Home » Language IDEs » Java Development Tools (JDT) » OSGI BundleActivator cannot be resolved
OSGI BundleActivator cannot be resolved [message #128946] Sat, 20 December 2003 15:07 Go to next message
Originally posted by: schmerl+gef.cs.cmu.edu
Moving to M6, my plugin no longer compiles. The plugin.java file is flagged
with the following error:
The type org.osgi.framework.BundleActivator cannot be resolved. it is
indirectly referenced from required .class file.
I have the OSGI jars selected in my target plaform. What more do I need to
do?
Any help would be greatly appreciated.
Bradley.
Re: OSGI BundleActivator cannot be resolved [message #129011 is a reply to message #128946] Sat, 20 December 2003 20:42 Go to previous messageGo to next message
"Bradley Schmerl" <schmerl+gef@cs.cmu.edu> wrote in message
news:bs2a6j$pap$1@eclipse.org...
> flagged with the following error:
> it is indirectly referenced from required .class file.
We ran into the same thing with our products.
> to do? Any help would be greatly appreciated.
Add the following JARs to your .classpath file...
ECLIPSE_HOME/plugins/org.eclipse.osgi_3.0.0/osgi.jar
ECLIPSE_HOME/plugins/org.eclipse.osgi_3.0.0/eclipseAdaptor.j ar
You will also need to add the following import to your plugin.xml...
<import plugin="org.eclipse.osgi" optional="true"/>
-Eric Clayberg
Sr. Vice President of Product Development
Instantiations, Inc.
mailto:cpsws-support@instantiations.com
http://www.instantiations.com
http://www.instantiations.com/codepro/ws
http://www.swt-designer.com
Re: OSGI BundleActivator cannot be resolved [message #130107 is a reply to message #129011] Sat, 27 December 2003 21:18 Go to previous messageGo to next message
Originally posted by: ed.burnette.REMOVE.THIS.sas.com
Or instead of org.eclipse.osgi, add org.eclipse.core.runtime.compatibility
to plugin.xml. Editing .classpath shouldn't be necessary (wasn't for me, at
least).
I could be wrong but I believe this is only a problem for those of us
following along with the 3.0M* versions - somebody converting directly from
2.1.x shouldn't have to do that manually.
Ed Burnette, co-author, Eclipse in Action
www.eclipsepowered.org
"Eric Clayberg" <clayberg@instantiations.com> wrote in message
news:bs2tpd$8h2$1@eclipse.org...
Re: OSGI BundleActivator cannot be resolved [message #130216 is a reply to message #130107] Sun, 28 December 2003 09:39 Go to previous messageGo to next message
"Ed Burnette" <ed.burnette@REMOVE.THIS.sas.com> wrote in message
news:bslega$nkj$1@eclipse.org...
> to plugin.xml.
We added that one as well, but it was not enough. We needed to import the
osgi plugin as well.
> least).
We needed to do that in order to get everything to compile properly. Editing
the plugin.xml file only solved the runtime problem for us.
from
I'm not sure what you mean here. On our end, we are keeping our plugins
compatoble with Eclipse 2.0, 2.1 and 3.0 simultaneously.
-Eric Clayberg
Re: OSGI BundleActivator cannot be resolved [message #130297 is a reply to message #130216] Mon, 29 December 2003 01:11 Go to previous message
news:bsmpuh$ne4$1@eclipse.org...
> from
That's a nice trick; I remember a posting you made about that a while back.
I see that you're going to be presenting something on this at EclipseCon
(www.eclipsecon.org) and I'm looking forward to it.
However, I expect most plug-in developers (esp. non-commercial ones) will
still target only one major version of Eclipse. When you bring a 2.1 plug-in
into 3.0 there's a wizard to convert it, making it incompatible with 2.1.
One of the things this wizard should do is insert any new necessary
dependencies. Since I converted my plug-ins early in the 3.0M* cycle, I
didn't get the benefit of that (even M6 doesn't completely do it). But
somebody converting directly from 2.1.x production to the production 3.0
hopefully won't have the problems.
Ed
Previous Topic:mac os x & memory
Next Topic:Project inconsistent.
Current Time: Wed Jul 16 08:43:31 EDT 2025
Powered by FUDForum. Page generated in 0.07997 seconds
