Home » Language IDEs » Java Development Tools (JDT) » CVS ext connection method content comparision does not
CVS ext connection method content comparision does not [message #129559] Wed, 24 December 2003 01:59 Go to next message
Originally posted by: smadhusuthanan.yahoo.com
Hi All,
I'm connecting to a remote cvs repository using the ext connection
method. Everything works fine but i have problems when i try to compare
the workbench file with that of the repository file. The remote file
doesn't have any content. While the cvs diff from the cli works fine with
the same rsh client. Also whenever i try to retrieve a different version
of the repository file using the "Get Content" menu item it fails saying
cvs update failed.
Any ideas?
- Madhu
Re: CVS ext connection method content comparision does not [message #130178 is a reply to message #129559] Sun, 28 December 2003 08:40 Go to previous message
Originally posted by: Andre_Weinand.oti.com
On 24.12.2003 7:59 Uhr, in article bsbdg8$fk6$1@eclipse.org, "Madhusuthanan"
<smadhusuthanan@yahoo.com> wrote:
> Hi All,
> cvs update failed.
> Any ideas?
> - Madhu
What version of CVS are you using?
--andre
Previous Topic:Compare packages
Next Topic:MacOS X and command line arguments
Current Time: Tue Jul 22 09:10:12 EDT 2025
Powered by FUDForum. Page generated in 0.02516 seconds
