXw /wCH0toohMbwxxm3
dGxt2MIizMeRjb2H95csiTSpII5G0XTI2ZQxQ2MOVJHT7tZU11FNpS6SunXc VlAA9rMrq0yzckuw
3BSDubgH16ZG3H+zaiUBaaUNjkbzwa0rVeW3I7/M5sJh1O/tVb5HYRw6Q0yL /ZOlYLAf8eMP/wAT
VHUNEsofh/Y6zaRJa3cFhDO7xLtEo2KW3AdSeueufxB521tr/wC3Qkzy4DqT 8x6A811+oB4/gwiu
CHXRYQwPXPlLW+Ek5u0jjzSnGjG8De8PwhvC2j8f8uFv/wCilrN8Q+CrbX4z mdreXBw6jOD9KtaX
qC2fgixuAAzQaVHKFJ4O2ENj9K2vsOqf9BCw/wDAJ/8A49XWp8lmjgV9bHCe GfhXZaDqi6lc3r31
yn+qzGEVD64yefxrsr/R7bVLNrS7WRoGPzokzx7h6HaRlT3B4PcVZ+w6p/0E bD/wCf8A+PUn2DVf
+glYf+AL/wDx6idTnd5AotGbc+FNHu7+O9mt5fNjljmCx3MscZkjxsdo1YIz DAGSCcADoBVhvD2j
sdRb7EobUXWS6dWZWd1ACsCDlWGAQVwQeevNW/sOqf8AQRsP/AF//j1J9g1T /oI2H/gC/wD8eqLx
HaRDpOk2GhRTx2CSqLiYzytNcSTO7kAFizsSeFHftV/z+x6VV/s/VO+o2H/g E/8A8eo/s7U/+ghY
f+AT/wDx2i8QtIp2vhTQ7XzDDaybXieERvcyukSP95Y1ZiIweOEA6D0rO8Ue Gn1VYo7HTbNyLU2p
nm1GeAqnZWSNSJkHXa5x1Hcmt9bHVF6ajYf+AT//AB6nfY9V/wCgjYf+AT// AB6k+V/1/XcFzIzY
/CekjTobSaOR2jjgXz0meKTMS7UZWRgUOCR8pGQSDmpp/DOlXC23mfbfNtka OO4TULhJtrEEq0oc
OwyAcMSOBVz7Hqv/AEEbD/wCf/49R9j1X/oI2H/gE/8A8equZXv8xKLSsijf +H7Kexu1toVS6lju
PLd5GwHmXDE8nqcduO1Qab4R0vT9PECrdLI0CQNIl/PuRVwdsTb8xrkdE2jg ccVq/Y9V/wCgjYf+
AT//AB6k+x6r/wBBGw/8An/+PVK5Vt/Vv+HH7xnSeFdGZLcLFdQvAHCy299P FKwc7m3yI4Z8sMnc
TzzVXW/D0NwhlsdMinupLn7RJI+pz2bqxjEZZZI1ZuVVQVGAcZPNbf2LVD/z ELD/AMAn/wDj1J9h
1T/oIWH/AIBP/wDHaq8bWFaRj+HPC9noul2kMscbXMMU8e6MsERZpPMdFH93 IABIzhe2TV6TQdJk
thbva5iFoLIL5j/6nj5evsOevvVr7Bqn/QRsP/AJ/wD47R9g1P8A6CNh/wCA T/8Ax2m5Rbv/AF1/
zf3sXLJ7lK78PaTevJJLBKssk4uTLDcyRSCQII9yujBl+QbSAQCOtNk8OaRM d00E0sgSJFllupXk
URtuTDltwOeSQcnvmr32DU/+ghYf+AT/APx2j+z9T/6CFh/4BP8A/HqLwBqT Mj/hDvD+6cm0mZZr
eS1MbXcxRIXILIiF9sanA4UDGOK0LrS9PujdmaDf9rRI5/nYb1QkqODxjJ6V P/Z+p/8AQQsP/AJ/
/j1IdO1M/wDMQsP/AACf/wCPUc0LWBxk9zB03wvZ22oXN/do0lxJfSXaKtzL 5WSflZoshC4GOSpI
wMHgVZl8OaQ4g2xXMDQKyI9tezQNtZtxBZHBYbucEnHatT+zNS/6CFj/AOAT /wDx2k/svUf+ghY/
+AT/APx2hOCSXYGpttmbd6DpV/JdPeRT3H2mNonWW7ldFVhhgilsJkcZUA1O dO08lj5HLXS3Z+dv
9aAAG6+gHHT2q3/ZWof9BCx/8An/APjtJ/ZOof8AQQsf/AJ//jtPmgJwkzLu dF0mYSmW13eak6P+
8cZE2PM799o+mOMVFc6XpeoNIbm23s8UcRYSMrBY2LJtIIKkMSQwwfetdtGv 2GDqFj/4Byf/AB6o
10G9U5/tCx/8A5P/AI9SvT7Fe/3MQ6JpGmRCS3tnDi4+1l3nkdmm2FN5LMST tJHP161gTDTSUhkt
leNJpZgjsWG+QMHJBPOQ78Hjmu5n8P3txHsbULHH/XnJ/wDHqyn8Ayu+46jY 5/68pf8A4/W9KpRi
rSOerCs37rOKvNGsZrR47XzfMnmtmme4u5pGaOKQPtDMxI43Yxjk1q2ttY2l 1DcQ+aXiZ5MyytKz
SMoXezPliwUFRzwCRXRL4FnXpqVj/wCAUv8A8fpw8EXA/wCYlYf+AUv/AMfr X22H7fgZ+yxBjZs2
ZmMXLXIuj87cygABuvoBx0qKey0y5IZopY5FleUSwXMkUgZ/v/OjBsHjIzjg ccCugHgu5H/MSsP/
AACl/wDj9KPBtyP+YjYf+AUv/wAfpe1w/b8P67L7hqlX/r+vM5ufR9Euooop LMrHHCLcJFM8avEO
iOFYB168NnqfU1P9j06K6iu41uIZYljQeTdyxqwT7odVYB8Dj5geOK3x4Puh /wAxGw/8Apf/AI/T
ZPBt1Iu3+0rEf9uUv/x+l7Wh0H7Kt1OIlv7PSrySe1LKWVlCFshNztI5Gefm ZsnnHAxjFZMesW0D
QGJNv2feIvnJ27zlu/eu4uPhe1w2X1Sx/wDAGb/5IqD/AIVKv/QTsf8AwCm/ +SK55Tg2dEYSW5xM
F3p0apGsGEVYkUeY3Aibcg69mOffvWss+l3rvJNG4lebzzLFO8cgfYEyrKwK /KADgjNdB/wqVR/z
E7H/AMApv/kipF+FZTpqlj/4BTf/ACRS5oFNT7mFHPo+lwwrZW6wrAkqRhXb CrIwZx17kA+3aufu
r/TvJhtxD+7ggFvEBI2UQEEAHOQQVUg9QR1rvX+FZcYOq2X/AIBTf/JFQN8I I2OTqdj/AOAU3/yR
RzxFyzPNZJLTfbiEyrGtw1xKxupfMZym3cH3bs9O44qxNfWJs2hS1jkxE0YW SVhkMwYktyclgG3c
nPOc16B/wp6L/oJWP/gFN/8AJFH/AAp6L/oJWP8A4BTf/JFLmgHLI84027S3 luZrhRvmljk2id5S
Gj+6xdvmY59ewA7V1Wk6jazfOY+Rcfac7z/rMY3dfTt0rd/4U9F/0ErH/wAA pv8A5Iq9Z/DH7GuE
1Kx/8Apv/j9HND+v68kHLI8+8Q3MSxW8VraRERK6hmu5ISoY5K5UEspPJUnH ApmjahZ2llHaSokw
+yJZyFhxJGueNvTHzN+degXXwsF2cvqVj/4BTf8AyRVdfhBGpyNTsf8AwCm/ +SKE6aC07WOfOnWF
3bKtv52ZbmGa4ea8md2EecYdmLAjPGCK37K3sLVoWhiffFK0yySTO7l2XaWZ mJLHbx8xPAHoK1LX
4dy2owmp2OP+vKX/AOP1dTwbcp01Gx/8Apf/AI/XTCrQSfn/AMD/ACOaVKs2 ZtrPFY2wgtl2Rhmb
buJ5Zix6+5NJczpf2c9pcDfBPG0ci7iNykYIyOehrW/4RG5x/wAhGx/8ApP/ AI9SjwndL01Gx/8A
AKT/AOPUOtRtYapVk7nIyaZp4txbMbyRA6yI0l/O7xsMgFHLlk4JHykZBxT2 s7HO94pJH/c5eSeR
2PlMXjySSThiTz175rqG8H3LNk6jY5/68pP/AI9SnwhcsMHULH/wCk/+PVSr 0UT7Gt3OK0XR4LIG
e43SXX2meZSLiQxqZHYhghO0PtbG4DPXmrDaTp3kmMpcOxkEnnPeTNMGAIGJ S28YBIwDj5j6mus/
4Q+5xxqNj/4BSf8Ax+j/AIQ+6z/yEbH/AMApP/j1L21Dt+A3SrPqc+Xj+wGw cyvBt2/vJnd/rvJ3
Z985FUDp2nfZHgZbgh5VlaU3cxlLr90+Zu38dueK64+DbknP9o2P/gFJ/wDH 6a3gu4ZcHUbH/wAA
pf8A4/Tdag91+AvY1jk1i06C1a1SFijTLO7PK7u8ikMrM5JZiCo6k8ADpxT4 vJtpbma3Qo1y/mSg
O20tjGQucAnvgDPeuk/4QOXdu/tGxz/15S//AB+pv+EMn27f7Qsf/AKT/wCP U/b0FsL2Fd7nHzSl
85qg5+Y13reCJm/5iFj/AOAUv/x+oj4BlJz/AGjYf+AUv/x+t442ku5hLBVW cNSiu3/4QGX/AKCN
h/4Ay/8Ax+j/AIQKb/oI2H/gDL/8fqvr9HzJ+o1TihSiu1/4QKb/AKCNh/4A y/8Ax+j/AIQOb/oI
2H/gDL/8fpfXqPmH1GqcWKdXZ/8ACCT/APQRsP8AwBl/+P0f8IJP/wBBGw/8 AZf/AI/R9epD+pVT
jRS12P8Awgs//QRsP/AGX/4/S/8ACCz/APQRsP8AwBl/+P0vr1IPqVU42nxf 6wV1/wDwg1x/0EdP
/wDAGX/4/Sr4HuFORqOn/wDgDL/8fo+u0h/UqpLo3+rFbVVLbQr+1ACajYf+ AUn/AMeqz/Z+p/8A
QQsP/AJ//jtcM60W7o7YUpKNmLRSf2fqf/QQsP8AwCf/AOPUf2fqf/QQsP8A wCf/AOPVPtIl+zYE
Uwin/wBn6n/0ELD/AMAn/wDj1J/Zupf9BCw/8An/APj1HtYh7OQwimEVL/Zm pf8AQQsP/AJ//jtH
9l6j/wBBCw/8An/+PUe1iHs5Fcim1Z/srUP+ghY/+AT/APx2k/sjUP8AoIWP /gE//wAdo9rEXs5F
U0hq1/ZF/wD9BCx/8An/APjtH9j3/wDz/wBj/wCAT/8Ax6j2sQ9nIrI21quK 2RTP7Gv/APoIWP8A
4Bv/APHaeumaivTULH/wCf8A+O0e1iHs5CmkNL/Z2pf9BCw/8An/APjtH9m6 l/0ELD/wCf8A+O0e
1iHs5EZFRkVP/Zmo/wDQQsP/AACf/wCO0n9l6if+YhYf+AT/APx2j2sQ9nIr GmkVa/snUP8AoIWP
/gE//wAdpP7Ivz/zELH/AMAn/wDjtHtYh7ORTp6Ng1Z/sa//AOf+x/8AAN// AI7Sf2Nf/wDQQsf/
AADk/wDj1HtYh7OQ6NsipKYulaivTULH/wAAn/8AjtO/s7Uv+ghYf+AT/wDx 2j2sQ9nIWik/s7Uv
+ghYf+AT/wDx2j+ztS/6CFh/4BP/APHaPaxD2chaKT+ztS/6CFh/4BP/APHa P7O1L/oIWH/gE/8A
8do9rEPZyFopP7O1L/oIWH/gE/8A8do/s7Uv+ghYf+AT/wDx2j2sQ9nIWik/ s7Uv+ghYf+AT/wDx
2j+ztS/6CFh/4BP/APHaPaxH7OQ6ik/s7Uv+ghYf+AT/APx6j+ztS/6CFh/4 BP8A/HqPaxD2chab
IMrkdqX+z9T/AOghYf8AgE//AMeo/s7Uv+ghYf8AgE//AMepe0iHs2Qg08Gj +y9R/wCghY/+AT//
AB2l/szUf+ghYf8AgE//AMdo9pEPZsUU4Gm/2bqX/QQsP/AJ/wD49R/Z2pf9 BCw/8An/APjtHtIj
9mx9OFR/2fqf/QQsP/AJ/wD49R9g1P8A6CFh/wCAT/8Ax6l7RByMlzUVzaW9 5GI7iISKrblySCre
oI5B9xS/YNT/AOghYf8AgE//AMeo+w6p/wBBCw/8An/+PUc8Q5GVv7GtP799 /wCDG4/+Lo/sa0/v
33/gxuP/AIurX2LVP+ghYf8AgE//AMeo+xap/wBBCw/8An/+PUuaJXLIptod kxVmN6SpypOoXHBw
RkfP6Ej8aP7GtP799/4Mbj/45Vz7Fqn/AEELD/wCf/49SfYdU/6CFh/4BP8A /HqXNELSKn9jWn9+
+/8ABjcf/HKjm0DT7iPy5ftrpkNg6hcdQQQf9Z1BAP4Vf+w6p/0ELD/wCf8A +PUfYdU/6CFh/wCA
T/8Ax2i8QtJaoyx4V0kfw3//AIM7n/45Th4X0r0vv/Bnc/8AxytL7Dqn/QQs P/AJ/wD49S/YtU/6
CFh/4BP/APHqm1PsXz1e/wCJnf8ACL6X6X//AIM7n/45TW8L6X6X/wD4M7n/ AOOVp/YtU/6CFh/4
BP8A/HqPsWqf9BCw/wDAJ/8A49Ran2Dnq/zfiZQ8L6QG+eC4lXuk99PKjexV nKkexFV/HH/Ij6z/
ANerVufYNUP/ADELD/wCf/49XOeKbg3nw3v7llCmbT/NKjoCyg4/WtKXLzLl MMQ5Om+Z9GZUIl/4
QaLrj+w1/wDSau5luZQz4xwTXO20KH4dwt3/ALFX/wBJ627lnkimFvuSVlby 3kt3ZVbsSowSM9sj
6ipaurGsTgPDupT23hG11G7s9beWUWgee61aRknZ5UXcgEzFRk5I2rkcHgkV Zj8a3+lW7W6Ws+pX
c99fFVPnPsjjmK4/dxyMMblAG3HuOM7GnaFcw2MWmajLa3GmQKnkwW2nzwsr IyshLtK5IBXp39ex
sz+G9HuEQNaXcbJNJMkkDzxSK8hJfDoQwDE8jOOnHApvy/rYu6/H/M17e+lu LaKby2j8xA+yRSrL
kZwR2NPa5l2np0qOPy4okjVLgqihQWR2OB6kjJPuabOztbyLBuSYoQjyW7uq tjglRgkZ7ZH1FErN
OxCv1OI8K6xd2HhGHU5LLVprueKBFe+1EypcySMFBUGV/LGSCTtU4PQ4xUlv 4g1VNXvEu7ctdtqq
QQwC/kEMTfY9/UD5kJB4K9WzjIqzpHg77FbzWV/cfatOkiEYto4rxfLIIKlT JPIExjjaAQcEEYrX
tfDmj2bq8Nnc71uBdb5GmkYyhPL3EsSSdpxz9etJ2f8AXoVfcb4P1fVdT8Ka fe6mIftM0KuXjfdv
BA+Y/KoUn0AwPWtz7TL7VQ03T7PSLMWllDcpApJVH82Tb7LuzgegHA7Crm9f 7k3/AH5b/CqbQjj4
dZ1Gw8Xa1cT3MkmmG7itXjdyVtiYYyjqD0BZiGx3ZT2NVtN8b3mnaF4djli+ 3vcW9v8AaZTJK8qe
YwQO2I2XBJJy7rnBxnFadzoeqyy6mI7rTBb6g5M0U2j3EhddoQBj54BO0AHA AOM4FOsvB+lxWdlH
d27yTWsccYNstxDEyxsWjzGXbdt4wWLHOemcVK0svT/gjYzUPGEp0e5LWRMs VvdPdwpdNG0QhBBw
6jcCx27SMHB3DpTrrxlf2zSPBpaS2UE9vayyvdFXEkhTou05UCRckkEnt3rU k0XS5W1JnspSdSjE
d2dkg8xQpXHtwT0xWDq/hd9R1yGSGwjgtRNBLNcfaLgvIIiGA8jYIy3yhd5Y kL+VCtdX8v8Agg/8
yHWvHmpRrrNpYWsPmW9ncS294ryFN0WA2S0WwsMnhWcZXBxVm58c6lZXdpYP pDXN0YI5rr7N58qo
rsQNpSEgn5WPz+WPc840l8L6Gs08v2G4YzpLG6u0zIFlOZAqk7VDHk7QKVvD Wks1u/lakstvH5SS
pc3KSMmchXcMGcA9AxOMmhdL/wBb/wDAB+Xn+n/BNz7TL7VU1V9Rn0m7h0+d ILx4WWCVuiORwe/f
2P0NWN6/3Jv+/Lf4VFcxQ3dtJbzRzmORSrbUkU4PoQAQfccim7NCWjOPj8VD w/YNbw2Wpyai9ysL
WV7cT3LI5QtuDjzXKFUJG0NyOi/Ni1cePbq3/s0tphzc+WLiI+cJbffJsBK+ VgLnJBkMZIBwM8Vo
/wDCL6KbR7drS8fdKs5meW4afeowrCYnzAQOBhuhI6E1k6h4PmuNQWe2uoli jEYRbq1vJ3Ow7lMj
faFEhDEkFlyM4pddQ6aFxPGWoyhhHpcJklv5LG0VrogSvGX3M52fIu2Mnjcc 8Y7mjqPiXXNK12/u
Gso547bSYbm4t1vWEcWHl3lCV+ZyAMZVc7eSOM78uh6VNYvZtaXAiadrnKea jrKzFi6uMMpyT0I6
kdOKDoeltFPHJbXUguLUWcrStM7PEN3yliSc/O3Oc89aP6/D/MrS77f8H/I1 EvJJI1dcbWAIpWuZ
dp6dKYhjRFRY5gqjAHlP0/KmTs7W8iwbkmKEI8lu7qrY4JUYJGe2R9RTkk00 iFfqedeGdcvrLR01
iFtWu4YNHe4v/t8s/lyzKAyeU0ueuJMlPlxj2rpJ/F+rxeYqaPbvJbWgvLtf tpGyNi20IdnzvhGJ
B2gHA3HrTrHQ7+HT00m8ubKbR/Ia3e2g0u4icxlSuBIZmI+uCfp1q9f+H9J1 KVJbmzuGdI/KwjTR
iRByEkC4Dr1+VgRyeOTSdun9b/8AAL0v/Xl/wTHu/G5097w21jPcTyXscESG SaQOWgWXO1VdkAXP
CKeRnuSL1n4r1PUpoLe00pFnECT3a3crweSrMygKDGWY/IxGVXjGcZwI7Xw8 l5FfSa1a4nu7tboJ
aNMPIKIqLslCowOFzkBfvEdOt1vD+mNJayGPURNbLtSUXFyJGXO7a7hsyDPZ yR19aen9en+ZL/r1
IfCes61qNleSaoluGjvZ4ozFKX+VZGXafkXgYAB5JHJwa3/tMvtVCy0+y06S 5e1huU+0yGWRT5rL
vJJJVTkLkkk7QMmrm9f7k3/flv8ACjSyB7s4/wAa+J/sF1bWg1m30+aGJr7b JcrEZihwkRyeQx3Z
H+zS64YdVufD2oW19qKw6jcorfZtRuIUeIwyOPlRwByFOQAeK6eO1tYbye7S 3lE9wFWRzG53Bc7R
04Ayenqagj0jTYoLOFLSYR2Uplt12yfu2IYfiMOwweBn2FJJde/9fgH+X9fi VNCvLo6xr8DTSSRw
XUSRLJIz7F+zxnAyfUk+5JNZeoz3Vz8QRA0OrXEEdnbuFs79oIoWMsgLuolT cCAOzcL09dsaHpy6
vJqiR6gl1I4eTy57hY3YKFBaMHYeAByO1F5oenXupLqMseoJdKix74J7iEMq kkBghAYZY9QetNW0
b6f5DezRiXniPVb3VtI8u2NvpzapJbiVLk75tkcwYOgAwpZcj5j90EgVT0vx pqcbS3clsq6LBosN
95ZummmXPmE8suXY7dvzN2B6kgdEvhrRk1Iagtlci4WY3C/NNsSRgQzKmdoJ DHOBznJ5pYvDeiw+
UEsZwkdr9jEZ84o0PPyOp4cfMfvA4yaS2/rt/mO6v/Xe/wCRQufGWq2EE4vt HhS7QQPHFDeF0dZZ
RHy5RSGBPIwR0wfTpobq6aCMzpGkxUF1Riyq2OQCQMjPfA+grHg8N6Nb20kC 2l3IsjRszTSTyv8A
u2DINzksFUjIXOOTxya2N6/3Jv8Avy3+FPQnUc1zLtPTpXmXhfXNQsdLOqu2 pt9n0Zrq5h1C9eUX
jcFZIsu4QfK4ONpG5cr0r0edna3kWDckxQhHkt3dVbHBKjBIz2yPqK5ux8NX MTWMN7LYzWNnC8CQ
w6ZcRt5bLtK7mnbI4XIYNnHrghea/rcatsyfVPGc+nSTxpYee8cFrKoE23cZ pTHt5HGMZz39utX9
F1691Fr6C8tIra7spxDKkUxlQ5RXBViqkjDDqBzmq0HhXQ7dZAtneOZBEGaa W4lYiJ98YyxJwG5x
+HStOC1tba4up4YJllunEkzeW53MFCg8jjhQOPSnoIt/aZfauY1W4udS126s pGvWt7KzjuFtrC6a
3knd2ccuHTgBOBuAyxz0GOk3r/cm/wC/Lf4VzOveH7/WL8TxXlvbrGNsTCxu lnVSBuUyxTxkqSM4
wB06kZpSt0GjHsfEV0PEWnX0F3eHSG0u1WSK6lLECV5FWRuSC+5UBPoTzxWf qet6vcz63dC8vjbX
SWElrb29w0RWJrox/IQy7TIq5zkfewTxXZ2fh2xTTWtb60jmeW0FlN5FrLFG 8KltqhCzYwGPOSSe
c9ALM+iaVcSF5LGQkpDH8qSKNsT74xgcDDHP6HinpcL9vL8Lf19xh+ZczT6f o2zV7C2linuZYZtQ
d7mQoUAQTCViAd+eHB4A4GRT9J8TzIdO06wsrp1me6Eh1O8zJAIZVVwWBffj ccfN2GT3G9qOm2Oq
xxpd29wTE2+OSISxSRnGMq6YZcjIOCMgkdKitdE0uzMDQ2c26BJURnWVyRIQ z7i2SxYgElsmkIwU
+Ily0N8/9liU27W5hMMsgS4SWXywVaSNAfXIypyPmpupeJtZku9Pt1s1hv4N VWCW3hvCYpVa3kdc
vtB28gkFcjbwDxmxf+DNOOky2mm288byvbqxnknf91FKr7AW3FQBuwBgDPat a20HSrVYRHa3TNFc
faVklaaRzLtKbmZiWb5TjknjHoKFbr/Ww+/z/L/Mz73xFeX/AIA1m+VDZ3cN vdxsIpSTHJHvUlXG
D1XIOAenSotP1S80rSrVLXStQ+23s4iji1XUjJkhCxcyb5dq4U8DnPbnNbf9 lad/Zt3p/wBkm+y3
ZlMybJPmMhJfnqMlj06Z4xVT/hGdJNl9kePU5IxIsqNJdXTyRsBgFHLbk4JH ykcE0afl/wAEH/n/
AMA5N/FGr2uiXsqLIdTCarLG8t4xSARSgY24KvgH5cjjbjgMcb8vi3WYEMY0 q2nntbJby9xeFQqs
WwIyY/nYhGOCEHQZq9F4Z0OGAQJp0vlBJ49pWU5WYgyA567iB9O2KbN4X0Wd YVltb1/Kj8rLTXBM
kec7JDnMq5J+V9w5PqaOlv66/wDABtP8fzX6XJdL8R3eqarf26WkaWloUXzz Mdzs0aOBsxwMOcnP
Ydc8bH2mX2qpb2tpaz3M8NvKkly4kmPludzBQoOMccKBx6VY3r/cm/78t/hV aC1Of8Q61d6NfxXi
uzRy2k8Sw5O1plAePj1IDj/IrCXWNQtdOezu7m5uW0Wyu5Lwi5eOSfbxFudc HLIS2exAI6V0Gv6T
eaxJbrFLZrbwSJOkd1pk0zCVCSGDLKnHTjB79c4qrb+HLpr+/m1CXT54tSj8 q/W30q4hknUIVUbz
MwXAPYdPzEW/r+vNsa3V/wCv6QSeNL6G7nRdLRrG1ube2mna6O8GYR7SqbTu wZBnLDjkZ6CC88S6
pd6rpDR2/wBn046pJAJluTvm8uOYMHjAwF3LkfMc7QSBW62i6W6XCNZzFbiW KaUbZfmePbsPtjYv
TrjnvUC+GtGTUxqC2Vz9oWY3C/NNsWQghmVM7QSGOcDnOTzVf1+X/BEvh/rs Zsfjq/8AsMd9PpCJ
a3Nq95alLou7Rrgneu0bG2tkAFhwRkVci8ZmfU5LKO23N9qSCFt/Eqnduccc bTHIMd9o9as2Ph7R
9Okke2srgb0aMK/nSJGhOSiK2RGp44UAcD0FPtND0mxeza2sZEayiMMB2SHY h6jnqfc5PJ55NCtf
+v68gfkav2mX2rB8Y6le2fh1p7Yy+atzbACB9rsDOgKgkgcgkckDnmtvev8A cm/78t/hWbrljNqm
nrbW7RxETJITc2csqnYdwwEdDncFOc44xg5o0BbmBqHi6/tNet7q803UrC0t tOvLiSKWSJhNs8o8
CORgSOcbsfe4701PFmqapcaOZbO408/2kEZQJ0SZDBK2P3kcZbBHI2kcDk9t JdH1G71GG41i40+8
hSGWBo49JnjLJIBuXJmZcEqucqeARxmrVr4d0uzWFYob9xBIJYRPPcTCNgrI Nu9jgbWIwOPbgVPT
+u9x9Pv/ACKmheMb/VZNPNzpcdpDqNs09sy3PmN8u3IZdox97IIJ467TxXS/ aZfaua8LeGbXQNOs
/Mime/itlgkk3TSIvTcI1bhASATtAzgZrot6/wByb/vy3+FXoJ7j/tMvtR9p l9qZvX+5N/35b/Cj
ev8Acm/78t/hS0Af9pl9qPtMvtTN6/3Jv+/Lf4Ub1/uTf9+W/wAKNAH/AGmX 2o+0y+1M3r/cm/78
t/hRvX+5N/35b/CjQB/2mX2o+0y+1M3r/cm/78t/hRvX+5N/35b/AAo0Af8A aZfaj7TL7Uzev9yb
/vy3+FG9f7k3/flv8KNAH/aZfaj7TL7Uzev9yb/vy3+FG9f7k3/flv8ACjQB /wBpl9qPtMvtTN6/
3Jv+/Lf4Ub1/uTf9+W/wo0Af9pl9qPtMvtTN6/3Jv+/Lf4Ub1/uTf9+W/wAK NAH/AGmX2o+0y+1M
3r/cm/78t/hRvX+5N/35b/CjQB/2mX2o+0y+1M3r/cm/78t/hRvX+5N/35b/ AAo0Af8AaZfaj7TL
7Uzev9yb/vy3+FG9f7k3/flv8KNAH/aZfaj7TL7Uzev9yb/vy3+FG9f7k3/f lv8ACjQB/wBpl9qP
tMvtTN6/3Jv+/Lf4Ub1/uTf9+W/wo0Af9pl9qPtMvtTN6/3Jv+/Lf4Ub1/uT f9+W/wAKNAH/AGmX
2o+0y+1M3r/cm/78t/hRvX+5N/35b/CjQB/2mX2o+0y+1M3r/cm/78t/hRvX +5N/35b/AAo0Af8A
aZfaj7TL7Uzev9yb/vy3+FG9f7k3/flv8KNAH/aZfaj7TL7Uzev9yb/vy3+F G9f7k3/flv8ACjQB
/wBpl9qPtMvtTN6/3Jv+/Lf4Ub1/uTf9+W/wo0Af9pl9qPtMvtTN6/3Jv+/L f4Ub1/uTf9+W/wAK
NAH/AGmX2o+0y+1M3r/cm/78t/hRvX+5N/35b/CjQB/2mX2o+0y+1M3r/cm/ 78t/hRvX+5N/35b/
AAo0Af8AaZfaj7TL7Uzev9yb/vy3+FG9f7k3/flv8KNAH/aZfaj7TL7Uzev9 yb/vy3+FG9f7k3/f
lv8ACjQB/wBpl9qPtMvtTN6/3Jv+/Lf4Ub1/uTf9+W/wo0Af9pl9qPtMvtTN 6/3Jv+/Lf4Ub1/uT
f9+W/wAKNAH/AGmX2o+0y+1M3r/cm/78t/hRvX+5N/35b/CjQB/2mX2o+0y+ 1M3r/cm/78t/hRvX
+5N/35b/AAo0Af8AaZfaj7TL7Uzev9yb/vy3+FG9f7k3/flv8KNAJUuJS6jj qK5PXv8AklM//YKT
/wBFiuoWRQ4JSbg/88W/wrmNeH/FqZv+wUn/AKLFXC3MrGNf+HL0ZHbXe3wD Ev8A1BFP/kuK7kkK
pZiFVRkknAFcTDZ5+H0L/wDUEUf+S9dlcjNrJ8sTcZ/fH5B7msJ9DaHUloor AvfEF3bapLaQ6TJP
HGyqZl8zHKg9oyO/rSjBydkOU1FXZv0Vh3WtTQMpdVtwEEgWRZD5uWRSBhDw N+P727HGOu0jFkVi
hQkAlWxkexxxWUakZTcFui7Oyl3HUVkw+KPD1xPHDDrumSyyMEREu42ZmJwA ADySavX8zW2nXM6Y
3xRO656ZAJqxFiiqFruea6WS/uWEcgRciPptVs8J/tfpUMc8qaiI/tUsqG5M O2QJ08rzM8KDnPH0
p2YuZGrRSO6opZ2CqOpJwKqF2MBlWeXeWYqBFvTAYgfdXPQetIZcoqGCcSDY 7J5ykhlU+hxn1x/j
U1ACZBLAEEqcHBzg0tRRDa8w2xL+8PEZ9h973qO+upLO382KyuLs5wY7cpuA wefmZR+Rzz0oAs0V
xum+MZpIrdr22lijeWWWWZk8xUhIZ4kzHnEhDRgKRk4Pdlz1NjqFpqdv59nc JNHna208q2AdrDqr
DIyDgjvQTGSlsWaKz77XdI0ydYdQ1WxtJWXeEuLhI2K5IzgkcZB/KrVpeW1/ bJc2dxDcW752ywuH
VsHBwRweQRQUTUVz3iHXpLC7ttPtDGtzPyzuM7FJwMD1Jz9MHg1n6lqOt+G7 4C6ujeQsfkEkaKJB
/slQNrexz/WspVoxdmZSqpN+R2NFRwTx3NvFPE26OVA6N6gjINZs3ijw9bzy Qza7pkUsbFHR7uNW
VgcEEE8EGtTU1qKK5Cx1bU/ENje6hpl55aW8mFt1RDuXGeSwPOMdxUTmoESm o6HX0Vk+HdXOtaWL
hgokRzG5XoSADkfgRWnNNFbwSTTSJFFGpd3dgqqoGSST0AFUmmroqLUldD6K zLTxHod/cpbWes6d
cXD52xQ3SOzYGTgA5PAJrTpjEyNxXI3AAkZ5GaWolGLqX5YlyFPyn5z15b+l E1zBblRNKiM/3FJ5
b2A6k/SgCWiuavtZu7PxDdw71FvHYJMInXIRizAuxUEkAAAgZ6jtkjY067a6 WZSd6xStGJgCA+CR
3A5GOcDbnoeoESnFTUOrVwSbi5F2iqmoXj2aQ+XEsjyyeWAz7QOCc5wfSsqL XLqZp0ljhgUXSwCR
CzeWCE6/KcsSxwcBegP+1M60IX5mXGnKSujoKKqaZdvfWEVw6gFhkMoIVx/e UMAcH3H5jBMOr6r/
AGbFEsUJuLu4fy4IQcbj6k9gO9Wppx5lsRL3dzRorAF9rELhb6SwRGkWJ2tw zNCWIAzy2CeQMgDI
5PY6mmXb31hFcOoBYZDKCFcf3lDAHB9x+YwTCqxc+TqCTceYt0VmXfiPQ7C5 e2vNZ063uExuimuk
RlyMjIJyOCDWhDNFcQRzQyJLFIodHRgyspGQQR1BFagOJCjLEAZA5OOT0pai nGUQ7YjiReZD057e
/pT3dY0Z3YKiglmY4AHqaAHUVxHijxZf2F/aW1nBNGkybwxVMtzj+LOB04IB GecVY0nxvFdT2ltc
LEXmZYvMjk5LngHZjgE47k89BzglZRjNvR7EzkoO0jr6KKqXmo29mVjaRDcO QI4dwDMScD8M96mU
lFXZaTbsi3RWLbXF/wD2jFHNIzb5H3xAIVVApw3AyBuAAyScEZwcgbVTSqqo roc4OLsxMjcVyNwA
JGeRmlqJRi6l+WJchT8p+c9eW/pSXcwgtZZC6oQp2liOuK0JJqKpiYJftbQs h/dq6rLMdxOWzjgk
8AVYidmLq6hWRsHBJ7A9wPWgCSiq91f2dls+13cEG/O3zZAu7HXGfqKdbXdt eRmS1uIp0B2lonDA
H0yPrQBNRVO/SRwqxyyRswIQoCSWyCBgEdg3U4FSQwRNFETK75AUtvZSx6Hj dxz27UAWKKitSWtI
WYkkopJPfioJ9W022maG41C0ilX7ySTKrDvyCaALlFNjkSWNZI3V0cBlZTkE HoQazdP1Z9QuZYFh
EbLyCzduhOO//wBdfXIANSiq8d0DEjSJIjFQWzEwAPfkjirFABRVK9urhYbh bGNZJoYy7ZUsAQMh
MDkseOB0ByewZyalbu6qVuE3EANLbSIuT0GWUDk8e54rP20OblbK5JWuW6KZ NNFbwSTTSJFFGpd3
dgqqoGSST0AFZ9p4j0O/uUtrPWdOuLh87YobpHZsDJwAcngE1oSadFISFUsx AA5JPaoXmYgLEku9
mUAtC+BkgEngdqAJ6KarEkqw2uvVf6j1FR3N3bWcYkuriKBCdoaVwoJ9Mn6U ATUVXtb+zvd/2S7g
n2Y3eVIG256Zx9DVigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKK ACiiigAooooAKKKK
ACiiigAooooAKKKKACiiigApwXHLHHt3pQAq7j17CmE5OTQA7cvZB+JNG4f3 F/Wm1Q1nUJNK0uW8
itjcyIyKsQJBYs4XsGPfPANNK7sJuyuaO4f3F/WjcP7i/rXK2/ii8nt7mSTT Ps3kjlnExVOM5YGJ
TgcdMnnsORt6ddNcpMD86xSNGswBAfBI7gcjHOBtz0PUCJyUKnspbjj70eZb CT69o9rM0NxqVhFK
pwySXCqw+oJqP/hJtB/6C+mf+Baf/FVxVjbpF4UsrvyTJPOYgWEDS8sRuYhe emT1GTgdTTNDkW9v
ora4iZvNWdlLWTxEbZMDk8bcd+xwCSeqc0pcrLUG48x3H/CTaD/0F9M/8C0/ +Ko/4SbQf+gvpn/g
Wn/xVctplml1resW0iKY7aSNY12j5cpk/Xmrdpa2F5eX1rHbkPZSrFIWAwSU Vxjnphh6c1o42djO
L5ldG9/wk2g/9BfTP/AtP/iqP+Em0H/oL6Z/4Fp/8VWb/Ylt/wA8V/Kj+xLb /niv5Uhm9aajZX6M
9ncW1yinBaGUOAfwNWNw/uL+tcvp9jFY+KYPJQJ51lNvx/FteLGfpub866ag B24f3F/WjcP7i/rT
aKAHbh/cX9aNw/uL+tNooAduH9xf1o3D+4v602igB24f3F/WjcP7i/rTaKAF JBH3QPzridfH/Fp5
v+wUn/osV2tcXr3/ACSaf/sFJ/6LFbUPiMMT/Dfoy5bOv/Ct4Rnn+xV/9EV0 dyM2snyxNxn98fkH
ua4WCaQeAohzj+xF/wDSYV3siCSJkZUbI6OuR+Xepn0NIdR1UtPuIBqWpQPP GsvnKQhcBiPKTnHp
V2isnfoXuUNa1Oyg0+7jN7bpOkMhVGlAYttOABnPer9FFTGFm5Pdjb0sYdt4 Q0Sz8TXHiGGyRdQn
XBb+FWOdzqOzMDgnvj3bN7WjjQtRPpbSf+gmr1IQGBBAIPBB71onZiZx95Ks l1OwZohHEssjgMQc
5HIEiAYC9efwxUul3Akn00bCjG6kDgkklljkXJySe3TJx0zW7/Yekf8AQKsf /AdP8KfBpWnW0yzQ
afaxSr9144VUjt1ArTmhq0jPlkSXsgitjIxwEdGJ+jCs+S7s5Sd5ZsknDQg4 yc91961yAylWAIPB
B71F9ktv+feL/vgVmaFW0uo7i6VI2ZtiOTuGDywPp9a0KZHFHFny40TPXaoG afSAiiG15htiX94e
Iz7D73vUWo2lvd2jLcWv2ny8yRouA4cA4KMSNrejZGM9RVhECF9qooZt2FXH 5+p96dQB5vBaa7pt
t/wjZszqMsNusxkjkBRxIX3CQvt6sj4PPGPcHtNB0+/03TYbe/1A3jrGgyyA FGAwQGAG5emMjd1J
JzgaKRRxtIyRqrSNucgYLHAGT6nAA+gFPpJJNtdSI01F3MbxF4W0jxTbQwar beaIZBJG6ttZeRlc
jnDAYI/kQCNaGGK3gjhhjSKKNQiIihVVQMAADoAKfRTLOF8baNNJrWnaygle GHakwQE7Ar7txA5x
yfpj3rN1/X9Q8YaktlpayGzjcFI42z5hB4aTHQZ9Tx9a9MorKVK7eu5zzoOT dnZMrafaCw021sw2
8W8KRBj32gDP6VmXPhDRLzxNb+IZrJG1CBcBv4WYY2uw7soGAe2fZcblFam6 VlYK4TVPDF7pekaj
Dp1zFFpblrmZOVkKgcoMDBGB7Z6V3dIyq6FHUMrDBBGQRUzgpIUoRk1zHk+j eMYNEhhht45zD5zt
LEUIDLhgpB2cHhOcnvlV52+s1nroOjqwZdJsQwOQRbpx+laFTTjKKs2deInR lZUo8tjD0Twhonh7
UL6902ySGe8bLkdEXj5EH8K5GcDv7BQNyiitDmIlGLqX5YlyFPyn5z15b+lZ +sXMVlPpt1KVXbcM
u4jJwYn4Hc5IHA6nFaYQCV3CoNwGSF5OPU96bPBDcwtDcRRyxN95JFDKe/IN Gj0YHL6fC9nNNeRG
ygubgkyEwu7YyTjJlOOuSBxn161q6Asy20mfJNszboXjiMe7OegyflA2hT6D 0wTP/YOj/wDQJsf/
AAHT/CtCtZyg9UtSIRktL6GD4ntROlhM0V3KkVwd62zPnaUbnavXnbzjjJ9T XJwQRqNWFrZ6pJct
KVRHjmK5Ma/K4PHOf4uxHbFelUVyToqTvc6YVuVWsNRBHGqKWIUADcxY/iTy fxrnfFVtdrPper2k
LznTpi8kKfeZDjOPXp+vtXSUVq1dWOeceZWPLXTTr+8un0cahdajdy7o45MC OAEndu5II5I5GMV6
ZZwtbWVvA7mRoo1Quf4iBjNTUVMYcpFOlyGHrfhDRPEOoWN7qVkk09m2UJ6O vPyOP4lyc4Pf2LA7
lFFWakU4yiHbEcSLzIenPb39KrayrtoeoLEjPIbaQKijJY7TgAdzVyRA4XKo SrBgWXOMenv706lJ
XTQ07O5xlxq2nasFa41G0SJDuiRjCzf7x3hsewGCO/JwI9E8Lac+pW99aM8t rA+8O5Uo79gm0D7p
5z0BAA77e3orjp4SUZJym2l0/pmtSpCa+Bfn+gyRmRMom9iQAucZJOPyrmNe 024sUgRZXvZbx9jK
VG8uQT9NuB3+7j06dVRXTKDcuZMzUrFLSrFrGwijlbzLnYvnSlixdgOeTzj0 q7RRVRioq0dhNuTu
yJRi6l+WJchT8p+c9eW/pSXShoCP4sgIfRicA/rUgQCV3CoNwGSF5OPU96V0 V1KuoZT1BGRVCM/T
/LnQ3HmecwJRSI2ULx1AI6kHr2BwO5NuH/WT/wC+P/QFo+yW3/PvF/3wKkSN Il2xoqDrhRigCrqe
mWur2L2l3HujbkEfeQ9mB7H/AD0qa1tYLG1jtraJYoYxhUXt/n1qaigCpd7o pYpkdgSdhXjGME+n
0/IVFYvMBJMyTu0khzgoFwrEDHI5xjk56D0q+6K6lXUMp6gjIoACqFUAAcAD tStrcBlujJbRIwwy
oAR74qjqOg6dqt1bXF5brJJAcqf7w/ut6jPOP6Eg6VFMAqtPE6FpYsnPLqO/ uP8AD/Js0UAUUtri
aBfNmA3qN6hCCMjkdavUUUWAyL83elW1xLZRNPGwd0jVSzJIcnoOWUsfqCfT 7spsb+cot1ewPCsi
SFYrcoxKsGHJc9wM8dPTrWlRXP8AVafM5M09rK1grD0Twhonh7UL6902ySGe 8bLkdEXj5EH8K5Gc
Dv7BQNyiugzGyIJYnjbOGBU496rTfbIo94mD4IyojOSM896t0UAQwpISJJj8 +MAf3Qf68D/PUurW
C+tZLa5iWWGQYZG7/wCfWpqKAKemaZa6RYpaWke2NeST95z3Ynuf89KuUUUA FFFFABRRRQAUUUUA
FFGKMUAFFLijH0/OgBKKXH0/OjH0/OgBKKXB9vzowfb86AEopdp9vzo2n2/O gBKKXafb86Np9vzF
ACUUu0+35ijafb8xQAlFLtPt+Ypdp9vzFADaKdtPqPzFGw+o/wC+hQA2inbD 6r/30KNh9V/76FAD
aKdsPqv/AH0KNh9V/wC+hQA2nKueT0FGFHVs+wpC2eMYA7CgAZtx9B2HpSUU UAFZfiGYQaR5rSJE
FuLcmST7q/vk5PI4H1rUopNXVgOetNW05ri+aXxPZxkzjHlTQqrDy05Abcfb r2q74eaJtIHkSLJC
J51jdMbWUSuARjjGAOnHpWpRRbW4LQ8xni1J/BuitZwG4gWIedEsZkJJVdp2 D7w+969vqKtrrq6O
0aahArXT743iKOGjhbb8p5wpyCcEZAwOBXfx+H/s6mOz1S+tYMkrDGImVPYb kJx+NZ83gazn1EX8
upX7XIIbdthwSOhK+XgngckdhTpxgp889TNU7VHO5oafpVppcbpZwrGJG3Oc lix9ySTXHanouq6j
a38sujs0Wo6gkstqy20s8caQhAwEpaLJZAe5Cnjnp2n9jXP/AEHtS/74t/8A 41R/Y1z/ANB7Uv8A
vi3/APjVD13NForI47T/AA1qsNlpljLADb3VpDFqm+RWKGHoOD828fISOwHS n6LoeqQ+Op9WuNP+
zLItwk0ka26RSAuvlEbP3jnauSZDwc4ABrrv7Guf+g9qX/fFv/8AGqP7Guf+ g9qX/fFv/wDGqd9b
+v4hbSxGM/8ACU2Wf+fK5/8AQ4K2qoWelra3BuJLq4up9uwSTlflXOSAFVQM kDPGeB6VfpAFFFFA
BRRRQAUUUUAFFFFABXF69/ySaf8A7BSf+ixXaVxWvf8AJJ5/+wUn/osVtQ+I wxP8N+jLFvbKfhzC
+Of7FX/0nrpp5JPMit4QPNlJwxGQgHViPy/EgcZrmLe6QfDmFcjP9iL/AOk9 dQpxq8H/AFwl/wDQ
o6mfQ0h1F+w2a3CW8txdSXEiNICZ3XcFIBOFIUY3L2H86jtk0a8kaO1vvPdR krFfuxA47B/cfnVX
WHsl1qwN9dfZovs8+H+0tBlt0XG4EZ78e3tXOeBjZf2zKLa/luHW3I2seMbY Rn/WvjgL2HJI/hAH
NUm4yil1N4QUoyb6Hbf2Vaetz/4FS/8AxVH9lWnrc/8AgVL/APFVznjq6WGL RFmm1GO2l1IJONPa
cSuvkynA8n5yMhTgelZreKtQ8L+E7Wa5tJr2YmeSOC5eb7V9lViUZgsUh3BC gJfaASNzAmtUQ1t/
Xf8AyO1/sq09bn/wKl/+Ko/sq09bn/wKl/8AiqzLbXrvUdWnt7CxiaytWWO5 uJrko6uyB8IgRt2A
y5JZepxnFc54V8Y3E3gWG/2x3CWttHE9zdXL757o7cptVHc/eABwWZjgKeDR 3EtTtv7KtPW5/wDA
qX/4qj+yrT1uf/AqX/4quasPGl7qltZCy0UG9mNwZoZ7hoVjSFwjEFowxJLL hWRepztxVJfiPLMN
MFroVzO9zZw3lwkYmkMKSEgKpjiYFvlb75jHA564dv6/r0Dpc7L+yrT1uf8A wKl/+Ko/sq09bn/w
Kl/+KrlfF8k0nifQ7VYNXuoJLe6d7fTL82rMVMOGY+bHkDceM9+lT33jGXTZ tUs/7M3zaXaSXkgN
zw0AQmNt20kszBlI7bWJJ+Xcul/60HZ9Do/7KtPW5/8AAqX/AOKo/sq09bn/ AMCpf/iqzNH167v9
Rlsr/Tks5Rbx3UQS5Eu6NyRhvlG1gV5A3DnhjV3Wobe50mWK6ZVi3I3zJvDM HBVSnVgWAG0cnOBy
aLEp3C40SKUDybu8gYZ+7cOwJ7ZBOcfQiqclmbM5u2neL/ntFPNgf7y7jtHX nJHHOKp31lZ3Gmm3
uAoQKi3Nq0qSrpaupJZQBweyschAcjCAg9PuoGZgsICARJckH/p5k/8AiqP7 Ph/v3P8A4Eyf/FUs
if2cS6D/AEM8so/5Y+4/2f5fTpZBBAIOQaAMPVrvTtHEX2hrxnlzsRLl8kDG Ty4HGR781egtrS6t
4riGa4eKVA6MLmXlSMg/eqn4msIL3TozLAksiTxLHuYp96RVI3DkAg4P/wBY VR0y714eIfsk9l5N
im5SqIPJjQD5CjYGT93j3PAxUttPXYzcnGWuzN7+z4f79z/4Eyf/ABVH9nw/ 37n/AMCZP/iqyfGl
3cWPhp7i1M3nLdWoCwOFdwZ4wVBJA5BI5IHPPFYWt+Ir1NTV7nSdVsbaHSb6 d4JbqOPzygiIw0Mj
lSOfm4I3cd6pf191zVK52f8AZ8P9+5/8CZP/AIqj+z4f79z/AOBMn/xVc4nj KSTxGNKt9IuZbeN4
4ZrkJM2x2QP1ERTaAy5LSKepweM07jx9eW/hiz1l9IgLXUTXCWiXMskvkhQS 2EgbHJx82FGVywzg
Alqdf/Z8P9+5/wDAmT/4qj+z4f79z/4Eyf8AxVYE3i+aK41Pbpga3s5YbeN/ tGHmmmEZRdu3CjMm
CxbjHAOeK+o6l4hh8Q6Mi2Fu11La3Ze0j1BvIO1odrM5jBJAJA+Q4LemSD+v wuC1Olk02J4yqz3c
ZP8AEty+R+ZIqOC1jcvHI1wJYyA2LmQBgRww+bof5gjnGaxbXxmLvT1uEsCs 1xb209pC82PO847d
uccFWyDjOBg98V0Ef/IVuP8ArhF/6FJTasBTuHsbe5Nux1F5QgcrD9olwpJA J2Zxnafyot3sbi5F
up1FJShcLN9oiyoIBI34zjcPzq1caZb3FybhmuElKBC0NzJFlQSQDsYZxuP5 0W+mW9vci4Vrh5Qh
QNNcyS4UkEgb2OM7R+VICG7SysljMz3pMj7EWOSeRmbBOAFJPRSfwqD7Tp4Z A41WMO6oGkjukXcx
AAJIAGSQOafrf2HztK/tL7P9k+1nzPtO3y/9TLjO7jrj8ap6j/wivkwf2b/Y 32v7XbeX9m8rzP8A
XJnG3npn8KANeN5ba4S3ldpUkB8uRgAcgcqcYHuPofTJhluGuJnQSPHDG2w7 DhpCOvPYduOc55GO
Z7r/AI+bH/ruf/Rb1y+s63Doen3d7OHZIpX+VOrM0pCgfUkD8aqKT3E77Idc eMfCFtF5kniK0K7l
XEepM5ySAOFcnGTyew5PArUsb3StTgabT74XcStsL2988ihsA4yHPOCPzrwT RLc3N/Z6bqUSiA2r
wxgOzBn8vbnoMfJ5n5+uDXc/Dc3FpDrUN2f36XoRm4+bESANx0yMHHbNTCtQ qVXSpyu0k9u97/c1
YK0J0ZunUTTXc9L8uD+9P/4Ey/8AxVHlwf3p/wDwJl/+KrjL681PSrjU9Yku zPYQWzyR2m4AkqpO
M7eAckeowMls4WrceNNTt1uy+ixA2tst5IPtv/LA7unyf6z5W+X7v+1W/IjP mZ3vlwf3p/8AwJl/
+Ko8uD+9P/4Ey/8AxVcNL4qkt76eGzsWnmlvktl827YKS1uJA3IOwDGCFHqe TwXw+Lby7jt4rbTU
a9dpxNE9ztSMRPsbD7TuJJGOBnuRScUkHMztvLg/vT/+BMv/AMVR5cH96f8A 8CZf/iq8003xlf2n
h+0zZNem30qK+uZ5braxU7twGQdz/JkZIB5yRxnWPi+5hW+S7soIJ4IYp4V+ 0s6yrIzKoJWMsHyu
Nqq3JGM03BIG2v6/rudr5cH96f8A8CZf/iqPLg/vT/8AgTL/APFVwlt40vb5 LKO10lTdXIuNyTXD
RLGYnVTktHuwc8ZUHpkDkjQPifd4dg1SG2Z5LgRrHAXA+d2CgFuQBk8nnjse lHIhczOr8uD+9P8A
+BMv/wAVR5cH96f/AMCZf/iq4U+Mb9ZTatpMf2wXq2exbvKZMPm792zO3t0z jnGeKIPGOoTNAG0q
GNZppbRWN4TidA+QQE+4ShAbr/s0uVWuPmf9f15HdeXB/en/APAmX/4qjy4P 70//AIEy/wDxVec+
HNe1OLQtLT7N9sv76JruVpr9yuwbckFlO0ksMIAFHPIq7ZeNZr0RSCyhggOn pfTSzXW0RBt+F4Q5
5Tk8cEntgvkX9f15Bdnc+XB/en/8CZf/AIqjy4P70/8A4Ey//FVwNv45u7iC MLpOLt70WgiaV415
iMgfMkatjjB+T1IzxmKTxLqlzq+mm1tAZxFeRTWhu9sO+N4xkuFOR1wdufm6 DnC5UHM/6/ryPQ/L
g/vT/wDgTL/8VR5cH96f/wACZf8A4qsHS9ZTVNKtL9FZFuIllCMeVyM4qeyt 7Oa5v552W2j+V5NR
DKjQvhVEZZgQysMHaQcHnqy4cocu4Rk3oXhavGcpdzzD+7NPID/30pGP++TV q2itbnIDXaSKPmja
4kBH/j3I9xxWM0cVjq14q2q2j/Knlr1dFLbZGbq7Nkkt+B5UmpPtRDK6ttdT lWHb/Eeo/wDrGp9n
dXQ+ezszd/s+H+/c/wDgTJ/8VR/Z8P8Afuf/AAJk/wDiqSxvkvIz0WVfvpn9 R6irdZGhV/s+H+/c
/wDgTJ/8VR/Z8P8Afuf/AAJk/wDiqtUUAVf7Ph/v3P8A4Eyf/FUf2fD/AH7n /wACZP8A4qrVFAFX
+z4f79z/AOBMn/xVH9nw/wB+5/8AAmT/AOKq1RQBV/s+H+/c/wDgTJ/8VR/Z 8P8Afuf/AAJk/wDi
qtUUAVf7Ph/v3P8A4Eyf/FUf2fD/AH7n/wACZP8A4qrVFAFX+z4f79z/AOBM n/xVH9nw/wB+5/8A
AmT/AOKq1RQBV/s+H+/c/wDgTJ/8VR/Z8P8Afuf/AAJk/wDiqtUUAVf7Ph/v 3P8A4Eyf/FUf2fD/
AH7n/wACZP8A4qrVFAFX+z4f79z/AOBMn/xVH9nw/wB+5/8AAmT/AOKq1RQB V/s+H+/c/wDgTJ/8
VR/Z8P8Afuf/AAJk/wDiqtUUAVf7Ph/v3P8A4Eyf/FUf2fD/AH7n/wACZP8A 4qrVFAFX+z4f79z/
AOBMn/xVH9nw/wB+5/8AAmT/AOKq1RQBV/s+H+/c/wDgTJ/8VR/Z8P8Afuf/ AAJk/wDiqtUUAVf7
Ph/v3P8A4Eyf/FUf2fD/AH7n/wACZP8A4qrVFAFX+z4f79z/AOBMn/xVH9nw /wB+5/8AAmT/AOKq
1RQBV/s+H+/c/wDgTJ/8VR/Z8P8Afuf/AAJk/wDiqtUUAVf7Ph/v3P8A4Eyf /FUf2fD/AH7n/wAC
ZP8A4qrVFAFX+z4f79z/AOBMn/xVH9nw/wB+5/8AAmT/AOKq1RQBV/s+H+/c /wDgTJ/8VR/Z8P8A
fuf/AAJk/wDiqtUUAVf7Ph/v3P8A4Eyf/FUf2fD/AH7n/wACZP8A4qrVFAFX +z4f79z/AOBMn/xV
H9nw/wB+5/8AAmT/AOKq1RQBjyTWEdxLB/xM5HiYK/krcyBSQGxlcjOCD+NS Wv2G8lkija/WSNVZ
kmaeIgNnBw+Mj5T+VTSaTbSXEs++6jeVgz+TdyxhiAFzhWAzgAfhUlrp8FnL JLGZmkkVVZ5p3lJC
5wMuTgfMfzoAq3X2Gzljika/aSRWZUhaeUkLjJwmcD5h+dRpNYyTxwBtUhll JWNpUuEBYAt1cbc4
BOD6Ump/2V/bth/a/wBi+z/Zrjb9r27N26HGN3GcZ/WoZf8AhHP7V0n+yP7K +0faW3fZPL37fJlz
nbzjOP0oA1YJZEuGtZjvYLvSTGN65xz7jvj1HTOKr3NyF086jcC5a2MiRxW9 uwV5CzhFJYkcEsCM
MBjnJzirEn/IVt/+uEv/AKFHVS8W0k8H2yXs88EOy3PmQJucOGQptG1skttG MHrVQSckmTNtRbQ+
wksb25nt5LXULOWFEci4vD8wcsBgpIw/gatFdNsnGVe4Yeou5D/7NXF3Vmst vcjSrWTXL0mIywax
ZqojQLNsZVcRDlyVJySATwcYrsdLs4tPhmhg0+zsYjKWRLTAVxgAMwCrhjjk c9Bya0qwjHYypTlL
ck/sq09bn/wKl/8AiqP7KtPW5/8AAqX/AOKri5/tF3oWt+JH1W9gv7OW6+zo l06QQCBmVVaIEI+7
bklgSd/BAC415fF7Q2+oyNYHdZXdralTLjcZhFz042+b05zt6jPGK1/rudDW v3/gbv8AZVp63P8A
4FS//FUf2Vaetz/4FS//ABVcNZa5r16dMbUmjhz4huLb/RrljvjVbgbGwicK VXB5zgE4NSQ+OrqH
R4prHRPOt7fSItTnM+osXWM78qGZGMjgJkFiM85I4yL+vuuDTvb+t7fmdr/Z Vp63P/gVL/8AFUf2
Vaetz/4FS/8AxVc4PGzy+KjpNrpNzPbRypDNdLHMdjOgcH5YjHtAZclpFI54 PGej1GOC40y7guZP
Kt5IXSWTcF2qVIJyeBgetHS4iOfRreVAqXF7Cc53R3Lkn2+YkVSfTprQAzNP cRcAvDNMGX/gG45H
uD36d6qfZoP7N8vyI/N2eb/ZW0eVt37fP8j7+MfP5eevGN/zVuadHBb6ZaQW 0nm28cKJFJuDblCg
A5HByPSgCnHZ20sayRy3DIwyCLqTBH/fVO/s+H+/c/8AgTJ/8VUk8LW0jXFu paNjmWFeue7KPX1H
f69ZI5EljWSNgyMMgjoRQBX/ALPh/v3P/gTJ/wDFUf2fD/fuf/AmT/4qrVFA FX+z4f79z/4Eyf8A
xVH9nw/37n/wJk/+Kq1RQBV/s+H+/c/+BMn/AMVR/Z8P9+5/8CZP/iqtUUAY 32nTyzhBqsgR2QtH
HdOu5SQQCAQcEEcVPaJZXqyGF70GN9jrJJPGytgHBDEHowP40/8Ase1DOUkv Yw7s5WO9mRdzEkkA
OAMkk8VPaWUNksgh8wmR97tJK0jM2AMksSeigfhQBRuHsbe5Nux1F5QgcrD9 olwpJAJ2Zxnafyog
ks7i4EEMupQTlDIvnLMmQCASBINp+8PXrUM/9h/8JHdf2z/Z3/HpB5X2zZ/f mzt3fhnHtRB/Yf8A
wkdr/Y39nf8AHpP5v2PZ/fhxu2/jjPvQBqWszu0kMwHmxEAkDAcHow/z1BHO K5LXv+STz/8AYKT/
ANFiurj/AOQrcf8AXCL/ANCkrk9e/wCSUz/9gpP/AEWK2ofEc+J/hv0ZBDbO fh/C3b+w1/8ASeu1
Jxq1v/1wl/8AQo65+2Cn4bQ/9gVf/RFb0n/IVt/+uEv/AKFHUz6GsOpYaBGv Yrolt8cbxgdsMVJ/
9AH61UsNF0/TZzNaxSI5XZlpncAYUcBiQOEUfRRV2isnFN3aNE2tER3VlbXk trJcR73tZfOhO4ja
+1lzx14Zhz61S1fw9peulDqEEkhWN4v3c8kW5GxuRtjDcpwODkcVo0UxFD+w dOGqLqKJPFchVU+V
cyxpIFGBvRWCuQDjLAnp6Cqv/CIaELUWyWkkcSxRxARXMqYEZBQ5DA71IGH+ 8OmcVs0UActrHhVF
0+2t9G0y3keF5XWS41O4gZGk5YlkDNIGPLKxAOBnPazY+DNMttP0uGU3BubC 0S1FzbXMts0irjhv
LcZXOSFOQMn1NdBRQtAKGqaFp+sT2892LpZrdXWKS2vJrdlDY3DMbKSDtXr6 Vnav4SsrvR9Rhs49
t9cW86JPNPIxLyxhDvYkllwqcHIG0YHAroKKLdBptNMz9G0Oy0VHNsknnSqi ySSTySkhc4UFySqj
JwowBk4FXru2hvbcwThjGWVvlcoQVIYEFSCCCAeKdRTbuSlZWKk+kWFzaLbS RN5YVl+WV1Zg33gz
AgsGPJyTk8nJq/uqOikMk3VQMMtmSbZfMgz/AKgYBX/dJOMex98HoKt0UAZd 9JHqNstrFcfZ52li
cCRdjgK6sSAw5OFOOCM1m2Hh3ULXxK2oS6gJYMsSxH7yUEYCtgAYHHT+6OBX SSRxzRmOVFdD1Vhk
H8Kr/wBmWH/Plbf9+l/wpNJ7kygpNN9B17Y22o232e7j8yLekm3cR8yMGU8e jKD+FQaho2n6q269
t/NPkS2332X93JgOvBHXaOeoxxipf7MsP+fK2/79L/hTPsWmeZ5f2Wz8z+75 a5/KmWm0Vz4c0z+0
xqKR3ENzhNxhu5Y0k2jC70Vgr4HHzA8YFQXHg/Q7qytbOS0kFvawG3jSO5lT 90cZRirAupwOGyOK
0v7MsP8Anytv+/S/4VE1ppy3UdubGDe8bSA+SuMKVB/9CH60C2GPoGmSW99A 9qGjvipuAXb5iqqq
kHPykBVwRggjPXmltdDsbSW3lRbiSW3SRIpLi6lmcK5UsNzsSc7V69McYqf+ zLD/AJ8rb/v0v+FH
9mWH/Plbf9+l/wAKAMiDw3HHrGmutrbw6fpEDR2QWVnkJYAHduHAUA45bOc8 Y514/wDkK3H/AFwi
/wDQpKP7MsP+fK2/79L/AIU17DTo0Z3tLVUUEszRqAB6nii/cOpcoqhb2mmX UIlisoCpJX5oApBB
IIIIyOQal/syw/58rb/v0v8AhSTTV0DVtGWqKz7qDR7KMSXcVhBGTtDSqign 0ye/BqtHc+GpZEjj
n0l5HIVVV4yWJ6AD1pgX7r/j5sf+u5/9FvXDeIbGLVor2wnLCJ5X5U4KkSFg R9CAfTiuzls7a3u7
J4beGNjMQSiAHHlv6VzrW6T397uLDbO+Mf7xrWlZt3M6jaSa3OBtvBM0dxHc Ta1L5sJzE1vAqbTg
g53F88H2/HtuaVo50y8ubpr+5uprhURmmCDAUsRgKo/vGt1oIxGkm24WOTGx 3iZVbPTBIxzUbxKv
QmnRpYa/PSSuupOIq1qs+es7vuytcxJeWk1rcDfDMhjkXOMqRgjI56VBNptp P9o82Ld9otxbS/MR
ujG75evH3m5HPNb+j6ZDqBn81pF8vbjYQOufb2rU/wCEbs/+es//AH0P8K2l UgnZmcYSaujihpdm
LgTiH96JhOG3n74Tywev93jHT8ail0PT5ggaF1KSSSho5nQ5c5cZUgkE9V6d OOK7r/hG7P8A56z/
APfQ/wAKP+Ebs/8AnrP/AN9D/Cl7WDH7OZw0eiadFavbJb4he1Fmy725hGcL 1/2jz1560+50myvC
7TRMWdI4yyyMrAIxZMEEEEEk5HNdt/wjdn/z1n/76H+FH/CN2f8Az1n/AO+h /hR7WAezmecTeGbd
72y8vzI7SBJ9wS5kWQvIyHIcHdztbPPfvVq80e2ayljgsoZHaCOBY2maJdiE lAGUErgkkEDOcV3v
/CN2f/PWf/vof4Uf8I3Z/wDPWf8A76H+FL2sLWHyTPOtF0L7IrzXiobhrv7U ipM8gjYJ5Y+dsM52
5ySOp9hWium2i+Xtix5dw9ynzHiRt25uvfe3HTmu0/4Ruz/56z/99D/Cj/hG 7P8A56z/APfQ/wAK
ftYbC9nM851TRmaxs7bTrKBvsqGOIy3ksJjXAGMoCXU4GVJwcCrFloNna6Yl nIgm/wBDSzlY5G9F
B7Z45ZjxzzXff8I3Z/8APWf/AL6H+FH/AAjdn/z1n/76H+FL2sNfMfJM84u/ DVu4tUt/MWNbsXE7
PcymR8RsgIfJbdyvOR0rTt9MtLRrdoYirW6ukbF2Jw5BfJJ+YkgEk5P512n/ AAjdn/z1n/76H+FH
/CN2f/PWf/vof4U/awE6czkrSCOxtIbW2XZBCgRFyTgDoMnmnBcSM4Z/mbeV Lkruxt3bc4BxxnGc
V1f/AAjdn/z1n/76H+FH/CN2f/PWf/vof4UOrB7h7OZyka+W5ZWcnaqDc5YK ozhQCeAMnAHFSeY/
96un/wCEbs/+es//AH0P8KP+Ebs/+es//fQ/woVWCD2UznILqa3lWSNyGXof 89q6Kz8Q28iBbr91
J3YKSp/nj8fzpf8AhG7P/nrP/wB9D/Cj/hG7P/nrP/30P8KznKnIuKnE1YpY 50DxSJIh/iRgRT6x
T4YsScl5ifqv+FH/AAi9h/em/Nf8KytHuaXfY2qKxf8AhF7D+9N+a/4Uf8Iv Yf3pvzX/AAosu4Xf
Y2qKxf8AhF7D+9N+a/4Uf8IvYf3pvzX/AAosu4XfY2qKxf8AhF7D+9N+a/4U f8IvYf3pvzX/AAos
u4XfY2qKxf8AhF7D+9N+a/4Uf8IvYf3pvzX/AAosu4XfY2qKxf8AhF7D+9N+ a/4Uf8IvYf3pvzX/
AAosu4XfY2qKxf8AhF7D+9N+a/4Uf8IvYf3pvzX/AAosu4XfY2qKxf8AhF7D +9N+a/4Uf8IvYf3p
vzX/AAosu4XfY2qKxf8AhF7D+9N+a/4Uf8IvYf3pvzX/AAosu4XfY2qKxf8A hF7D+9N+a/4Uf8Iv
Yf3pvzX/AAosu4XfY2qKxf8AhF7D+9N+a/4Uf8IvYf3pvzX/AAosu4XfY2qK xf8AhF7D+9N+a/4U
f8IvYf3pvzX/AAosu4XfY2qKxf8AhF7D+9N+a/4Uf8IvYf3pvzX/AAosu4Xf Y2qKxf8AhF7D+9N+
a/4Uf8IvYf3pvzX/AAosu4XfY2qKxf8AhF7D+9N+a/4Uf8IvYf3pvzX/AAos u4XfY2qKxf8AhF7D
+9N+a/4Uf8IvYf3pvzX/AAosu4XfY2qKxf8AhF7D+9N+a/4Uf8IvYf3pvzX/ AAosu4XfY2qKxf8A
hF7D+9N+a/4Uf8IvYf3pvzX/AAosu4XfY2qKxf8AhF7D+9N+a/4Uf8IvYf3p vzX/AAosu4XfY2qK
xf8AhF7D+9N+a/4Uf8IvYf3pvzX/AAosu4XfY2qKxf8AhF7D+9N+a/4Uf8Iv Yf3pvzX/AAosu4Xf
u4XfY0JP+Qrb/wDXCX/0KOqr2T6l4YtbaKcQSbLeRZCm8AoyuOMjP3cdapaZ aR2XiSeCLO1YDgnG
f4D/AFrd0eJX0i0JJ/1KDj/dFGsJXQaSjZmRb+HZHmuJdTv3uDKsSr9m8y2K 7N/UrISc+YeM44Fa
1jZQadA0NuZihbcfOneU5wB1ck446dKv/Z09WpskKRxs5LEKCetOVSUt2KNO MNkYdz4Y0e7v2vJr
Z2d3WSSMTyCGV1xhniDbHYYXllJ+VfQYS+8L6PqOoG9ureVpi0bsFuZUjdoy CjNGrBWYEDkjPAHS
k1zxHpfhx7dNUvWhe5DmJY7WWYkLt3fcBxjcvXHWsSy+Jvhi+1B7NNQnjbzU ijklsJVSQsdoIOPl
G7Kkvt5U9ualRejSLN+Lw7pUNz56QSb/ALUbwAzyFVmIYFlUttXIdsgAAk5I zSR+GdGis5bRLPEE
tktg6+a/MA3YTOc/xtz1561q+TJ/z1X/AL4/+vUc7JbR+ZcXcMUe5V3SDaMk gAZJ6kkAe5peQ7v+
vv8AzM//AIR3TBqg1KOO4hufk3GC7ljSTaMLvRWCvgcfMDwAK0riGK6tpbeZ d0UqFHXJGVIwRx7U
7yZP+eq/98f/AF6ry3NvDewWcuoW0d1OGMMDEB5AvUqu7Jx3xQIZ/Zlp9n8n bJjf5nmec/m7sY3e
ZnfnHy5z046cVZt4YrW2it4V2xRIERck4UDAHPtTvJk/56r/AN8f/Xo8mT/n qv8A3x/9egB26qUs
EsMjzWm0hjueAjhj3Kn+En8ifTk1b8mT/nqv/fH/ANeo1KvM8K3ULSxgF0Ay yg5wSM8ZwfyNAFdd
Qt9wSUtBITgLMNmT6AnhvwJq1Stbs6FHdGVhggpkEfnVb+xrP/n2tP8AwHH+ NAFiiq/9jWf/AD7W
n/gOP8aP7Gs/+fa0/wDAcf40AWKKr/2NZ/8APtaf+A4/xqN9N06OSON47BXl JEatCoLkDJAGeeAT
+FAFyiq/9jWf/Ptaf+A4/wAaP7Gs/wDn2tP/AAHH+NAFiiq/9jWf/Ptaf+A4 /wAaP7Hs/wDn2tP/
AAHH+NADY/8AkK3H/XCL/wBCkrk9e/5JTP8A9gpP/RYrpbBbX7ZK9l5Bgkt4 ZEeADY4JfDDHBBGO
a5rXv+SUz/8AYKT/ANFitqHxGGJ/hv0ZDb3pX4fxJ/1BF/8ASYGuyk/5Ctv/ ANcJf/Qo65OKyDfD
uF/+oIv/AKT4rrJP+Qrb/wDXCX/0KOon0NIdS1RRRUFhRRRQAUUUUAFFFFAB RRRQAUUUUAFVpAty
kyO20YKKpGcH+8R+oH4+mLNV7q1W5jZc7WK7ScZyPQjvQANJJHtZpI3BYLgI QeTjrk+tWKjS3gRg
yQxqw6EKAakoAqEvc2v/AB8RoJU6eWSVyPXdzU25EmWOI5Rs4Ufwf/W/lx68 Mms4Jo5FMUYZwRu2
AnJ70+CBYV65Y/eb1/8ArUgJayWvE8m3tA4854xJh5CB65wDycg9Pr9daqN1 pkU0f7vKOrbl+Y7c
4I6fQmmA2wuorlwYGYrhg4MhcBht6H8e3r+T5P8AkOWv/XtN/wChxUmm2T2c ex9h2gKrBmY49Ofw
6elPkRjrFs4U7BbyqWxwCWjwP0P5GgB9/wD8g66/65P/ACNc+0uiwMw1DWrK xlMkm2GVrdDsDsoI
DLnHy9fY10s0SzQyRMSFdSpx1wRVS0W9s4WhFvbTr5ruHecqSGYnkBCM81pC SS1M5xb2INIkgZ5E
s79LyzMayRSIUZcl5A2CgwRlfwq1fRTMIpYlEphbeYCcB/TB/vDqM8Z9DhlW BJ2vZriaKGIPGiBY
5C/3SxycqP736VYdBIjISQGBB2sQfwI5FZVYqaaNINxscvJFdixm1HzJYUed 9tusdwHO6UgHb5y8
nIOMDr0ro7OaK4s4pYZ/PjZRiXjLe5wAM+vArEn8PfY0S5si888UsbCPyLdd wDjdg7Fwduccjmti
zt5IvMlncGeYhnCfdXAwAPXj+I8n2GAOLDQnCfK42Vu/9fcdFVxlG9yaeCO5 haKVdyHHQkEEHIII
5BBwQRyCMioY7adpklvbn7S8XEPyBAvGNxA4LkcFuBjIAXJzaoruOcq3X/Hz Y/8AXc/+i3rnI/8A
j+v/APru3/oTV0d1/wAfNj/13P8A6Leucj/4/r//AK7t/wChNWlLdmdTZFu0 3XunWFpiN0ktUYiU
MwAVFBwA45+cccdc9uc+7sbu0jd5bdlhVtvmb1IwTgcbiecj1+p606HzdPeN rXLpGjRrHLM2FB29
Cc4xtHFJe6ld3lsbeWGONGZSWWUseCD02j0ritiKdb3I6aLyOh+ynT959zF1 OWZI7COJNQlWbUY0
kg0+5MEsq+TMdoYOncA43DpVyDxXd6JoOlQR21xqt1erPPCr+fI8cCv8qyMk UjmRQ6Kcr1By2euv
oVjbXkxknj3vaypNCdxG19rrnjrwzDn1q9ceFNHuTua3mjcTPOslvdSwurv9 /ayMCobqVBAJ5Izz
XbV+N/10/r+mY07cq/rq/wCv+GM2Txobea/e7sBa21paG6CTysl1MojVzsiK AMBnaSH4IwQKdJ4r
vrFJE1PSIYblfszIkF4ZUZJpRFksUUhlJyRjB4wfTU/4RrS2uXuJo7i5Z4jC UuruWaPYVCkBHYqC
QMEgZOTk8nMcPhTR4bG5sxbzSRXKqsjTXUskm1eVAkZiyhTyACMEkjBrPqV0 /ry/4JSvvFdxBqMt
haaak866ilgnmXPlqxa387eTsOAOmMH19qf/AMJRMLLUtVawjGj2Kz5mFwTP I0RIYCLZjG5WAJfP
HQZq5aeF9IsnWSG3lMi3IuvMluZJHMoj8vcWZiSdhxzTx4c0sXd1cCCT/Sww nhNxIYJNwwxMO7y8
nuduTz60Pb+uy/W49Lr+u/8AwCt4c128161uTcabLp8sZAQvHMFYEcEebFGS QeoAI6cnPHPWusnw
pp91/akWqS62kcXmRS3Uk8V27SCMSQ/e2qXblVUEAj5D8uev0zRbLSLd4LU3 TROANlxdyzgADAC+
YzbRjsMVTTwhoi29zA9tNOtyixyNc3UszhVOVCs7FkAPI2kYOD1FD30EttTE sfE+val4j0eAaZHa
Ws0Vz9oineWMsUaP51EkCuQA4xkLklgcbQT29ZEXhrTYpLSUfbXltHZ4ZZb+ eRxuxuBZnJZTtHyk
leOla9PoAUUUUgCiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKK KACiiigAooooAKKK
KACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoooo AKKKKACiiigAoooo
AKKKKAMW3/5G26/64f8AxFbOif8AIGtP+uSf+gisa3/5G26/64f/ABFbOif8 ga0/65J/6CKqW/3E
x2NCorn/AI9Zf9w/yqWmyJ5kbIeAwIqSjwn4o6xcap4s/s+1SOMaUjRM8gLe Y0ojkOACMABVH5+1
c39kEmg6FqkICC2ljivCeAVSYb3OB2dWbJ7MxPJr2LxB8M9O8Q6o+oyT3Npc SKFla1lVRLgYBYMj
c4AHHYDOcCqn/CoNBFs1sDfiBs5iGpS7Tnrx05ya5qkcRKcWp2UXdLyas18z XEewlSp+yTU1u+jO
i8S6jPYeFtWvLWTy7i3s5pYn2g7WVCQcHg8iuGutan1HTrqIa0NXtVl06R5l jjVYJzdLuiGwDoAD
tbLL3JzXoF7oC32jXGlv8lvPbtbnZJ8yqV28EqeceuatR6fJFEka7cKoUZf0 /CulaO/oZvZf12PK
9a8RajrE3iPToNTk+xvp98PsweJ5oXiwMFBCDGG+YAM7kqcjaauWlxdW2qan q2l6xcavLF4eiktw
VhdJmDTYX92gJAZeikEkkHPGPS/scvon/fZ/wo+xy+if99n/AAo2Vv66/wCY X/r5p/oect4k1D+z
rv8AsrxMdUhBsgL/AMqFvJkknVHj+RQh+U52kblzyeRUt/qmv20+qvDr0pj0 +/s7SOOS2hPmCVYQ
7OQoycyFht24Oc5GAPQfscvon/fZ/wAKPscvon/fZ/wp/wBfkJHHadrF3a6x cafqGvSSLaX5jR5r
dN9zGbUS7GKKqrtJLbgBkKB3qOa41FbXSpre7ksLjW9TLTyJEjOsRhkKLhww DBUjHTqD64rspdOM
8TxSxxSRupV0dshgeoIxyKd9il9E/wC+z/hS/wCB/XzA81i8Ua7Nq+sRya9p Fi8P2qNLS8vERoQm
fLl8sw7gMBWLGR1IYnb0AmXxW81npnm+JrnT9Pl+0iXVpjaN5kqFQsayBPJK nLkEKGOzHBBFei/Y
5fRP++z/AIUfY5fRP++z/hQHU86vfGuoadpd1LqV9FZXMugrcWaSRqhkuR5m 4orck48slDnGenWr
Nxr2sxrr94uouIbOW3hVPIQpBG8cLSTH5dzFAzsBnHXIIxjvPscvon/fZ/wo +xy+if8AfZ/wo/r8
f6Q/6/L/AC/E851/xLeWtrpUek+KraWyuPPL6xc3dvEhkXbtj8xYHjHVjjYC dv3uDnXl1K+ntNS1
u2SG6udP04xWohBkSWcoJJCmOWUny1HQ/KfWuv8Ascvon/fZ/wAKZHpphUrF HEilixCtgZJyT93q
SSfxo6B1R543iTUP7Ou/7K8THVIQbIC/8qFvJkknVHj+RQh+U52kblzyeRTt Y8SX+nalPa/8JG8d
3b3dnbw2UkERa5hdog8x+TJJLONy4UYxjNeifY5fRP8Avs/4VkX3hWXUtQhn udRumtYpUmWxDxiE
unKkkR7zhgGxuxkDjHFNPVev9f1/w4uhzXi/xZdpLYR6TqltYWkj3EU17czL bos0RC+XvkhkUc7z
jaN23huObdhr8t34hNtqOvw2cqrF9msYGi2XytEGMil1Luu4uBsIwE5rsfsc von/AH2f8KPscvon
/fZ/wqbaWBnN+DP+Re0n/sD2X/oDVm69/wAkpn/7BSf+ixXWRqV1W4U9RBEP /HpK5PXv+SUz/wDY
KT/0WK3o/GY4t3hJ+poW3/JNYf8AsCr/AOiK3JF36rboGK7oJRuXGR80fIzW Jbf8k0h/7Aq/+iK3
f+Yza/8AXKT/ANCjqJ9C4dSf+zH/AOgjd/lF/wDEUf2Y/wD0Ebv8ov8A4itC ioLM/wDsx/8AoI3f
5Rf/ABFQRwJLIETU735vukxIFb6Ex4PHPHbmn6/ZQXmmjzwp8mVJVDDIJDfd x0+YErzwN2e1YZ1Y
3NvZ31paWNzBKqypJNKUOeGGB5ZPQqwJweegIrJzk6ipwV2yrJRc5bGtHC8m rXFj9tux5MEU2/8A
dc72kGMbO3l/r7Va/sx/+gjd/lF/8RWH4UMqX9xF5BaOOCOHzvtIkESpny4v 9WmeHY5+ZsY3Hlc0
fFuvXdhrVxb/ANuHSVisVnsIxFG39oTlnBjw6kvjbGNkeG/edeRjoqR5JcpF N80b/wBbnVf2Y/8A
0Ebv8ov/AIij+zH/AOgjd/lF/wDEVx97rWtRf8JFdyam9rDZz21vsEEbJaJI kDSyk7SSU3uRk7Ry
SCBxc8MeJlluNSgn1r+1Ivt6Wmn3HlqPOzbrLjMahT0c7sAHt2FR/X5f5jOk /sx/+gjd/lF/8RVe
6S2sv+PvXHt/3bS/vXhT5FxublegyMntkVwGj+L/ABBNo99e3Or6c84jja4t knSWfTcyhZXaEQoy
LGpYkO0nKjkjObmtaoLf7NqWl6//AGs8Gi6rLDf7oZPnXySP9WoQ4I6Y+tH9 fgUleXKd2unMyhl1
K6IIyCBFz/45R/Zj/wDQRu/yi/8AiK4W48T6iPEF7br4gVLmG8tIrTShDFm6 WSOEyZyN5A3s2VI2
8k5GAGXnivU7a08RC11dL69tZFJeGWCS1s4mn2EkpGZEdEyWEgcDaSNwBFD/ AK/r5krVfd+J3v8A
Zj/9BG7/ACi/+Io/sx/+gjd/lF/8RXLad4nuo/CdyTqlhq2reRczWbWcwu1k EYU4Zo441LAuo2hV
JBHU5NYx8U6iRfx6T4qXVYkh08w3jW8LBXmuTHIDsVVb5cDHUdM55p21sHS/ 9dj0L+zH/wCgjd/l
F/8AEVXgjtrm6uLW31x5bi2IE8Ubws8RIyAwC5XI55rk59Q1+wm1Fm1+4uI9 L1S0tQklvAPtEcxh
3eYVQcjzSFKbegyGq74MlTR9Nuo7rUbi4lvNavIYBMiDdIJJTj5EGCQjEk8Z 6Y4FLpf+un+Y2nb+
vP8AyOn/ALMf/oI3f5Rf/EUf2Y//AEEbv8ov/iK810jxf4gnsJbubWtOn1E+ WyaPHdRtP5+/BtzH
5KNEDkqSzOVKg7iA2bN/4xv47jRUs9bV5nFvJcpK0US3HmTbHSOLymdimGUj emzC7ixzTSuJ6X8j
0H+zH/6CN3+UX/xFH9mP/wBBG7/KL/4iuLTUfENxc20n9vyxxXmt3emiJLWH EUSGYqykqSZB5YGT
lcHlSeTVfxPfxPptpqXihdMg8zUoLi/eKBWkMEypGcuuxWIPPGDkgAEjC6f1 2uNpp2/rr/kzuhaI
blrYavOZ1QSNEDFuCkkAkbM4JBGfY1J/Zj/9BG7/ACi/+Irzm513WraC81dV VNSfQ9PMsjpsEStP
KHlI2tswpLcqwXHIIBFWI/E99DbaTJd+K7C5ikuHjI0u/tZ7i5JZAqjdCiyA biGEaowBXG407a2E
9Nf62ud9/Zj/APQRu/yi/wDiKjuLRLW3kuLjVp4YIlLySSGJVRR1JJTAFYmp 6rdat4g07T9G1mSz
tpY71biSK3Rn8yF40wPMUgYYsM4IIz7Ec8viTxBBoMGpyaq0smoeHrq/Ef2e NUt5oljKmPC5I+c5
DlufTpSWqv8A11/yKUW2kegLpzMoZdSuiCMggRc/+OVHLaJA0SzavPG0z+XG HMQLtgnAynJwCceg
NchdazriXmo3yau629jqNjbrZiCLZIkywbwzFd3/AC0JGCMHrkYAqS6vJqHi zSI7jWhJdxa5NG+l
CJB9lRYpxG3A3/MuGyxIbd8oAFD0/r0/zJXw83l+jO+/sx/+gjd/lF/8RR/Z j/8AQRu/yi/+Irht
FvPEmpx+H1n8TXCHV9NkupHitIAYXj8vGzKEc+Z824NnHy7egpz+N9Vli8Ny RagkF1Nb2c11BJJG
i3QlkCt5cZiZ3wA2droFyvXmnbW3y/P/ACBq12ei/wBmP/0Ebv8AKL/4ij+z H/6CN3+UX/xFcVpP
iS/uvEcdv/b63NwdWurWTSlhiHl2qNIBIcDeMbVG/O08LgtzXotLpcHo2jGu oDb3NihmkmzOTukC
5/1b8cAVmaPYre3+qbpXj2Tn7qoc5Zv7yn0rZ1P/AI/bD/rqf/Rb1Q8N/wDH /q//AF3/APZnqo7M
mW6Lp0KI9bmb/v3F/wDEU0+H4D1nk/79Q/8AxFO8R+ILLwxos2qX5byo8Kqr 1dj0UdufU8Csb4ee
JL/xTot7qF8Ihi9eOARD5RHsQgA/xYJYZ9u3SldjsifV5tJ8K2kd1f6ndWsU 8ohUxWquXfazAYSI
norHp2rnT8SvCa3slu2uasqRxeY0509tme648rcCAVJyMYYc1lfGPWZpr7T/ AA/bRorwgag80mSP
mEsSqACP9sk5/u+9edHT5dQ8FXZgTOoWc0wcqv8ArQygkDAJPyMoA9UHYCsa uKoU+VTerdn5JrR/
fZGlWjUpUo15R9xu1z6STTzIiump3LIwBVlERBHqPkps9mttBJPPq08UMal3 kk8pVVQMkklMAAd6
fosiS+HtOlidXR7WNldTkMCgwQe4ry+LxJf6v4Ou/M19dUkuPD11Nf2yxRKL NxGNh+QBlLZPDE7u
SoAGK0vv/Xf/ACFGN2j1BdOZlDLqV0QRkECLn/xyq91HbWLQLd649u1xIIoR K8KGRz0VcryfYc1x
03iLUJPGdnpFnqrW8DMtpNbNJCZRm3LiWOIwltuduHaTaSCNhFZvg23eS68F yQ67c3Rg0y6V4B9n
IidfI3QnEeR1AIJ3DA5HOa6/15/18yFqj0v+zH/6CN3+UX/xFH9mP/0Ebv8A KL/4ivPbfxXqr6Jd
3cGvfbL4aRc3V7a+TF/xK7hFBVMBQVw25dshYnbnsauarqHiKz/tPyfEE3/E u0RNS+a1hJmlLTHa
3y8JhAuBhsAfMDksv6/P/Irlf9fL/M7b+zH/AOgjd/lF/wDEUw2ai4FudWnE zKXEf7rcVBAJxszj
JHPuK5mLU9SstalsL3xBIYnSxuY5ZLSMkNLM6NCAij5W2gAnJXOSTTtVvL1N K1LXbKf7PPc3ttZ2
0vlqxWATrGTg5B3FpSPYr6U7f1/XqLfT0/H/AIB0/wDZj/8AQRu/yi/+Io/s x/8AoI3f5Rf/ABFc
TJr2t2/jptKl12wt4LZ4oo4dQuo4ZLyMxgmQRiDMjFiwykiKCuNvBzXtfFV2 +iw+b4lby/7QS31D
WY3tZbe3UxM/7mRUCBSwRcyqSN+D1U0lqrh1sd9/Zj/9BG7/ACi/+Io/sx/+ gjd/lF/8RXI2Xiue
zl0ibVdXhGlT/bIlvp1SJboq6eQ2cAbmXeRtwG6gYxVTSfEPiK/skvY7uS5m h8Ow362awIBdXD+c
Pmwu4A7V+VSOQPcE6X/rr/kNK/8AXnY7n+zH/wCgjd/lF/8AEUyWzWBVabVp 4wzBFL+UMsTgAZTq
TwBXE6n4luLfwxa3Oj+LYdRWe9SK71CWa3jSyUoWwWSFliBYKP3iMRuwSCQR taJdXOtyaY091Z3/
APZ9uZ5Li1lEsU0zbkjKuAoJCBycKBlhgDpQ9Pl/w4v1/wCGN/8Asx/+gjd/ lF/8RR/Zj/8AQRu/
yi/+Irz238V6q+iXd3Br32y+GkXN1e2vkxf8Su4RQVTAUFcNuXbIWJ257Gp/ Emv6lotrcxzeKZLS
5g0k3dp5lvDm+mO8suCnITCYVMEBssWo/r8/8h2/r7v8zu/7Mf8A6CN3+UX/ AMRR/Zj/APQRu/yi
/wDiK5bxZ4pubbSIF0y+ht5Uu4re/u5mEKWoaLzATI0ciLklBuKMPmxwTkQW fiG5lvNLttV8U2dj
C9qkkN1aTQPHqUvmMrIJHj2tgBMhFU5c4wMCnbW39dyb6X8rnTxraTTrBFrr PMxcCNXhLHYdr8bf
4SQD6HrVn+zH/wCgjd/lF/8AEV55/beo6TYaiLG48oBdeufuK37yKYFG5B6b jx0Oec1ZHiS+ex1J
7XxbaT28cNtJJfzNBAltKzkSQq+0oG2jhZAxUkbjzkLon/X9aFNW+9/gzuv7 Mf8A6CN3+UX/AMRR
/Zj/APQRu/yi/wDiK89vfF2rPfaQtrrNvYWUtlFcRTaxcw25vHLsGUlYXR8A LxEycOCCQQRv694m
hN9YRw68NKsGe5jkuvKX95cRMqiDMikcnfwBubb8poeiv6/gL+vvOj/sx/8A oI3f5Rf/ABFRXNrH
Z20lzdaxNBBEpeSWUxKqKOpJKYArgIvEXiS80F79NaaF7Tw3BqjKtrEfOnPm khsrwhCAEDB6YK85
d4lbVZ4LvSrrXLqWMnS7xHEMCshkuijIP3eCgKqwyCcjksMgtxd7edvxsO1t /wCtv80d/DZLcwRz
warcSwyKHSRPKZWU8gghORT/AOzH/wCgjd/lF/8AEVzPjLxJc6fp0dvpeoRw yw3sdpf3twwhW3DR
bwzSNE6LuJjG7YV+fHBORQ0/xNqR1HTbebXLW8tJVjN1d2bRzRxyfPsiWQIo YzBRk7RgggAeYmFp
/X3is1v2udr/AGY//QRu/wAov/iKP7Mf/oI3f5Rf/EV5rZeMtbvLPVJLTWI5 FY2L2zu0Vw9v51zs
ZJAkUahguAUyxU/x1rTahr9hPqLNr89xHpeq2lqEkt4B9ojmMO4SFUHI80hS m3oMhqaTdv67f5gd
p/Zj/wDQRuvyi/8AiKjt7RLu3juLbV55oZFDJJGYmVgehBCYIrjdL8SX914h S3/t9bm4Oq3VrJpS
wxDy7VGkCyHA3jG1RvztPC4Lc1h6f4g1iw0/wxY2+q6dpdoNKtpo2vrpLdLp yxDploX34AX5VZGG
/OTkYUdfw/G7G1a/l/nY9S/sx/8AoI3f5Rf/ABFH9mP/ANBG7/KL/wCIrmdF 8URx6vq8Wp639r8i
ZV/0Z4ZraDfMY40/dqJEkyVBWTPcgkA4opqPiG4ubaT+35Y4rzW7vTRElrDi KJDMVZSVJMg8sDJy
uDypPJFrbzBq1/L/ACude1rGlzHbNrEy3Eis6RExBmUYyQNmSBkZPuKl/sx/ +gjd/lF/8RXBz+KN
cttLmX+0C89tZ6zmYwx5ke2kVYnIC4BAPIAAJPSrN5rWtaQNTt59ZeZRaWV0 byW2jBs1llZJWAVQ
Cqqu4bt2MfMWGaP6/P8AyBpr+u1l+p18dok0ssUWrzvJCwWVVMRKEgEBhs4O CDz2IqT+zH/6CN3+
UX/xFed6bqN4+p3UWleIDOl9r0Vu+orDE7SxfYd2RhdhOUGGAxkZwRkHT03V tchuNMuLvWJruKTV
rnTJbc28SrIkYm2yfKobzCYhnBCnJwoo/r8v8wa/r7/8mdj/AGY//QRu/wAo v/iKRtOZVLNqV0FA
ySRFgf8AjleZ2/jfWJdN1e5h1qJoVFlLBI7RXD2wluNjpIEijUMFwCnzFT/H XQWepz6zZXekxar/
AGvaXV6trBqG2P8AeQeWrz8xhVYAbkDAdWAOSDRZv+vT/MWx1cViJ4Umh1W4 kikUMjp5RDA8gghO
RTv7Mf8A6CN3+UX/AMRXHatqeuw32tTWmrm3t9P1GztILUW0bIUlWENuJG44 8wlcEYPXcMAMu9c1
TTjd6fea9JFa2+rpbTaxNFCrwQNbiUbvkEQJchNxXGGHGcGjfX+un+aHZnaf 2Y//AEEbr8ov/iKj
t7RLu3juLbV55oZFDJJGYmVgehBCYIrjj4kvDb6Yl54jFjYzPdeVqnkRA3ux wIV+ZSnzqWb5QC+3
KYFYOm+IdYsdN8L2MGq6dpdp/ZNtNG99crbpdOSQ6ZeF9+AF+VWRhv6nIw0r /wBev+Qnom+x6X5d
t9mluf7cfyImZZJd8O1CpwwJ24BBBB9MVY/sx/8AoI3f5Rf/ABFcloQN9jSw AY/7Zvru5yMjZHcu
VH1MhQ/RWqBNR8Q3FzbSf2/LHFea3d6aIktYcRRIZirKSpJkHlgZOVweVJ5K Wtv67fqNq1/L/g/o
jr2tY0uY7ZtYmW4kVnSImIMyjGSBsyQMjJ9xUv8AZj/9BG7/ACi/+Irg5/FG uW2lzL/aBee2s9Zz
MYY8yPbSKsTkBcAgHkAAEnpVm81rWtIGp28+svMotLK6N5LbRg2ayyskrAKo BVVXcN27GPmLDNH9
fn/kDTX9drL9Tr47RJpZYotXneSFgsqqYiUJAIDDZwcEHnsRUn9mP/0Ebv8A KL/4ivO9N1G8fU7q
LSvEBnS+16K3fUVhidpYvsO7IwuwnKDDAYyM4IyDp6bq2uQ3GmXF3rE13FJq 1zpktubeJVkSMTbZ
PlUN5hMQzghTk4UUf1+X+YNf19/+TOx/sx/+gjd/lF/8RR/Zj/8AQRu/yi/+ IrzK38b6xLpur3MO
tRNCospYJHaK4e2EtxsdJAkUahguAU+Yqf4667w74iR/tMcus/2rbPei206+ 2J/pDeV5jJuiUIdp
DjcABxjqKOlxf1+pv/2Y/wD0Ebv8ov8A4ij+zH/6CN3+UX/xFebr4x1M2jzW /iMXdydFvry5thbx
D7FcxqhWPAXK7SzDa5Lcck8VoalfeJLJNZA8STFrHSE1VCLSAbpD5mYiNh/d fu+B9/n75p2/r7/8
h2f9fL/M7AR2zag2njXHN6sfmm2Dw+YEzjdt25xnjPSrH9mP/wBBG7/KL/4i uEW5vdLk8Y6pHqk8
fmX1qskkkUbLaxvFBukGEBOxGONxIAUFgeSS11/VL+7+w2XiWS5tn1uOzjv4 4ICzQmzMpwdmwncM
7guPbHFCV9P66f5i6X/rY7v+zH/6CN3+UX/xFRz2iWsXm3Grzwx7lXdIYlGW IAGSnUkgD3Nef3Xj
LVRquv8A2PUwYINPv3jt5HikltpYMBS0axKUBO4gO77hg4HSk1DV7zVNHvoI Nej1WESadIbnyY9l
tcNdLuiATGQMA7GJZe7ciktbedh2tv8A1t/mei/2Y/8A0Ebv8ov/AIij+zH/ AOgjd/lF/wDEVn+G
rm+N5renX19JfGwu1jiuJURHZGhjkwwRVXguRkAcYroKBGf/AGY//QRu/wAo v/iKP7Mf/oI3f5Rf
/EVoUUAZ/wDZj/8AQRu/yi/+Io/sx/8AoI3f5Rf/ABFaFFAGM1rMszoNQucL 0+WP/wCIo+yzf9BC
5/75j/8AiKnnYpLO6xtIVGQi4yxx0GSBk+5ArG0GTxG81y2uW9tHHK++BIHD eQuAAhP8fTO7jknj
BAUASyVk8U3KtI0hEJ+ZsZP3PQAVuaJ/yBrT/rkn/oIrFtv+Rtuv+uP/AMRW 1on/ACBrT/rkn/oI
qpb/AHEx2NCiiipKCiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAK KKKACiiigDI/5jN1
/wBco/8A0KSuR17/AJJRP/2Ck/8ARYrrv+Yzdf8AXKP/ANCkrkte/wCSUT/9 gpP/AEWK2ofEYYn+
G/Rmhbf8k0h/7Aq/+iK3f+Yza/8AXKT/ANCjrDtv+SZw/wDYFX/0RW5/zGbX /rlJ/wChR1E+hpHq
a9FFFQWU9SsXv4ERJhEyPvBZNwPBHIyPX16gVjQeDLMwRRX801z5MaxxmOaW HAHdir5Ynjknt9c9
LRUKnFVFVXxLqVztx5HsQWdnb2FpHa2sYjhjGFUHPuSSeSSckk8kkk1PRXOX dxOj3U0jy/aYXYpE
rSbAoYBOEznIKk5ViN3IxgBVavJq+o4Q5tEbl5BJc2kkMV3NaSMMCeEIXT6B 1ZfzBqpo2jRaNBOq
3NxdT3MxnuLm5KmSVyAMnaFUYVVAAAGAK8vtptcsriO+ljvA6JaGWWW7u/m2 MTIHypG3BORyBk7d
2SK9Q17U5tI0mS8t7M3cisiiPLAAFgCzFVYhQDkkKcAdKmlXjUu0VUpOFkaV Fci3jV4pJHeztJbK
20xdSurq0vfNQIfMG2L5B5nMfU7Rgn0wd/SrjU7m2Mmp2NtaOSDGkF0Z/lx/ ESi4PsMj3raxkOs9
Lgsb7ULuJpDJfyrNKGIwCsaoNvHTCDrnnNXaKKAGSo0kLosrxMykCRANyn1G QRke4IrM0jQU0u6u
7yW/vNQvboIslxdlA2xM7UAjVVABZjwM5Y5JrWooAKKKKACiiigAqlNpcE+s Wmps0gntYpYUUEbS
JChOeM5+QY59au0UAFFFFABRRRQAUUUUAFFFFAFLTNLg0mCaGBpGWW4luWMh BIaRy7AYA4yxx7Vd
oooAzNT/AOP2w/66n/0W9UPDf/H/AKv/ANd//Znq/qf/AB+2H/XU/wDot6oe G/8Aj/1f/rv/AOzP
VR2ZL3R0VFFFSUcv4p8BaT4suoLu6lu7W6hTyxPaOqsyZJCncrAgEkjjIyfU 1kwfCDw3bxFEuNXG
/BkK37pvbGMkLgZ47Cu+rnZ/GWnR+MLPw1CGnu5y4ldCNsBCM4De5CngdOM9 RUuEW7tFOcpQ5G9O
3Q1dK0q00XSLbTLJGS1toxHGpYsQB7mjSNMh0XR7TTLZpGhtYliRpCCxAGBn AAz+FXa4DVfF893q
cTaWZYYNNm33UdwpiafjG3acEDazH5gPm2nHAzRJ39FZ+i6xb67psd/apOkT 9BNEUPTPHZhz95SQ
exrKvY31rxVPpNxd3UFla2cVwIrW4eB5ndnGS6ENhdg4DAZbnPFAdLnS0Vye seJj4ZvtP0yO3a+i
YxRzOZZXmhV5Ais2ImXHvI6ltpxkio4vGWoS3qINEiFrNfXOnwSm9+Z5ovMI yuz5UbyyM5JBP3SO
SeYWZ2FMiijghSGGNI4kUKiIoCqB0AA6CuZfxkj6e13bW0RRbOOd/PmZdssj bUgwiOxckMMBSc7R
g7uKlt46uLq102Y6XDai5mlhnkvbiSCKFkkEe0M0Od7ZyqusZOMdeKdtbB0u dpRWDreuX2n6rY6b
p2mR3tzdwzSqZbryUQRlM5O1jzv7A847EkYT+OJbnRpLm60dobO70ifUbUxX 5WV1jVSyMVUGJvnG
GVm/A8Ut/wCvX/JjSbaR3dFcfL4yu4L24RdHRtPtLq2tZ7lrz5wZlj2lU2Hd gygHLDjkZ5Ar3niD
Ur3WtFMNobbTG1iS2Ey3R3z+XFMrB4woAUsmR8zZ2gkCh6f16f5iW1zuKYkM UbyOkaK0jbnKqAWO
AMn1OAB9AK4qw8ba1qUenGDw5brJqVo13aCXUsDam3eHIjO3767cBs552U6f 4gqsOiXEGniaHUY4
JJkV5DLbCVgqlgsTIBknl3TO04zinZ3t/X9aA9Dtqx9c8P8A9vJ5E+qX0Ni6 7J7ODygk65yQzFC4
BHB2svFZln4uu7nUI1l0hItPk1GbTluPtYZzJGzgN5e37h2dd2QexHzHq6Xm GzsIAAAB0FLRRQBU
1PT4tW0m806dnWG7geB2jIDBWUqcZBGcH0qxFGIokjXJCKFGfan0UAFZ2saX PqtuIYdXvtOXDBzZ
iLLgjGCZEbH1XBrRooauCdivY2Vvpthb2NpH5dvbxrFEmSdqqMAZPsKsUUUN 31YJWCiiigAooooA
paZpcGkwTQwNIyy3EtyxkIJDSOXYDAHGWOPartFFABRRRQAUUUUAFFFFAFLV dLg1ix+yXDSLH5sU
2YyAcxyK46g8ZUZ9qtGGJplmMaGVFKq5UbgDjIB9DgfkKfRQAUUUUAFFFFAD BDEJmmEaCVlCs4Ub
iBkgE+gyfzNPoooAKKKKACiiigClqulwaxY/ZLhpFj82KbMZAOY5FcdQeMqM +1XaKKAMaw8PC01d
tUutTvtRuvKMMRuvKAhQsGYKI0QckLknJ+Uc1s0UUeQEF5BJc2kkMV3NaSMM CeEIXT6B1ZfzBqpo
2jRaNBOq3NxdT3MxnuLm5KmSVyAMnaFUYVVAAAGAK0qKAKmp6fFq2k3mnTs6 w3cDwO0ZAYKylTjI
Izg+lWIoxFEka5IRQoz7U+igAooooAKKKKACiiigDInuXF5OsVrNNsYKxQoA DgHHzMOxFQtqTR/f
srhef70f/wAXU0P/AB96l/18D/0VHWTek+d1/j/rQAWMqz+Jp5kOUe33KfY7 DW7on/IGtP8Arkn/
AKCK5rQf+Qqn/Xin/oMddLon/IGtP+uSf+giqlv9xMdjQoooqSgooooAKKKK ACiiigAooooAKKKK
ACiiigAooooAKKKKACiiigAooooAyP8AmM3X/XKP/wBCkrk9e/5JNP8A9gpP /RYrrP8AmM3X/XKP
/wBCkrlNe/5JLP8A9gpP/RYraj8Rhif4b9GaFsP+LZQ/9gVf/RFbf/MZtf8A rlJ/6FHWFbMP+FZQ
/wDYEX/0RW7/AMxm1/65Sf8AoUdRLoaxNeiiioKCiiigArjItI1c6tNdfZ/K lmijjadirAENIWJA
flf3jYAAP04x2dcZqPxL0jS9RuLG6sdVWaCQxti14OD1HPII5B7gisqmFVdq /Qf1hUFd9TastDkj
uFlvrqO58sho0SExqG/vEFmyR26AdeTgjQv7GHUbRrad7hI2IJNvcSQPwc8P GwYfgawtM8UJqWsQ
rFKjWl1CjxICN8ZK7sPjowwwIye1aniDUJdJ8N6pqMCo01paSzosgJUsqFhn BBxketZ0HStKMFbl
bT9UaS55NNu99vmJa+HtKswwhs1w9sto4kZnDxKWIVtxO7l2JJ5OTkmpNK0e 00W2NvZm68okELPd
yz7cDACmRm2j2GBXIN4y1M+J57CG50qQw3VtENMETfa5Y5EjZ5VbzOAu9j9z GEOSOtaHhrxJcazr
eoW02saMTbXNxF/ZsMRF0iRylFdiZTwQAfuD7wrqs/6/rzMul/T8f+GOuorl j4gvP+EovbOW5sbW
3sxv+xy27tc3UOwMZomDYKgkrgI3KkEgnjTuvE2kWcUcktyzCWFZ4xDDJKXR mCrgIpJJLAAdTzgc
HCB6GtRXNQ+NbCXX7jTXgu7eKGxS8a5uLWaJFU7yd29AEAC5yxGSSOqmpj40 0JLVbiS4uYleYQIk
1lPHI7lSygRsgY7gpwQMEjAyeKA/r9fyN+isKx8Y6HqV3b2trdyNJcFliLW0 qKXUEtHuZQokAU5Q
ncMHIqeLVJ5PFt3pJWPyIbGG5VgDuLO8ikE5xjCDt60B0ua1FchceM4rHVrK Ca4juLWc3qu1vZTG
TfDIihFRdzMQGbcQDnbuGBWvH4p0ee6gtre5kuJZ7ZbuMQW8kgMJDYbKqQAd pHPfA6kAnS42jYor
APjPQ1tRcNPcoDcfZfKexnWbzSm8J5RTfkryPl57Vft9b0+6WyMM5b7aXEA8 tgSUzuyCMrjBB3Y5
46nFAjQormm1y7S91o3F3Z21nZXtvaQlrV5GJdYidxD8ljKFGAAvU5HFWT4v 0UJcMLid/s9wbZhH
ZzOWlBYFEAQmRhsYkLnAGTxzR0v/AF/Wo7G5RXNw+Ibq68T6dawR2x0q+tJp 45fn84shjGGVgNmC
5BU5PHO3GKq+J/FkmlaxFp0Nzb2apALm6uriymuVjQsVX5Yyu0ZViZGYKuBn 73B28xdLnXUVg67q
Wpx31jpmjm1W8uo5pzLdRNJGqRhcjarKclnQZzxyeelPg8RxS+Cl8StCyxfY PtrRA5IATcVz+maO
jf8AX9aDSbaS6m3RXC3XifxJp+l6ys8GlzalZaemoqQskUSxssmVK5YsytGR 1UMD/Dit6+1O/t9Q
8PiJrb7NfzGG4RomL58l5AUbcAMFMEFTnPUYp2F0v/Xc3KKKKQGZqf8Ax+2H /XU/+i3qh4b/AOP/
AFf/AK7/APsz1f1P/j9sP+up/wDRb1Q8N/8AH/q//Xf/ANmeqjsyXujoqKKK koK57TvA/h3StXGq
2enlL0M7iRriV8M2dxAZiATk9u5roaKACsbWPDlrrOoaddzMVa0k3Mo6TJ1C N7bgp79CP4jWzUV1
dQWVrLdXUyQwRKXkkc4VQOpJoAlrM1TQNO1iSGW7ilE8GRHPb3ElvKoPVQ8b K208ZGcHA9BV61uY
b20huraQSQTRrJG69GUjII/A1V1fV7XRrF7m5dd2D5UW4BpmAyFUHqT/APX6 UAUp/CGiXE8M0ttK
zxLGo/0qUB/LbchcBsSEMSQWyck81bTQdNj8nbbY8m7e9j/eNxM+7c3Xv5j8 dOenAqv4b11da06P
zzFHqMa4urZTyjZxkDOdpIyPb3Bpni/WJ9B8Nz6hby2sMiSwp5t0paKMPKiF mAZeAGJ6jpRew7a2
JW8L6O1jd2YtCkN1c/a5fLmdG87IberAhlOQCNpGO1Qjwhowt4LcRXQghkaU RC+nCSMzb2Mi78SZ
bn589/U1X07xFAY7aS68R6PexPDcTNNZQMsTLGV3MH811ULu5yTnIxjBqe38 Z6FciQrdTIYhCXSa
0miYCV9kZ2soOG
Re: How can I render a figure like Rational Rose style? [message #130528 is a reply to message #130487] Mon, 28 May 2007 00:21 Go to previous message
Originally posted by: bhatia1984.yahoo.com
hiiii
look at this article
this article tells u hw to set coustom figures
http://wiki.eclipse.org/index.php/GMF_Tutorial_BPMN
nw i think u cn follow.
varun bhatia
Previous Topic:Dynamic Colour change on Node
Next Topic:Link Constraint with oclIsKindOf
Current Time: Sun Jun 29 05:24:37 EDT 2025
Powered by FUDForum. Page generated in 0.27122 seconds
