Home » Language IDEs » ServerTools (WTP) » Content assist in jsp: problem getting model
Content assist in jsp: problem getting model [message #130156] Fri, 05 August 2005 09:28 Go to next message
Originally posted by: relaxedrob.remove.optusnet.com.au
Hi All,
I created a new (empty) jsp file and attempted control+space in it. No
content assist appeared, but the following error did in the Problems view.
Can anyone tell me how I can fix this?
Any advice is most appreciated!
Message:
Exception Stack Trace:
java.lang.IllegalStateException: problem getting model
org.eclipse.wst.xml.ui.internal.contentassist.AbstractConten tAssistProcessor.computeCompletionProposals(AbstractContentA ssistProcessor.java:1230)
org.eclipse.jst.jsp.ui.internal.contentassist.JSPContentAssi stProcessor.computeCompletionProposals(JSPContentAssistProce ssor.java:843)
org.eclipse.jface.text.contentassist.ContentAssistant.comput eCompletionProposals(ContentAssistant.java:1503)
org.eclipse.jface.text.contentassist.CompletionProposalPopup .computeProposals(CompletionProposalPopup.java:261)
org.eclipse.jface.text.contentassist.CompletionProposalPopup .access$7(CompletionProposalPopup.java:258)
org.eclipse.jface.text.contentassist.CompletionProposalPopup $1.run(CompletionProposalPopup.java:221)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
org.eclipse.jface.text.contentassist.CompletionProposalPopup .showProposals(CompletionProposalPopup.java:216)
org.eclipse.jface.text.contentassist.ContentAssistant.showPo ssibleCompletions(ContentAssistant.java:1352)
org.eclipse.wst.sse.ui.internal.StructuredTextViewer.doOpera tion(StructuredTextViewer.java:489)
org.eclipse.ui.texteditor.TextOperationAction$1.run(TextOper ationAction.java:122)
org.eclipse.ui.texteditor.TextOperationAction.run(TextOperat ionAction.java:120)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:996 )
at org.eclipse.ui.commands.ActionHandler.execute(ActionHandler. java:182)
org.eclipse.ui.internal.handlers.LegacyHandlerWrapper.execut e(LegacyHandlerWrapper.java:108)
at org.eclipse.core.commands.Command.execute(Command.java:311)
org.eclipse.core.commands.ParameterizedCommand.execute(Param eterizedCommand.java:396)
org.eclipse.ui.internal.keys.WorkbenchKeyboard.executeComman d(WorkbenchKeyboard.java:459)
org.eclipse.ui.internal.keys.WorkbenchKeyboard.press(Workben chKeyboard.java:781)
org.eclipse.ui.internal.keys.WorkbenchKeyboard.processKeyEve nt(WorkbenchKeyboard.java:828)
org.eclipse.ui.internal.keys.WorkbenchKeyboard.filterKeySequ enceBindings(WorkbenchKeyboard.java:550)
org.eclipse.ui.internal.keys.WorkbenchKeyboard.access$3(Work benchKeyboard.java:493)
org.eclipse.ui.internal.keys.WorkbenchKeyboard$KeyDownFilter .handleEvent(WorkbenchKeyboard.java:117)
at org.eclipse.swt.widgets.Display.filterEvent(Display.java:917 )
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:842)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:867)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:852)
at org.eclipse.swt.widgets.Widget.sendKeyEvent(Widget.java:880)
at org.eclipse.swt.widgets.Widget.sendKeyEvent(Widget.java:876)
at org.eclipse.swt.widgets.Widget.wmChar(Widget.java:1190)
at org.eclipse.swt.widgets.Control.WM_CHAR(Control.java:3135)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3038 )
at org.eclipse.swt.widgets.Display.windowProc(Display.java:3706 )
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:16 56)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2711)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
Session Data:
eclipse.buildId=I20050627-1435
java.version=1.5.0_04
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_AU
Command-line arguments: -os win32 -ws win32 -arch x86 -clean -data
F:\java\eclipseWorkspace
Rob
Re: Content assist in jsp: problem getting model [message #131307 is a reply to message #130156] Tue, 09 August 2005 12:33 Go to previous message
Originally posted by: amywu.us.DELETETHISPART.ibm.com
Looks like:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=105467
"Robert Mark Bram" <relaxedrob@remove.optusnet.com.au> wrote in message
news:dcvpgr$70h$1@news.eclipse.org...
> Hi All,
> Message:
> at
..computeCompletionProposals(AbstractContentAssistProcessor. java:1230)
> at
uteCompletionProposals(JSPContentAssistProcessor.java:843)
> at
> at
> at
> at
> at
> at
> at
extViewer.java:489)
> at
:122)
> at
20)
> at
rapper.java:108)
> at
java:396)
> at
ard.java:459)
> at
781)
> at
oard.java:828)
> at
> at
va:493)
> at
> at
> at
> at
java:226)
> at
> at
> Session Data:
> Rob
Previous Topic:Minimum set of plugins for CSS editor
Next Topic:How to get WTP JSP editor to take note of @include directives
Current Time: Fri Jul 18 00:37:48 EDT 2025
Powered by FUDForum. Page generated in 0.03100 seconds
