Home » Eclipse Projects » Nebula » Alpha dist needs updated to reflect Snippet changes
Alpha dist needs updated to reflect Snippet changes [message #11775] Thu, 21 September 2006 14:28 Go to next message
Just was catching up on what has been happening with Nebula. Cool
CTableTree control!
Maybe this is already knowm, but the Snippets posted on eclips.org/nebula
site are out of sync with the Alpha distribution of the Grid and
Tree/Table control.
--Bill
Re: Alpha dist needs updated to reflect Snippet changes [message #11811 is a reply to message #11775] Thu, 21 September 2006 15:37 Go to previous messageGo to next message
Hi Bill,
In what way are they out of sync?
-Chris
> CTableTree control!
> eclips.org/nebula site are out of sync with the Alpha distribution of
> the Grid and Tree/Table control.
> --Bill
Re: Alpha dist needs updated to reflect Snippet changes [message #12455 is a reply to message #11811] Fri, 22 September 2006 07:28 Go to previous message
When API changes are made to the CTableTree, they need to be made in the
snippets as well. Because the website's snippets section points to CVS,
it becomes out of sync with the Alpha download as soon as something is
checked-in.
IMO, the website snippets should point to a version which matches the
widget download, as those two are more likely to be used together. If
people are intrigued with what they see, they should then start working
from CVS as soon as possible (while the widget is still in Alpha, that
is), grabbing both the widgets and their snippets.
I'll make the change for CTableTree shortly.
Chris Gross wrote:
> Hi Bill,
> -Chris
>> CTableTree control!
>> --Bill
Re: Alpha dist needs updated to reflect Snippet changes [message #565365 is a reply to message #11775] Thu, 21 September 2006 15:37 Go to previous message
Hi Bill,
-Chris
> CTableTree control!
> --Bill
Re: Alpha dist needs updated to reflect Snippet changes [message #565481 is a reply to message #11811] Fri, 22 September 2006 07:28 Go to previous message
checked-in.
Chris Gross wrote:
> Hi Bill,
> -Chris
>> CTableTree control!
>> --Bill
Previous Topic:cell events
Next Topic:variable CTableTreeCell
Current Time: Wed Jul 30 21:30:55 EDT 2025
Powered by FUDForum. Page generated in 0.04393 seconds
