Can't get BPMN Modeler to work [message #11871] |
Wed, 06 May 2009 05:14  |
I have installed the BPMN Modeler on my Linux box but it does not seem to
work very well. It will create a default document but when you try to make
any kind of connection between two shapes the connection will appear in
the upper left corner of the pool instead of connecting the two shapes and
the modeller then fails accept any more changes. If you save the changes,
when you open the document afterwards you get;
Could not open the editor: Corrupted model
org.eclipse.stp.bpmn.impl.ActivityImpl@604cd176 (iD:
_11Tc8DoZEd6bVPeztXi7sQ) (documentation: null, name: null, ncname: null,
orderedMessages: [], activityType: GatewayDataBasedExclusive, looping:
<unset>)
This is the same message you get when trying to load the samples.
I have even tried a completely fresh install of Eclipse but I get the same
problem. Any help would be appreciated.
FUDForum. Page generated in 0.03153 seconds
