Home » Archived » Visual Editor (VE) » NullPointerException when displaying a visual class
NullPointerException when displaying a visual class [message #127978] Sat, 08 July 2006 05:48 Go to next message
Originally posted by: harel.ben-attia.comverse.com
i have a visual class which worked without any problems for a while. After
changing one of my own methods (i've changed a parameter in a constructor
call), the visual part became blank. looking at the log, i found the
exceptions below. clearing the cache did not solve the problem. After
restarting eclipse for several times, the problem was gone. If I remember
correctly, i've let the workbench save the file for me (i did not press
ctrl-S before running the application), which might have been the cause for
the problems.
The problem is gone now, but i'm afraid that it will return the same way it
started. Does anyone have an idea about the cause ?
RL
!ENTRY org.eclipse.ve.java.core 4 2 2006-07-08 12:34:16.859
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.ve.java.core".
!STACK 0
java.lang.IllegalStateException: IWAV0163E Expression is in invalid state
org.eclipse.jem.internal.proxy.core.Expression.checkForExpre ssion(Expression.java:438)
org.eclipse.jem.internal.proxy.core.Expression.mark(Expressi on.java:1980)
org.eclipse.ve.internal.java.core.BeanProxyAdapter.releaseBe anProxy(BeanProxyAdapter.java:1344)
org.eclipse.ve.internal.java.core.MemberContainerProxyAdapte r$2.run(MemberContainerProxyAdapter.java:253)
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:1044)
at org.eclipse.core.runtime.Platform.run(Platform.java:783)
org.eclipse.ve.internal.java.core.MemberContainerProxyAdapte r.releaseSetting(MemberContainerProxyAdapter.java:246)
org.eclipse.ve.internal.java.core.MemberContainerProxyAdapte r.releaseBeanProxy(MemberContainerProxyAdapter.java:309)
org.eclipse.ve.internal.java.core.MemberContainerProxyAdapte r.releaseBeanProxy(MemberContainerProxyAdapter.java:324)
org.eclipse.ve.internal.java.core.CompositionProxyAdapter.re leaseBeanProxy(CompositionProxyAdapter.java:339)
org.eclipse.ve.internal.java.core.MemberContainerProxyAdapte r.releaseBeanProxy(MemberContainerProxyAdapter.java:273)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$Setup.run(JavaVisualEditorPart.java:1911)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:76)
!ENTRY org.eclipse.ve.java.core 2 0 2006-07-08 12:34:16.859
!MESSAGE Exception thrown.
!STACK 0
!ENTRY org.eclipse.jem.proxy 2 0 2006-07-08 12:34:16.875
!MESSAGE
+++ Warning +++: Sat Jul 08 12:34:16 IDT 2006 Project
(UniLoaderConsole)-VM for UniLoaderConsole:err>
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:123)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3102)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2761)
org.eclipse.ve.internal.swt.targetvm.Environment$3.run(Envir onment.java:68)
!ENTRY org.eclipse.jem.proxy 2 0 2006-07-08 12:34:17.31
!STACK 0
org.eclipse.ve.internal.swt.CompositeManagerExtension.primSe tExtensionProxy(CompositeManagerExtension.java:81)
org.eclipse.ve.internal.swt.ControlManager$1.proxyResolved(C ontrolManager.java:172)
org.eclipse.jem.internal.proxy.core.ExpressionProxy.fireReso lved(ExpressionProxy.java:262)
org.eclipse.jem.internal.proxy.core.Expression.fireProxyReso lved(Expression.java:735)
org.eclipse.jem.internal.proxy.remote.REMExpression.processp ulledExpressionProxies(REMExpression.java:389)
org.eclipse.jem.internal.proxy.remote.REMExpression.pushInvo ke(REMExpression.java:974)
org.eclipse.jem.internal.proxy.core.Expression.invokeExpress ion(Expression.java:685)
org.eclipse.ve.internal.java.core.CompositionProxyAdapter.in itBeanProxy(CompositionProxyAdapter.java:311)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$Setup.run(JavaVisualEditorPart.java:1992)
!ENTRY org.eclipse.ve.java.core 2 0 2006-07-08 12:34:17.31
!STACK 0
IWAV0073I *** RemoteVM Exception - Trace from Remote VM:
org.eclipse.jem.internal.proxy.initParser.tree.NoExpressionV alueException:
Proxy id: 1
org.eclipse.jem.internal.proxy.initParser.tree.ExpressionPro cesser.pushExpressionProxy(ExpressionProcesser.java:829)
org.eclipse.jem.internal.proxy.vm.remote.ExpressionProcesser Controller.process(ExpressionProcesserController.java:320)
org.eclipse.jem.internal.proxy.vm.remote.ConnectionHandler.p rocessExpressionCommand(ConnectionHandler.java:602)
org.eclipse.jem.internal.proxy.vm.remote.ConnectionHandler.r un(ConnectionHandler.java:493)
org.eclipse.jem.internal.proxy.vm.remote.CallbackHandler.cal lbackWithParms(CallbackHandler.java:150)
org.eclipse.ve.internal.swt.targetvm.DisplayExec$1.run(Displ ayExec.java:109)
org.eclipse.jem.internal.proxy.vm.remote.RemoteVMServerThrea d.doCallback(RemoteVMServerThread.java:541)
org.eclipse.ve.internal.swt.targetvm.DisplayExec$ExecRunnabl e.run(DisplayExec.java:107)
IWAV0074I *** Local StackTrace:
org.eclipse.jem.internal.proxy.remote.REMThrowableBeanProxyP roxy:
Proxy id: 1
org.eclipse.jem.internal.proxy.remote.REMThrowableBeanTypePr oxy.createThrowableBeanProxy(REMThrowableBeanTypeProxy.java: 34)
org.eclipse.jem.internal.proxy.remote.REMThrowableBeanTypePr oxy.newBeanProxy(REMThrowableBeanTypeProxy.java:65)
org.eclipse.jem.internal.proxy.remote.REMStandardBeanProxyFa ctory.getBeanProxy(REMStandardBeanProxyFactory.java:459)
org.eclipse.jem.internal.proxy.remote.REMExpression.pushInvo ke(REMExpression.java:983)
!ENTRY org.eclipse.ve.java.core 4 0 2006-07-08 12:34:39.15
!STACK 0
org.eclipse.emf.ecore.impl.EStructuralFeatureImpl.getSetting Delegate(EStructuralFeatureImpl.java:790)
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eSettingDelegate (BasicEObjectImpl.java:822)
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eDynamicIsSet(Ba sicEObjectImpl.java:609)
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eIsSet(BasicEObj ectImpl.java:600)
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveFeatures(XMLS aveImpl.java:951)
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveElementID(XML SaveImpl.java:2272)
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveElement(XMLSa veImpl.java:889)
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveContainedMany (XMLSaveImpl.java:2001)
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveFeatures(XMLS aveImpl.java:1221)
org.eclipse.emf.ecore.xmi.impl.XMISaveImpl.writeTopObjects(X MISaveImpl.java:78)
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.traverse(XMLSaveI mpl.java:478)
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.save(XMLSaveImpl. java:206)
org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doSave(XMLRes ourceImpl.java:193)
org.eclipse.emf.ecore.resource.impl.ResourceImpl.save(Resour ceImpl.java:893)
org.eclipse.emf.ecore.resource.impl.ResourceImpl.save(Resour ceImpl.java:813)
org.eclipse.ve.internal.java.codegen.util.VEModelCacheUtilit y.doSaveCache(VEModelCacheUtility.java:158)
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.doSave(JavaSourceTranslator.java:1358)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart.doSave(JavaVisualEditorPart.java:2817)
at org.eclipse.ui.internal.SaveableHelper$1.run(SaveableHelper. java:95)
at org.eclipse.ui.internal.SaveableHelper$2.run(SaveableHelper. java:116)
org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:346)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:291)
org.eclipse.jface.window.ApplicationWindow$1.run(Application Window.java:624)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
org.eclipse.jface.window.ApplicationWindow.run(ApplicationWi ndow.java:621)
at org.eclipse.ui.internal.WorkbenchWindow.run(WorkbenchWindow. java:2134)
org.eclipse.ui.internal.SaveableHelper.runProgressMonitorOpe ration(SaveableHelper.java:122)
at org.eclipse.ui.internal.SaveableHelper.savePart(SaveableHelp er.java:100)
at org.eclipse.ui.internal.EditorManager.savePart(EditorManager .java:1154)
at org.eclipse.ui.internal.WorkbenchPage.savePart(WorkbenchPage .java:2714)
org.eclipse.ui.internal.WorkbenchPage.saveEditor(WorkbenchPa ge.java:2727)
at org.eclipse.ui.internal.SaveAction.run(SaveAction.java:69)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:996 )
at org.eclipse.jface.commands.ActionHandler.execute(ActionHandl er.java:117)
at org.eclipse.core.commands.Command.execute(Command.java:311)
org.eclipse.core.commands.ParameterizedCommand.execute(Param eterizedCommand.java:396)
org.eclipse.ui.internal.keys.WorkbenchKeyboard.executeComman d(WorkbenchKeyboard.java:459)
org.eclipse.ui.internal.keys.WorkbenchKeyboard.press(Workben chKeyboard.java:781)
org.eclipse.ui.internal.keys.WorkbenchKeyboard.processKeyEve nt(WorkbenchKeyboard.java:828)
org.eclipse.ui.internal.keys.WorkbenchKeyboard.filterKeySequ enceBindings(WorkbenchKeyboard.java:550)
org.eclipse.ui.internal.keys.WorkbenchKeyboard.access$3(Work benchKeyboard.java:493)
org.eclipse.ui.internal.keys.WorkbenchKeyboard$KeyDownFilter .handleEvent(WorkbenchKeyboard.java:117)
at org.eclipse.swt.widgets.Display.filterEvent(Display.java:919 )
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:842)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:867)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:852)
at org.eclipse.swt.widgets.Widget.sendKeyEvent(Widget.java:880)
at org.eclipse.swt.widgets.Widget.sendKeyEvent(Widget.java:876)
at org.eclipse.swt.widgets.Widget.wmChar(Widget.java:1190)
at org.eclipse.swt.widgets.Control.WM_CHAR(Control.java:3135)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3038 )
at org.eclipse.swt.widgets.Display.windowProc(Display.java:3751 )
at org.eclipse.swt.internal.win32.OS.CallWindowProcW(Native Method)
at org.eclipse.swt.internal.win32.OS.CallWindowProc(OS.java:158 0)
at org.eclipse.swt.internal.BidiUtil.windowProc(BidiUtil.java:6 49)
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:16 56)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2756)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
Re: NullPointerException when displaying a visual class [message #128161 is a reply to message #127978] Mon, 10 July 2006 10:27 Go to previous message
Originally posted by: richkulp.us.NO_SPAM.ibm.com
I don't know what caused these. If it happens again we can see if it can
be reproduced by sending us your class that failed.
Rich Kulp
Re: NullPointerException when displaying a visual class [message #613494 is a reply to message #127978] Mon, 10 July 2006 10:27 Go to previous message
Rich Kulp
Previous Topic:VE problem after eclipse updates
Next Topic:Best way to incorporate an existing visual class in another window
Current Time: Mon Jul 14 19:01:24 EDT 2025
Powered by FUDForum. Page generated in 0.04932 seconds
