Adding GMF to EMF model [message #128291] |
Tue, 22 May 2007 22:36  |
Originally posted by: exquisitus.example.com
See my thread in the GEF and EMF newsgroups. I'm just trying to get drag and drop to work (and GEF and EMF are apparently
inconsistent in this), and getting desparate...
So I guess I should use GMF, but I can't even get that installed properly:
There is a release Build 1.0.3 that is meant to work with Eclipse 3.2.
At http://download.eclipse.org/modeling/gmf/downloads/drops/R-1 .0.3-200702091900/index.php it gives the requirements, amongst them
"EMF OCL Build M200611161546". When I click on "build page" it says "Sorry! There are no builds yet available for this component."
When I try to get the plug-ins via the Update mechanism, I get errors like this:
Current configuration contains errors that are not corrected by the requested operation and more errors would be introduced. See
details for more information.
----- Current configuration problems -----
Graphical Modeling Framework Runtime (1.0.3.v20070202-1200-gW3quizrSB1Fxqp) requires feature "org.eclipse.emf.ocl (1.0.0)", or
compatible.
----- Configuration problems after the operation -----
CDO Utilities (0.7.1.v200610271316) requires feature "org.eclipse.net4j (0.7.1)", or compatible.
Eclipse Modeling Framework Technology Query OCL (1.1.0.v200703301543) requires plug-in "org.eclipse.ocl (1.1.0)", or compatible.
Net4j Examples (1.0.0.v200606271241) requires plug-in "org.eclipse.net4j".
EMF Model Query OCL Integration (1.1.0.v200704200841) requires plug-in "org.eclipse.ocl (1.1.0)", or compatible.
What do I have to do to get a GMF that I can use to get diagrams for my existing EMF stuff? I'm using the latest stable release of
Eclipse, EMF, etc. Perhaps I am the only person in the world to do so.
Re: Adding GMF to EMF model [message #128304 is a reply to message #128291] |
Tue, 22 May 2007 22:41  |
Oh great it's even "better" than I thought: I can't even use GMF 1.0.3 with RCP.
Who had the bright idea of mixing up all the version numbers that you can't do basic stuff with the current stable releases, and are
forced to use stuff that's not even properly tested yet?
If I come across as rude, that's because I've been slaving at this for days, and it's 4:40 am now and I have to get that DND working
by about 10.
FUDForum. Page generated in 0.04184 seconds
