Home » Archived » EPP » No update site for 3.5 externally available
No update site for 3.5 externally available [message #11711] Thu, 02 July 2009 04:11 Go to next message
Hello
I'm trying to package my own 3.5 using epp but unfortunately no update
site seems to be externally available.
Trying to mirror the p2 repositories seems to fail using the
org.eclipse.equinox.p2.metadata.repository application.
I get
Unable to read repository at
http://download.eclipse.org/eclipse/updates/3.5/content.xml.
http://download.eclipse.org/technology/epp/packages/galileo/ content.xml.
http://download.eclipse.org/releases/galileo/content.xml.
Directly opening the page http://download.eclipse.org/eclipse/updates/3.5
in a browser yields a 404 where as the url
http://download.eclipse.org/eclipse/updates/3.5milestones/
is available displaying the nevada test site.
I'm really wondering what I'm doing wrong because I had no problems
fetching these repositories from within eclipse p2 installer.
Jens
Re: No update site for 3.5 externally available [message #11817 is a reply to message #11711] Fri, 10 July 2009 14:29 Go to previous message
Originally posted by: eclipseng.arthorne.com
The eclipse/updates/3.5 repository is available, but it no longer uses a
content.xml file. There is more information on using the mirroring
applications here:
http://help.eclipse.org/galileo/topic/org.eclipse.platform.d oc.isv/guide/p2_mirror.html
Note you'll need to use the Eclipse 3.5 mirroring application due to
changes in the site format that aren't compatible with Eclipse 3.4.
Jens KŸübler wrote:
> Hello
> I get
> Jens
Re: No update site for 3.5 externally available [message #579290 is a reply to message #11711] Fri, 10 July 2009 14:29 Go to previous message
applications here:
Jens KŸübler wrote:
> Hello
> I get
> Jens
Previous Topic:How to build a package locally
Next Topic:UDC in my RCP
Current Time: Sun May 11 03:58:40 EDT 2025
Powered by FUDForum. Page generated in 0.04931 seconds
