Home » Eclipse Projects » Eclipse Platform » How to Customize Compiler Flags
How to Customize Compiler Flags [message #128533] Fri, 12 September 2003 15:32
Originally posted by: denabhoth.yahoo.com
i tried to figure out the following but without succes. I suppose there is
somewhere a featurein Eclipse allowing doint this but i am not aware about
it.
I have to comppile/and run my project with the flag -Dmbrola.base=/xxx/xxx
but i am not able to find out how to set it up neither for project or the
whole Eclipse. Is there a special way i have to run Eclipse? Note
mbrola.base is set up in the system as a variable.
thanks
regards
martin
Previous Topic:How to enable/disable Eclipse menu
Next Topic:Tiny DT example?
Current Time: Sun Jun 22 22:19:17 EDT 2025
Powered by FUDForum. Page generated in 0.18367 seconds
