Home » Archived » Visual Editor (VE) » Need getter for JLabel
Need getter for JLabel [message #129853] Mon, 14 August 2006 07:20 Go to next message
Originally posted by: juergen.hohmann.first-financial.biz
we use eclipse 3.2 with VE 1.2.
When i insert a jlabel to a panel ve generates no getJLabel method.
The object jlabel ist created insight the code for the jpanel.
But our code conventions says, we need a method.
Can i customize the ve to generate am method?
Thank you,
Juergen
Re: Need getter for JLabel [message #129908 is a reply to message #129853] Tue, 15 August 2006 09:14 Go to previous messageGo to next message
Originally posted by: musterman.hug.de
try Menu Window - Preferences - Jaa - Visual Editor - Pattern Style
"Juergen Hohmann" <juergen.hohmann@first-financial.biz> schrieb im
Newsbeitrag news:675863a7540d01d109050d60c88b0b4f$1@www.eclipse.org...
> Hello,
> Thank you,
> Juergen
Re: Need getter for JLabel [message #130014 is a reply to message #129908] Thu, 17 August 2006 09:01 Go to previous message
Pattern Style is enabled (i can't deactivate it).
For all other components ve generate the getter, but not for JLabel.
Re: Need getter for JLabel [message #613775 is a reply to message #129853] Tue, 15 August 2006 09:14 Go to previous message
> Hello,
> Thank you,
> Juergen
Re: Need getter for JLabel [message #614547 is a reply to message #129908] Thu, 17 August 2006 09:01 Go to previous message
Previous Topic:inaccessible components after cleaning project
Next Topic:Internally setting value of a property
Current Time: Sun Jul 27 01:27:31 EDT 2025
Powered by FUDForum. Page generated in 0.03852 seconds
