eclipse in linux, specifying "-Xmx512m" on ant run [message #11781] |
Sat, 22 January 2005 03:44  |
Originally posted by: suryaradhakrishnan.yahoo.co.in
Hai ,
I have installed and configured eclipse in Redhat Linux 9.1 . But
on running the ant task for x-doclet (to generate interfaces) it shows
java.lang.OutOfMemoryError . In windows installation of eclipse I could
solve this issue by specifying more jvm memmory ( -Xmx512m ) . But in the
new linux installation the GUI part where we give VM argument is missing.
Also ant when run from within eclipse is not taking enviroment variable
ANT_OPTS . I will be gratefull to have a solution to this soon. Could
anybody explain, Where can I give VM arg -Xmx ?
Thank you,
Surya.
Re: eclipse in linux, specifying "-Xmx512m" on ant run [message #11816 is a reply to message #11781] |
Sat, 22 January 2005 09:21  |
The VM arguments text area should be available for both Windows and Linux
Have you tried resizing the launch configuration dialog to make it visible?
Ant in Eclipse does not support ANT_OPTS
https://bugs.eclipse.org/bugs/show_bug.cgi?id=26491
HTH
Darins
"surya" <suryaradhakrishnan@yahoo.co.in> wrote in message
news:cst3q8$4ro$1@www.eclipse.org...
> Hai , I have installed and configured eclipse in Redhat Linux 9.1 . But on
> Thank you,
> Surya.
FUDForum. Page generated in 1.09009 seconds
