Re: [buckminster-dev] New to Buckminster [message #11806] |
Wed, 26 March 2008 10:10 |
Hi Matt,
first of all I just want to add to Thomas' response. Your input would be
very welcome and one of the areas where the documentation should be
extended is a bunch of diverse real life examples. We do provide some
usage scenarios with examples but we need to build up more of those. And
they should serve both as a coverage of Buckminster's usecases and as
simple HowTo documents.
As Thomas said, you shouldn't worry about the format. But feel free to
start things on the Wiki even if you feel that they are incomplete. That
would be the easiest way to collaborate on the docs if you want to.
I would also encourage you to make suggestions if you have ideas on how
to structure the Wiki content. Start a Wiki page for this if you like or
post to this list. We have collected some suggestions regarding Wiki
Categories that you may use
(http://wiki.eclipse.org/Buckminster_Wiki_contributions). As a minimum
put [[Category:Buckminster]] on the page and feel free to add new
categories if you feel they are missing.
We invested a lot of time last year writing the Buckminster language
reference
( http://wiki.eclipse.org/Buckminster_component_meta-data_lang uage_%28Reference%29_-_LATEST).
It represents one - very formal - entry point to Buckminster. I am
always very happy if I see that someone is actually reading this ;-)
and feedback on this is also VERY welcome. A primer for this reference
is on our list of docs to write and I think the examples you were
thinking of would match up perfectly with this.
Adrian, all of the above applies to you as well of course. Your input
will be invaluable given the amount of time you spent with Buckminster
and of course because you succeeded :-)
You were asking for an example query/rmap to try. One that I can
recommend is
http://www.eclipse.org/spaces/queries/spaces.cquery
for the Eclipse Spaces project. It is not resolving as big a project as
the Buckminster project or STP project CQueries but it is not trivial
either. Spaces is also using Buckminster under the covers. If you have
any problems let me know.
Looking forward to your contributions.
Stefan
Matt Hollingsworth wrote:
> Adrian,
> I have also spent quite some time wrestling with it (and actually haven't
> managed to make my own rmap/cquery that works), which is what made me decide
> to do this a bit more systematically, and I figured that while I was at it,
> I might as well write down what I'm doing. And I am quite interested in
> coming up with lots of examples... at least one for each feature. For
> example, I couldn't find any examples for the things like the match tag, or
> basically any of the rewriting features of the rmaps, so that will be one of
> the first things that I do, after double-checking all the existing docs.
> Not to mention that I would like to have a *really* simple example that just
> gives a name for a project in a repository and have Buckminster check it out
> for you. I really like the approach where you take the simplest situation
> possible and add more and more features to it to construct further examples,
> so that's probably the approach that I will take unless someone has other
> suggestions.
> As far as I'm concerned, any input that you could give would be very
> welcome :).
> -Matt
> -----Original Message-----
> From: buckminster-dev-bounces@eclipse.org
> [mailto:buckminster-dev-bounces@eclipse.org] On Behalf Of Adrian Skehill
> Sent: Thursday, March 20, 2008 11:36 PM
> To: Buckminster developer discussions
> Subject: Re: [buckminster-dev] New to Buckminster
> On Thu, Mar 20, 2008 at 9:41 PM, Thomas Hallgren <thomas@tada.se> wrote:
>> Hi Matt,
>> I think the most important things right now is the content itself and to
> get it structured in a way
>> that makes it easy to navigate. IMO this is the difficult part. The
> actual medium can be changed
>> once we have that.
> For me, one thing that would be invaluable would be a whole bunch of
> cquery's, rmaps, cspex with tonnes of comments in them. I'm a learn by
> doing person, then going "oh, that's how it works" when I go back to
> documentation later to follow up on something.
> Having spent a lot of time wrestling with Buckminster these last few
> weeks, I finally have light at the end of the tunnel, and my final
> build system is so much more simple than anything I had done
> previously. If there's anything I can add to the documentation, I'll
> gladly help.
> Adrian.
> _______________________________________________
> buckminster-dev mailing list
> buckminster-dev@eclipse.org
> https://dev.eclipse.org/mailman/listinfo/buckminster-dev
FUDForum. Page generated in 0.03194 seconds
