Home » Newcomers » Newcomers » running apps with args
running apps with args [message #129974] Mon, 16 January 2006 13:47 Go to next message
Originally posted by: ashiers.hfx.eastlink.ca
Hi there,
I downloaded Eclipse and decided to try it out. I wanted to run my first
app with arguements passed to the main(...) method. Where in the IDE is
the place where I enter the arguements that are to be passed to the
main(...) method when executing the app?
Alan
import javax.swing.*;
public class HelloWorld
* @param args
public static void main(String[] args)
if(args.length == 0)
JOptionPane.showMessageDialog(null, "You didn't include any
arguements. Nothing to display.");
else
for(int i = 0; i < args.length; i++)
System.out.println(args[i]);
Re: running apps with args [message #129986 is a reply to message #129974] Mon, 16 January 2006 13:51 Go to previous messageGo to next message
Alan,
You specify the arguments in the launch configuration for your app.
From the Run menu select Run..., select the existing launch for your
app (should be under Java Applications) or create a new one, switch to
the Arguments tab and enter your args into the Program Arguments text box.
Hope this helps,
- Jeff
Re: running apps with args [message #130105 is a reply to message #129986] Tue, 17 January 2006 09:15 Go to previous message
Thanks. I was having a heck of a time trying to find where I was supposed
to enter in my arguements. Now I know.
Alan
Previous Topic:deploy with oracle driver
Next Topic:unknown error
Current Time: Thu Jul 17 21:54:29 EDT 2025
Powered by FUDForum. Page generated in 0.18727 seconds
