Home » Archived » Visual Editor (VE) » Remote VM terminated before - Eclipse 3.2 VE
Remote VM terminated before - Eclipse 3.2 VE [message #129098] Thu, 27 July 2006 03:43 Go to next message
my projects work fine with eclipse 3.1 and the VE. Now I have installed
eclipse 3.2 and use the updater to install VE. (Windows XP)
After opening a visual class I recieve several errors. I did clean all
projects with no success.
Thank you for helping
Arndt
Start of log-file:
!SESSION 2006-07-27 09:35:12.781
eclipse.buildId=M20060629-1905
java.version=1.5.0_07
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_DE
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.jem.proxy 2 0 2006-07-27 09:35:35.812
!MESSAGE IWAV0138E Remote VM terminated too soon. See .log file for trace
of output. For VM "Project (MAMA)-VM for MAMA".
IWAV0072I Remote VM terminated before any commands can be sent. Following
are the error and output streams.
Remote VM Commandline:
C:\Programme\Java\jre\bin\javaw.exe -Dproxyvm.registryKey=21930582
-Dproxyvm.masterPort=2900 -Dproxyvm.bufsize=16000
"-Dproxyvm.servername=Project (MAMA)-VM for MAMA" -noverify
-Xbootclasspath:C:\Programme\Java\jre\lib\rt.jar;C:\Programm e\Java\jre\lib\jsse.jar;C:\Programme\Java\jre\lib\jce.jar
-classpath
" C:/Programme/Eclipse32/configuration/org.eclipse.osgi/bundle s/284/1/.cp/vm/remotevm.jar;D:/JAVA/Applications/MAMA/bin/;D :/JAVA/ApplicationLayer/ApplicationBase/bin/;D:/JAVA/Base/My Bus/bin/;D:/JAVA/Base/FWExceptions/bin/;D:/JAVA/Base/Mapping /bin/;D:/JAVA/Base/DBAccess/bin/;D:/JAVA/Base/Utilities/bin/ ;D:/JAVA/Base/jcifs-1.2.9.jar;D:/JAVA/Base/Datastructures/bi n/;D:/JAVA/Extern/ojdbc14.zip;D:/JAVA/Extern/jtds-1.0.3.jar; D:/JAVA/Extern/postgresql-8.1-404.jdbc3.jar;D:/JAVA/Base/Swi ngExtensions/bin/;D:/JAVA/Applications/MAMA/libs/Imagero191/ ImgrRdr191_4.zip;D:/JAVA/Base/Printing/bin/;D:/JAVA/Extern/i text-1.3.jar;D:/JAVA/ApplicationLayer/Compenents/bin/;C:/Pro gramme/OpenOffice.org
2.0/program/classes/officebean.jar;C:/Programme/OpenOffice.o rg
2.0/program/classes/ridl.jar;C:/Programme/OpenOffice.org
2.0/program/classes/sandbox.jar;C:/Programme/OpenOffice.org
2.0/program/classes/unoil.jar;C:/Programme/OpenOffice.org
2.0/program/classes/juh.jar;C:/Programme/OpenOffice.org
2.0/program/classes/jurt.jar;D:/JAVA/ApplicationLayer/AutoUp date/bin/;D:/JAVA/Applications/MAMA/libs/freechart/jfreechar t-1.0.1.jar;D:/JAVA/Applications/MAMA/libs/freechart/jcommon -1.0.0.jar;D:/JAVA/Applications/MAMA/libs/jcifs-1.2.9.jar;D: /JAVA/Applications/MAMA/libs/jai_imageio.jar;C:/Programme/My Eclipse
5.0M2/eclipse/plugins/org.eclipse.jem.proxy_1.2.0.v20060530_ RC2.jar;C:/Programme/Eclipse32/configuration/org.eclipse.osg i/bundles/477/1/.cp/vm/jfcbeaninfo.jar;C:/Programme/MyEclips e
5.0M2/eclipse/plugins/org.eclipse.jem.beaninfo_1.2.0.v200605 30_RC2.jar;C:/Programme/Eclipse32/configuration/org.eclipse. osgi/bundles/283/1/.cp/vm/beaninfovm.jar;C:/Programme/Eclips e32/configuration/org.eclipse.osgi/bundles/476/1/.cp/vm/java remotevm.jar;C:/Programme/Eclipse32/configuration/org.eclips e.osgi/bundles/477/1/.cp/vm/jfcvm.jar "
org.eclipse.jem.internal.proxy.vm.remote.RemoteVMApplication
-- Error Stream --
Exception in thread "main" java.lang.NoClassDefFoundError:
org/eclipse/jem/internal/proxy/common/IVMServer
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(Unknown Source)
at java.security.SecureClassLoader.defineClass(Unknown Source)
at java.net.URLClassLoader.defineClass(Unknown Source)
at java.net.URLClassLoader.access$100(Unknown Source)
at java.net.URLClassLoader$1.run(Unknown Source)
at java.net.URLClassLoader.findClass(Unknown Source)
at sun.misc.Launcher$AppClassLoader.loadClass(Unknown Source)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
org.eclipse.jem.internal.proxy.vm.remote.RemoteVMApplication .main(RemoteVMApplication.java:34)
-- Output Stream --
-- End of Stream Output --
!ENTRY org.eclipse.jem.proxy 2 0 2006-07-27 09:35:35.843
!MESSAGE
+++ Warning +++: Thu Jul 27 09:35:35 CEST 2006 Project (MAMA)-VM for
MAMA:err>
Re: Remote VM terminated before - Eclipse 3.2 VE [message #129112 is a reply to message #129098] Thu, 27 July 2006 09:51 Go to previous messageGo to next message
Originally posted by: richkulp.us.NO_SPAM.ibm.com
Do you have MyEclipse installed in addtion to Eclipse? There appears to
be a conflict depending on the order of installation. Another had
installed MyEclipse including VE and then also installed VE from
Callisto and this caused a problem. The only way he got it to work was
to first install Eclipse with VE from Callisto and then installed
MyEclipse without the VE.
Rich Kulp
Re: Remote VM terminated before - Eclipse 3.2 VE [message #129125 is a reply to message #129112] Thu, 27 July 2006 10:26 Go to previous message
Thank you!
Works fine.
Re: Remote VM terminated before - Eclipse 3.2 VE [message #613569 is a reply to message #129098] Thu, 27 July 2006 09:51 Go to previous message
Rich Kulp
Re: Remote VM terminated before - Eclipse 3.2 VE [message #613570 is a reply to message #129112] Thu, 27 July 2006 10:26 Go to previous message
Thank you!
Works fine.
Previous Topic:Remote VM terminated before - Eclipse 3.2 VE
Next Topic:Code generation
Current Time: Mon Jul 21 22:14:15 EDT 2025
Powered by FUDForum. Page generated in 0.06438 seconds
