Home » Archived » BPMN Modeler » Can't get BPMN Modeler to work
Can't get BPMN Modeler to work [message #11871] Wed, 06 May 2009 05:14 Go to next message
I have installed the BPMN Modeler on my Linux box but it does not seem to
work very well. It will create a default document but when you try to make
any kind of connection between two shapes the connection will appear in
the upper left corner of the pool instead of connecting the two shapes and
the modeller then fails accept any more changes. If you save the changes,
when you open the document afterwards you get;
Could not open the editor: Corrupted model
org.eclipse.stp.bpmn.impl.ActivityImpl@604cd176 (iD:
_11Tc8DoZEd6bVPeztXi7sQ) (documentation: null, name: null, ncname: null,
orderedMessages: [], activityType: GatewayDataBasedExclusive, looping:
<unset>)
This is the same message you get when trying to load the samples.
I have even tried a completely fresh install of Eclipse but I get the same
problem. Any help would be appreciated.
Re: Can't get BPMN Modeler to work [message #11899 is a reply to message #11871] Thu, 07 May 2009 01:12 Go to previous messageGo to next message
Originally posted by: atoulme.intalio.com
> to work very well. It will create a default document but when you try to
> make any kind of connection between two shapes the connection will
> appear in the upper left corner of the pool instead of connecting the
> two shapes and the modeller then fails accept any more changes. If you
> save the changes, when you open the document afterwards you get;
> <unset>)
> same problem. Any help would be appreciated.
Kerry, look up this thread:
news://news.eclipse.org:119/15b7869ef49cd0ddcd602ae63981af90 $1@www.eclipse.org
and the associated bug with its resolution:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=266959
Antoine
Re: Can't get BPMN Modeler to work [message #12462 is a reply to message #11899] Sat, 09 May 2009 17:35 Go to previous message
Thanks for your help Antoine,
that was the info needed to get this working.
Previous Topic:visualize process data
Next Topic:Questions: BMPN to BPEL / Drill Down / Organiziational Roles
Current Time: Sat May 10 09:02:55 EDT 2025
Powered by FUDForum. Page generated in 0.02817 seconds
