Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » EMF Compare
EMF Compare [message #128062] Wed, 06 August 2008 01:14 Go to next message
Originally posted by: lokesh.katiyar.india.thalesgroup.com
I had tried to compare identical xmi files through EMF Compare. but every
time its showing differences. Then I tried to compare these file through
option available in eclipse (Compare with each other) its showing "There
is no difference between selected inputs".
I tried to set the prefrences "Ignore XMI_ID for Model Comparision" and
"Ignore Functional ID for model comparision" but still its giving problem
Please let me know where I am wrong.
and tell me what i have to do to get the same message from my plugin as
Eclipse is showing.
Lokesh
Re: EMF Compare [message #128074 is a reply to message #128062] Wed, 06 August 2008 01:55 Go to previous messageGo to next message
Hi Lokesh,
Such behavior is happening when EMF compare is considering the technical ID's.
If I understand correctly you're launching the comparison using a Java program, right ? The preferences are only taken in account when using right click=> Compare..., if you want to ignore the XMI_ID's while comparing in a java program you should pass the option like this :
Map options = new HashMap();
options.put(MatchOptions.OPTION_IGNORE_XMI_ID, Boolean.TRUE);
And then call the MatchService with these options:
MatchModel match = MatchService.doMatch(model1, model2,options);
Cédric
Lokesh Katiyar wrote:
> Hi
> Eclipse is showing.
> Thanks
> Lokesh
Re: EMF Compare [message #128111 is a reply to message #128074] Wed, 06 August 2008 04:06 Go to previous messageGo to next message
Hi Cadric,
you are correct that i am launching Comparision using java.
As you suggest i tried to set the MatchOptions but still same problem
occured.
Lokesh
Re: EMF Compare [message #128150 is a reply to message #128111] Wed, 06 August 2008 04:46 Go to previous message
--------------010602040002040802050903
Hi Lokesh,
First of all, what is the behavior you're expecting from the comparison?
You told that the GUI showed "no difference between the selected inputs"
while programmatic comparison detects differences in your models. Which
is right?
Then again, the dialog box you're shown in the GUI does not come from
EMF Compare. If I am not mistaken, it means org.eclipse.compare found
the two files to be identical byte-wise and then didn't bother to find
an associated comparison engine (which would mean this is the behavior
you are expecting when comparing through code).
Could you provide us with either the models you're trying to compare or
the type of differences that is inaccurately detected as well as the
type of objects on which they are? Please note that we have a somewhat
similar issue : https://bugs.eclipse.org/bugs/show_bug.cgi?id=242164 .
Laurent Goubet
Obeo
Lokesh Katiyar a
Re: EMF Compare [message #620188 is a reply to message #128062] Wed, 06 August 2008 01:55 Go to previous message
Hi Lokesh,
Cédric
> Hi
> Eclipse is showing.
> Thanks
> Lokesh
Re: EMF Compare [message #620191 is a reply to message #128074] Wed, 06 August 2008 04:06 Go to previous message
Hi Cadric,
occured.
Lokesh
Re: EMF Compare [message #620194 is a reply to message #128111] Wed, 06 August 2008 04:46 Go to previous message
Hi Lokesh,
is right?
Laurent Goubet
Obeo
Lokesh Katiyar a
Previous Topic:EMF Compare
Next Topic:JPOXMappingException: URI <X> does not translate to an eclass
Current Time: Sun Jul 27 01:44:29 EDT 2025
Powered by FUDForum. Page generated in 0.06304 seconds
