| How to enable AUTO_UPDATE in 3.5M6 [message #128950] |
Fri, 10 April 2009 03:21  |
I see something has changed on the Preferences side. In my RCP app I
have code like:
Preferences pref = ProvSDKUIActivator.getDefault()
.getPluginPreferences();
// See if automatic search is enabled at all
if (pref.getBoolean(PreferenceConstants.PREF_AUTO_UPDATE_ENABLE D) ==
false) {
pref.setValue(PreferenceConstants.PREF_AUTO_UPDATE_ENABLED, true);
pref.setValue(PreferenceConstants.PREF_UPDATE_ON_STARTUP, true);
pref.setValue(PreferenceConstants.PREF_DOWNLOAD_ONLY, true);
How would I do this with 3.5 ?
Regards Thomas
| Re: How to enable AUTO_UPDATE in 3.5M6 [message #129945 is a reply to message #129265] |
Mon, 27 April 2009 13:52  |
Thomas wrote:
> Hi Susan,
> can you clarify some questions (see below) ?
> Susan McCourt schrieb:
>>> have code like:
>>> if
>>> false) {
>> The preferences for auto-update moved from the bundle
>> org.eclipse.equinox.p2.ui.sdk to org.eclipse.equinox.p2.ui.sdk.scheduler.
>> In M6, you need to ensure your app uses the scheduler bundle, not
>> ProvSDKUIActivator, and use the constants and prefs from its activator.
> What exactly do I have to change here ?
Preferences pref =
AutomaticUpdatePlugin().getDefault().getPreferenceStore();
Get the prefs from AutomaticUpdatePlugin() instead of ProvSDKUIActivator.
Then use the PreferenceConstants defined in that bundle
(org.eclipse.equinox.p2.ui.sdk.scheduler) instead of PreferenceConstants
in the other bundle.
FUDForum. Page generated in 0.04115 seconds
