Custom Dialog for a certain type of Node [message #130149] |
Fri, 25 May 2007 06:38  |
Originally posted by: evaandoli.dodo.com.au
I'd like to create a custom dialog when a user adds a certains type of node
to the diagram.
I thought this had been asked before on here but I could not find the
entry - so sorry if it has.
Can anyone give me a few pointers on:-
1) Best way to create a custom dialog.
2) Where should this be plug into in the diagram setup ?
Thanks for any help,
Stu
Re: Custom Dialog for a certain type of Node [message #131710 is a reply to message #131382] |
Thu, 31 May 2007 21:29  |
Excellent reply - thank you very much for this.
Stu
"Florin Banica" <fbanica@soluta.net> wrote in message
news:f3lu07$ao0$1@build.eclipse.org...
> Here it is a small example of a dialog (including the action, a command
> needed for modifying the GMF resource and some content and label providers
> for a listview and a comboview).
> The action is a contribution to the org.eclipse.ui.popupMenus extension
> point:
> <action
> class=" net.soluta.factory05.negotiation.diagram.utils.CreateVariabl esAction "
> enablesFor="1"
> id=" net.soluta.factory05.negotiation.diagram.utils.CreateVariabl esActionID "
> label="%createVariables"
> menubarPath="additions">
> </action>
> Inside the CreateVariablesAction class, in it's run method you declare a
> dialog variable:
> VariablesDialog dialog = new VariablesDialog(shell, selection);
> and then you just open it:
> dialog.open();
> You could also check the return code of open (it returns an int) and act
> in consequence.
> Inside the VariablesDialog class you will find how it is made (how
> controls are declared and used) and how it's working.
> There is a series of articles about this and related themes:
> 1. http://www.eclipse.org/articles/viewArticle/ViewArticle2.htm l
> 2.
> http://www.eclipse.org/articles/Article-JFace%20Wizards/wiza rdArticle.html
> 3.
> http://www.eclipse.org/articles/Article-TreeViewer/TreeViewe rArticle.htm
> Have a look at them and then try to make it on your own...
> Hope it will help you make yourself an idea about the dialog and how it
> works...
> Good luck,
> Floppy
> "Stu" <evaandoli@dodo.com.au> wrote in message
> news:f3lg9p$47j$1@build.eclipse.org...
>> Its the "Inside (dialog) I put the controls and the logic I needed".
>> That Im not sure how to start.
>> I haven't created a custom dialog before and I find myseld running around
>> trying to find examples of how to (without much success).
>> Stu
>> news:f3k36u$cd4$1@build.eclipse.org...
>>> Me, for instance, I made a new action (for a menu voice in the pop-up
>>> menu) and from the run method I create and open a dialog. Inside I put
>>> the
>>> controls and the logic I needed...
>>> news:f36eat$fbj$1@build.eclipse.org...
>>>> Hi,
>>>> node to the diagram.
>>>> Stu
FUDForum. Page generated in 0.03584 seconds
