Home » Eclipse Projects » Eclipse Platform » Using org.eclipse.ui.projectNatureImages extension point
Using org.eclipse.ui.projectNatureImages extension point [message #129333] Mon, 15 September 2003 10:42 Go to next message
With Eclipse 2.1 on Windows XP, I would like to add my own project nature
image to a project so that in the navigator view I can tell which projects
have my nature. In order to try and do this I am using the
org.eclipse.ui.projectNatureImages extension point in the following way
inside my plugin's plugin.xml file (where the nature "mynature" has
already been defined) :-
<extension point="org.eclipse.ui.projectNatureImages">
<image
id="org.eclipse.myproj.ui.mynatureImage"
natureId="mynature"
icon="icons/structure/myicon.gif">
</image>
</extension>
When the custom nature gets added to a project the expected outcome does
*not* take place - that is, my icon does *not* get overlaid on projects
with my custom nature in the navigator view. My plugin is extending the
JDT so I am adding my custom nature to the existing Java nature of a
project. However, all of the projects with my nature are still displaying
the "J" icon of a Java project.
Has anyone else encountered problems using this extension point or (more
likely) am I doing something wrong ?
I am a relative Eclipse newbie so if this question has previously been
answered on this group or else on some FAQ that you are aware of I would
be very grateful if you could point me at it. Likewise, if this is not the
appropriate group for asking this question then please let me know where
it should be asked.
George
Re: Using org.eclipse.ui.projectNatureImages extension point [message #129423 is a reply to message #129333] Mon, 15 September 2003 11:19 Go to previous messageGo to next message
Originally posted by: simon.ibm.oti.lab
It is order dependent. When you add your nature to the list of natures, add
it at the start.
Simon :-)
"George Harley" <gharley@uk.ibm.com> wrote in message
news:oprvjpsjnf22j3z7@eclipse.org...
> <image
> natureId="mynature"
> </image>
> </extension>
> it should be asked.
> Thanks
> George
Re: Using org.eclipse.ui.projectNatureImages extension point [message #129788 is a reply to message #129423] Mon, 15 September 2003 16:41 Go to previous messageGo to next message
On Mon, 15 Sep 2003 11:19:24 -0400, Simon Arsenault <simon@ibm.oti.lab>
> add
> it at the start.
> Simon :-)
>> nature
>> projects
>> <image
>> natureId="mynature"
>> </image>
>> </extension>
>> displaying
>> the
>> it should be asked.
>> Thanks
>> George
Thanks Simon. After reading your post I revisited the code where the
custom nature gets added to the project's existing Java nature and did a
slight mod to ensure that the custom nature gets added *before* the Java
nature.
Unfortunately this does *not* appear to make any difference to the outcome
: my projects always seem to have the little "J" icon positioned top-right
of their folder image. Any other suggestions for things to look out for
that could affect this ?
Thanks in advance,
George
Re: Using org.eclipse.ui.projectNatureImages extension point [message #129814 is a reply to message #129788] Mon, 15 September 2003 17:34 Go to previous message
On Mon, 15 Sep 2003 21:41:09 +0100, George Harley <gharley@uk.ibm.com>
>> add
>> it at the start.
>> Simon :-)
>>> Hi,
>>> nature
>>> projects
>>> <image
>>> natureId="mynature"
>>> </image>
>>> </extension>
>>> does
>>> displaying
>>> (more
>>> would
>>> the
>>> where
>>> it should be asked.
>>> Thanks
>>> George
> nature.
> outcome : my projects always seem to have the little "J" icon positioned
> top-right of their folder image. Any other suggestions for things to
> look out for that could affect this ?
> Thanks in advance,
Whoa ! Just found out that I was using an incorrect value for the natureId
attribute of my image element. I was not qualifying the id with the plugin
id (i.e. my natureId value was "mynature" whereas it should have been of
the form "my.plugin.id.mynature").
So it seems that getting the order of the natures right and using the
fully qualified nature id was what I required to get this to behave as
planned.
Thanks for your help !
George
Previous Topic:Is it possible somehow to add listner to catch CLOSING of IEditorPart
Next Topic:Junit does not show Progress bar ...
Current Time: Sat Jul 26 18:40:49 EDT 2025
Powered by FUDForum. Page generated in 0.04102 seconds
