Home » Eclipse Projects » Equinox » Re: Configure Jetty in OSGi
Re: Configure Jetty in OSGi [message #129969] Tue, 28 April 2009 02:56 Go to next message
Michael Vandenberg schrieb:
> I am trying to create a Jetty Fragment which includes the jetty.xml file
> to configure Jetty within my OSGi container.
You cannot configure Jetty this way. The only way to configure Jetty
(prior to 3.5) is to provide system properties (through the command line
or config.ini). The helps in setting up SSL.
See here:
http://dev.eclipse.org/newslists/news.eclipse.technology.equ inox/msg02563.html
Starting with 3.5(M6) there is a new way to customize a started Jetty
instance. It works by providing an implementation of JettyCustomizer
class via a fragment to org.eclipse.equinox.http.jetty.
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.equinox /compendium/bundles/org.eclipse.equinox.http.jetty6/src/org/ eclipse/equinox/http/jetty/JettyCustomizer.java?root=RT_Proj ect&view=markup
This allows you to configure Jetty programmatically through its Java API.
-Gunnar
Gunnar Wagenknecht
gunnar@wagenknecht.org
http://wagenknecht.org/
Re: Configure Jetty in OSGi [message #129982 is a reply to message #129969] Tue, 28 April 2009 11:28 Go to previous messageGo to next message
Gannar,
Thanks for the info. I am new to OSGi and Jetty. What I am attempting to
do is optimize our server implementation and in researching Jetty it
appears with a stand alone Jetty implementation, modifying the jetty.xml
(maxThread specifically) will increase performance. In the context of
Jetty in a OSGi container I am not sure how to do this. I'll look into
the JettyCustomizer and see what is available to me.
Thanks again for your response.
Mike
Re: Configure Jetty in OSGi [message #129995 is a reply to message #129969] Tue, 28 April 2009 13:29 Go to previous message
"Gunnar Wagenknecht" <gunnar@wagenknecht.org> wrote in message
news:gt69bv$los$1@build.eclipse.org...
Two things to add to this:
1) System properties is not the only way. You can also do configuration
using JettyConfigurator or the OSGi Configuration Admin service. Direct use
of JettyConfigurator is the way the IDE is using this stuff for Help/User
Assistance.
2) Perhaps in 3.6 support for "jetty.xml" will be there as the Jetty folk
have signaled an interest in providing richer configuration mechanisms for
us.
> See here:
> -Gunnar
> Gunnar Wagenknecht
Previous Topic:How to enable AUTO_UPDATE in 3.5M6
Next Topic:Load a OSGI bundle w/o EclipseStarter
Current Time: Sun Jul 13 17:08:37 EDT 2025
Powered by FUDForum. Page generated in 0.05201 seconds
