Home » Eclipse Projects » Remote Application Platform (RAP) » TreeItem with 2 or more Images
TreeItem with 2 or more Images [message #129235] Tue, 21 April 2009 10:14 Go to next message
Originally posted by: m.schnelle.msit-solutions.com
i'm using the treeviewer to display some structured data.
this works fine. ;-)
Now, i have to draw one or more images on the right side of the treeitem.
example: Image + Text + Image + Image
I found on eclipse.org/swt/snippets an example, but the
SWT version of RAP seems to be a little bit flatten.
So, is there an alternative method to draw the images?
thanks and greetings, Markus
Re: TreeItem with 2 or more Images [message #129440 is a reply to message #129235] Wed, 22 April 2009 10:32 Go to previous message
Hi Markus,
Which snippet do you try to run? Which API are you missing?
Does this snippet use the GC to draw on the TreeItem? This is not
possible with RAP.
Would it be an option to set images on following columns?
Best reagrds, Ralf
Previous Topic:Problem with RWTLifeCycle / disposed context and Jaas Example implemetation
Next Topic:upload widget
Current Time: Tue Jul 22 01:44:30 EDT 2025
Powered by FUDForum. Page generated in 0.03650 seconds
