NullPointerException when trying to profile [message #129776] |
Mon, 05 May 2008 19:03  |
Originally posted by: dmohr.cs.unm.edu
I just installed tptp and wanted to profile an application of mine.
However, after I select the settings, i.e. main class, parameters &
memory or performance timing, and click Ok, I just get a crash:
org.eclipse.core.runtime.CoreException
Agent Controller is unavailable under port 10002. Make sure that the
service is started and the port number is correct under preferences.
org.eclipse.tptp.platform.iac.administrator.internal.startst op.AutoStartStop.hasProcessTerminated(AutoStartStop.java:275 )
org.eclipse.tptp.platform.iac.administrator.internal.startst op.AutoStartStop.startIAC(AutoStartStop.java:113)
org.eclipse.tptp.platform.execution.client.core.internal.Nod eImpl.connect(NodeImpl.java:102)
org.eclipse.tptp.platform.execution.util.internal.AgentContr ollerFactory$EstablishConnection.run(AgentControllerFactory. java:126)
at java.lang.Thread.run(Thread.java:619)
Is this a bug, or am I doing something wrong?
Eclipse Version: 3.3.2
I installed tptp through the pre-defined eclipse update site, and I have
i.e. TPTP Core Platform Execution Framework v4.4.100.200802221314 (other
TPTP components version number varies).
Any help would be appreciated!
~David
Re: NullPointerException when trying to profile [message #129946 is a reply to message #129776] |
Fri, 09 May 2008 12:40   |
David Mohr wrote:
> java.lang.NullPointerException
> at
> at
> at
> at
So maybe it'd be a useful piece of info that I'm using java 1.6. I
haven't been able to find some documents saying whether tptp now is
compatible with 1.6 or not...
I tried to create a project and specified jre 1.5 in eclipse, but I
still got the same error. But of course it was still run in the same
jdk. Switching back to 1.5 to test if that works seems like a lot of
hassle though...
~David
Re: NullPointerException when trying to profile [message #129983 is a reply to message #129970] |
Mon, 12 May 2008 12:04  |
Alexander N. Alexeev wrote:
> Hi, David
> Could you provide additional information about your environment?
> What OS do you use? Do you have any firewalls on your host (including
> Windows firewall) configured?
I'm running this on Gentoo Linux. I have a firewall, but localhost is
completely open.
> Also you can try last stable build M7 from tptp download page, only
> agent controller or "...tptp.runtime.allInOne..." packages.
I'll give that a shot, thanks.
> Alex.
~David
FUDForum. Page generated in 0.06448 seconds
