Home » Language IDEs » C / C++ IDE (CDT) » Failing to launch debugger in v2.1 RC3
Failing to launch debugger in v2.1 RC3 [message #129518] Tue, 30 November 2004 14:31 Go to next message
Originally posted by: john.watts.adtran.com
After upgrading CDT to v2.1, RC3, I can no longer debug applications
from within eclipse/CDT. I can run applications fine, but if I attempt
to run in GDB, I get the following message:
An internal error occurred during: "Launching".
Using mingw on Win XP (w/o SP2):
GCC v3.3.1
GDB v5.2.1
Eclipse v3.1.0 and,
CDT v2.1, RC3.
The Eclipse error log contains:
!ENTRY org.eclipse.core.runtime 4 2 2004-11-30 13:24:12.876
!MESSAGE An internal error occurred during: "Launching".
!STACK 0
java.lang.NoClassDefFoundError:
org/eclipse/debug/internal/core/memory/IExtendedMemoryBlockR etrieval
at java.lang.ClassLoader.defineClass0(Native Method)
at java.lang.ClassLoader.defineClass(Unknown Source)
org.eclipse.osgi.framework.internal.defaultadaptor.DefaultCl assLoader.defineClass(DefaultClassLoader.java:298)
org.eclipse.core.runtime.adaptor.EclipseClassLoader.defineCl ass(EclipseClassLoader.java:223)
org.eclipse.osgi.framework.internal.defaultadaptor.DefaultCl assLoader.findClassImpl(DefaultClassLoader.java:281)
org.eclipse.osgi.framework.internal.defaultadaptor.DefaultCl assLoader.findClass(DefaultClassLoader.java:172)
org.eclipse.osgi.framework.adaptor.core.AbstractClassLoader. findLocalClass(AbstractClassLoader.java:220)
org.eclipse.core.runtime.adaptor.EclipseClassLoader.basicFin dLocalClass(EclipseClassLoader.java:135)
org.eclipse.core.runtime.adaptor.EclipseClassLoader.findLoca lClass(EclipseClassLoader.java:59)
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:371)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:402)
org.eclipse.osgi.framework.adaptor.core.AbstractClassLoader. loadClass(AbstractClassLoader.java:93)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
org.eclipse.cdt.debug.internal.core.model.CDebugTarget.<init >(CDebugTarget.java:243)
at org.eclipse.cdt.debug.core.CDIDebugModel$1.run(CDIDebugModel .java:96)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1676)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1696)
org.eclipse.cdt.debug.core.CDIDebugModel.newDebugTarget(CDID ebugModel.java:107)
org.eclipse.cdt.launch.internal.LocalRunLaunchDelegate.launc h(LocalRunLaunchDelegate.java:102)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:588)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:513)
org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(D ebugUIPlugin.java:737)
org.eclipse.debug.internal.ui.DebugUIPlugin$6.run(DebugUIPlu gin.java:909)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:66)
Re: Failing to launch debugger in v2.1 RC3 [message #136369 is a reply to message #129518] Tue, 25 January 2005 14:33 Go to previous messageGo to next message
Originally posted by: alexfarberov.[nospam]hotmail.com
I get the same error.
App runs fine but fails when trying to debug.
Environment:
Eclipse
Version: 3.1.0
Build id: 200412162000
Eclipse C/C++ Development Tools
Version: 2.1.0
Build id: 200412170841
gdb-6.2.1 ,6.3 and 6.0 produce same error.
Snip from .log :
!ENTRY org.eclipse.core.runtime 4 2 2005-01-25 14:24:45.128
!STACK 0
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(ClassLoader.java:620)
at java.lang.ClassLoader.loadClass(ClassLoader.java:251)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:319 )
org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1674)
org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1694)
org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(D ebugUIPlugin.java:738)
org.eclipse.debug.internal.ui.DebugUIPlugin$6.run(DebugUIPlu gin.java:910)
> GCC v3.3.1
> GDB v5.2.1
> Eclipse v3.1.0 and,
> CDT v2.1, RC3.
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at java.lang.ClassLoader.loadClass(Unknown Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: Failing to launch debugger in v2.1 RC3 [message #136381 is a reply to message #136369] Tue, 25 January 2005 14:37 Go to previous messageGo to next message
Forgot to include OS & gcc v.:
Linux version 2.4.21-9.ELgpfs (gcc version 3.2.3 20030502 (Red Hat Linux
3.2.3-24)) #2 SMP Sat Apr 10 15:26:14 EDT 2004
> Environment:
> Eclipse
> Version: 3.1.0
> Version: 2.1.0
> Snip from .log :
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
>> attempt to run in GDB, I get the following message:
>> GCC v3.3.1
>> GDB v5.2.1
>> Eclipse v3.1.0 and,
>> CDT v2.1, RC3.
>> !STACK 0
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
Re: Failing to launch debugger in v2.1 RC3 [message #136405 is a reply to message #129518] Tue, 25 January 2005 15:08 Go to previous messageGo to next message
Originally posted by: mikhailk.qnx.com
The CDT 2.1 is intended to use with Eclipse 3.0.x. It is not compatible with
Eclipse 3.1.
"John Watts" <john.watts@adtran.com> wrote in message
news:coihq5$mfm$1@www.eclipse.org...
> After upgrading CDT to v2.1, RC3, I can no longer debug applications from
> within eclipse/CDT. I can run applications fine, but if I attempt to run
> GCC v3.3.1
> GDB v5.2.1
> Eclipse v3.1.0 and,
> CDT v2.1, RC3.
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: Failing to launch debugger in v2.1 RC3 [message #136481 is a reply to message #136405] Wed, 26 January 2005 02:43 Go to previous message
> Eclipse 3.1.
Actually debugging works with 3.1M2, not M3 and M4 though.
Gael
Previous Topic:Precompile processing of source files
Next Topic:debug problem(repost)
Current Time: Sat Jul 12 00:10:37 EDT 2025
Powered by FUDForum. Page generated in 0.04357 seconds
