Home » Eclipse Projects » Plugin Development Environment (PDE) » How to get full path of opened file in editor
How to get full path of opened file in editor [message #11908] Wed, 09 July 2008 08:47 Go to next message
Originally posted by: yeronimuz.aol.com
I'm running an RCP app with two plugins. I want to start the second
plugin with a parameter, which is the file name (full path) of the
currently opened file in the editor of the first plugin.
So I have an action defined and get the filename from the active editor.
Problem is that I need the full path. I only get the short file name.
public final class SimulatorAction implements
IWorkbenchWindowActionDelegate {
private IWorkbenchWindow m_window;
public void run(IAction action) {
SimulatorGui gui = new SimulatorGui();
String fName =
m_window.getActivePage().getActiveEditor().getEditorInput(). getName();
// Start the GUI
public void init(IWorkbenchWindow window) {
m_window = window;
Help is appreciated.
JL
Re: How to get full path of opened file in editor [message #12473 is a reply to message #11908] Wed, 09 July 2008 09:15 Go to previous message
> String fName =
> // Start the GUI
> m_window = window;
> JL
Once again, I found the solution myself shortly after posting and after
some serious clicking around in the Object Inspector.
IResource fName = (IResource) m_window.getActivePage().getActiveEditor()
.getEditorInput().getAdapter(IResource.class);
String name = fName.getFullPath().toOSString();
String wsLocation =
fName.getWorkspace().getRoot().getLocation().toOSString();
// Now wsLocation + name are the full path to the opened file.
Thanks for the help...you're welcome ;-)
Re: How to get full path of opened file in editor [message #572765 is a reply to message #11908] Wed, 09 July 2008 09:15 Go to previous message
> String fName =
> // Start the GUI
> m_window = window;
> JL
String wsLocation =
Previous Topic:How to get full path of opened file in editor
Next Topic:cluttered directory structure view in new file creation wizard
Current Time: Fri May 09 06:59:11 EDT 2025
Powered by FUDForum. Page generated in 0.05173 seconds
