Home » Eclipse Projects » Remote Application Platform (RAP) » Browser window title and flavicon on RWT level
Browser window title and flavicon on RWT level [message #129150] Tue, 21 April 2009 07:54 Go to next message
Originally posted by: peterka.jiri.gmail.com
Hi all,
is there a way howto set Browser window title and flavicon from RWT
application?
Best regards
Jiri
Re: Browser window title and flavicon on RWT level [message #129182 is a reply to message #129150] Tue, 21 April 2009 08:55 Go to previous messageGo to next message
Originally posted by: markus.wolf.nmmn.com
Hi Jiri
> application?
in the FAQ is explained on how to create an RWT application:
http://wiki.eclipse.org/RAP/FAQ#How_do_I_use_a_RWT_standalon e_application_in_Tomcat
With the branding you can define your requested aspects.
Markus Wolf
NMMN - New Media Markets & Networks GmbH
Geschäftsführung: Kfm. Michael Schütt
Finanzamt HH-Altona UStID DE 812 699 852 HRB 71102 Hamburg
HypoVereinsbank - BLZ 200 300 00 - Konto-Nr. 156 29 82
http://www.nmmn.com Tel.: +49 40 284 118 -0
Langbehnstrasse 6 Entwicklung: -720
22761 Hamburg Fax: -999
Re: Browser window title and flavicon on RWT level [message #129209 is a reply to message #129182] Tue, 21 April 2009 09:31 Go to previous messageGo to next message
Hi Markus,
I've overlooked that. Thanks
Jiri
Markus Wolf wrote:
> Hi Jiri
>> application?
> Regards
> Markus Wolf
Re: Browser window title and favicon on RWT level [message #129262 is a reply to message #129182] Tue, 21 April 2009 10:54 Go to previous messageGo to next message
Markus,
I followed this steps, wrote own implementation of AbstractBranding and
this class is instantiated when app is executed. But getTitle() and
other methods are never called.
Don't you know what's wrong? (URL, some other details, etc.)?
Jiri
Markus Wolf wrote:
> Hi Jiri
>> application?
> Regards
> Markus Wolf
Re: Browser window title and favicon on RWT level [message #129336 is a reply to message #129262] Wed, 22 April 2009 03:12 Go to previous messageGo to next message
maybe the URL you're using is wrong? If you specifify "teaParty" as
Servlet-Name in your branding extension your URL should be sth like
"localhost:9090/teaParty" ...
Stefan.
Jiri Peterka schrieb:
> Markus,
> Jiri
> Markus Wolf wrote:
>> Hi Jiri
>>> application?
>> Regards
>> Markus Wolf
Re: Browser window title and favicon on RWT level [message #129349 is a reply to message #129262] Wed, 22 April 2009 04:15 Go to previous messageGo to next message
Hi Jiri,
You should define the following to get this working:
<context-param>
<param-name>org.eclipse.rwt.themes</param-name>
<param-value>my-theme#my-theme.css</param-value>
</context-param>
<context-param>
<param-name>org.eclipse.rwt.brandings</param-name>
<param-value>example.Branding</param-value>
</context-param>
Then you need a file my-theme.css in your root classpath and the class
'example.Branding'. This class must extend the AbstractBranding class of
RWT and override the following methods:
* getServletName() - this must return the servlet mapping url but
without leading slash
* getFavIcon() - this should return the path to the favicon you want to use
* getTitle() - this should return the page title you want to display
* getThemeId() - this should return 'my-theme' as specified in the
web.xml before the dash
Hope that helps :)
Markus
> Jiri
> Markus Wolf wrote:
>> Hi Jiri
>>> application?
>> Regards
>> Markus Wolf
Re: Browser window title and favicon on RWT level [message #129478 is a reply to message #129349] Wed, 22 April 2009 13:05 Go to previous messageGo to next message
Hi Markus,
thanks for detailed instructions. Nevertheless I've got still the same
problem. getServletName() is called twice and nothing more.
I've tried servlet name in getServletName() as
localhost:8180/rapServlet" or "localhost:8180/ServletTest/rapServlet",...
Web.xml servlet is defined like this:
<servlet>
<servlet-name>rapServlet</servlet-name>
<servlet-class>org.eclipse.rwt.internal.engine.RWTDelegate</servlet-class >
</servlet>
<servlet-mapping>
<url-pattern>/index.html</url-pattern>
</servlet-mapping>
Finally URL is http://localhost:8180/ServletTest where "ServletTest" is
Project name in Eclipse. I'm little bit confused with this mapping.
Any idea is welcome. (RAP 1.2 M6)
Best regards
Jiri
Markus Wolf wrote:
> Hi Jiri,
> <context-param>
> </context-param>
> <context-param>
> </context-param>
> Hope that helps :)
> Regards
> Markus
>> Jiri
>> Markus Wolf wrote:
>>> Hi Jiri
>>>> application?
>>> Regards
>>> Markus Wolf
Re: Browser window title and favicon on RWT level [message #129491 is a reply to message #129478] Wed, 22 April 2009 13:18 Go to previous messageGo to next message
Hi Jiri,
> <servlet>
> </servlet>
> <servlet-mapping>
> </servlet-mapping>
You specified '/index.html' as mapped servlet. Therefore using
'index.html' in your Binding as getServletName() should work.
Markus
> Best regards
> Jiri
> Markus Wolf wrote:
>> Hi Jiri,
>> <context-param>
>> </context-param>
>> <context-param>
>> </context-param>
>> to use
>> Hope that helps :)
>> Regards
>> Markus
>>> Jiri
>>> Markus Wolf wrote:
>>>> Hi Jiri
>>>>> application?
>>>> Regards
>>>> Markus Wolf
Re: Browser window title and favicon on RWT level [message #129504 is a reply to message #129491] Wed, 22 April 2009 13:33 Go to previous message
Markus, thanks, you're the man! Now it works great :).
Jiri
Markus Wolf wrote:
> Hi Jiri,
>> <servlet>
>> </servlet>
>> <servlet-mapping>
>> </servlet-mapping>
> Regards
> Markus
>> Best regards
>> Jiri
>> Markus Wolf wrote:
>>> Hi Jiri,
>>> <context-param>
>>> </context-param>
>>> <context-param>
>>> </context-param>
>>> to use
>>> Hope that helps :)
>>> Regards
>>> Markus
>>>> Jiri
>>>> Markus Wolf wrote:
>>>>> Hi Jiri
>>>>>> application?
>>>>> Regards
>>>>> Markus Wolf
Previous Topic:Suuport for tabbed properties view?
Next Topic:Problem with RWTLifeCycle / disposed context and Jaas Example implemetation
Current Time: Mon Jul 21 22:13:14 EDT 2025
Powered by FUDForum. Page generated in 0.07388 seconds
