moved eclipse, now says jre should be in eclipse folder [message #130347] |
Wed, 18 January 2006 12:25  |
Originally posted by: paulg002.earthlink.net
Eclipse won't even start up since i moved it, i get this error messsage: A
java runtime environment (jre) or JDK must be available in order to run
Eclipse. No Java virtual machine was found after searching the following
locations: C\Program Files\eclipse\jre\bin\javaw.exe 'javaw.exe' in your
current PATH
I HAVE CHANGED THE BUILD JAVA BUILD PATH TO THE REAL LOCATION OF JAVA JRE
AND IT STILL DOESN'T WANNA TRY THERE, SEE ERROR MESSAGE! ( it wants to
look in eclipse folder, why?) I moved it to C\program files\ and now it
thinks the jre should be in its own folder. Thanks all.
FUDForum. Page generated in 0.52836 seconds
