Home » Eclipse Projects » Equinox » [DS] Why is it necessary to activate bundles offering services?
[DS] Why is it necessary to activate bundles offering services? [message #127920] Wed, 25 March 2009 17:41 Go to next message
Hi everyone,
I've been lately experimenting with Declarative Services and faced and
issue I don't quite understand. Apparently, we need to activate bundles
offering services if we want org.eclipse.equinox.ds to register it to
the service registry. I don't exactly see the point of this. Wasn't
declarative services all about lazy registration? What's the concept of
delayed service for then? Am I missing something here?
Doesn't Eclipse's Extension Point work that in such a lazy way?
Thanks in advance,
Víctor.
Re: [DS] Why is it necessary to activate bundles offering services? [message #127934 is a reply to message #127920] Wed, 25 March 2009 19:12 Go to previous messageGo to next message
Víctor Roldán Betancort wrote:
> Hi everyone,
The lifecycle of the service registry and the extension registry are
different. Services are only available when the bundle is in the ACTIVE
state. Extensions are available in the RESOLVED state.
In the R4.2 version of DS, DS allows to look for bundles in the STARTING
state (lazy activation). Therefore, you can add:
Bundle-ActivationPolicy: lazy
Once you do that, DS should be able to work the way you expect it... as
long as DS is started of course!
Chris Aniszczyk | EclipseSource Austin | +1 860 839 2465
http://twitter.com/eclipsesource | http://twitter.com/caniszczyk
Re: [DS] Why is it necessary to activate bundles offering services? [message #127953 is a reply to message #127934] Thu, 26 March 2009 11:38 Go to previous messageGo to next message
Chris,
thanks for your feedback. From intuition I thought DS register something
like a "proxy" to a service, so as soon the service is demanded, the
bundle gets activated and the proxy is resolved. I read the OSGi spec
for DS but couldn't clarify this issue. Only when I looked at the code
and saw (if bundle.getState() == Bundle.ACTIVE)...
I guess the implementation of R4.2 is not included in latest (HEAD)
org.eclipse.equinox.ds, right?
Cheers
Víctor.
>> Hi everyone,
>> bundles offering services if we want org.eclipse.equinox.ds to
>> register it to the service registry. I don't exactly see the point of
>> this. Wasn't declarative services all about lazy registration? What's
>> the concept of delayed service for then? Am I missing something here?
> Cheers,
Re: [DS] Why is it necessary to activate bundles offering services? [message #128065 is a reply to message #127920] Sun, 29 March 2009 22:50 Go to previous messageGo to next message
Hi Vik,
Note also that a classloader is not created immediately on activation of
a bundle if that bundle does not declare an activator and all offered
services are lazy (default).
Cheers
/Eike
Víctor Roldán Betancort schrieb:
> Hi everyone,
> Thanks in advance,
> Víctor.
Re: [DS] Why is it necessary to activate bundles offering services? [message #128078 is a reply to message #127953] Mon, 30 March 2009 05:05 Go to previous messageGo to next message
Victor,
AFAIK, DS doesn't use proxies (in contrast to Spring DM). Parts of R4.2
should be in CVS HEAD, too.
I found the slides in [1] very helpful.
Stefan.
[1]
https://www.gpublication.com/eclipse/#requestedContent=conte ntID://EclipseConferences/EC2009/245
> Chris,
> Cheers
> Víctor.
>>> Hi everyone,
>>> and issue I don't quite understand. Apparently, we need to activate
>> ACTIVE state. Extensions are available in the RESOLVED state.
>> STARTING state (lazy activation). Therefore, you can add:
>> as long as DS is started of course!
>> Cheers,
Re: [DS] Why is it necessary to activate bundles offering services? [message #128176 is a reply to message #128078] Tue, 31 March 2009 07:05 Go to previous messageGo to next message
Stefan,
thanks for the hint. I'm using ganymede, so HEAD is not an option :(
I already created a special bundle that analyzes all registered bundles
and activates them if they define services component. Is not the best
solution, but at least is better than setting all service-providing
bundles to start at eclipe's startup!
Thanks for the slides, quite interesting!
ViK
Stefan Roeck escribió:
> Victor,
> Stefan.
> [1]
>> Chris,
>> something like a "proxy" to a service, so as soon the service is
>> demanded, the bundle gets activated and the proxy is resolved. I read
>> the OSGi spec for DS but couldn't clarify this issue. Only when I
>> looked at the code and saw (if bundle.getState() == Bundle.ACTIVE)...
>> Cheers
>> Víctor.
>>>> Hi everyone,
>>>> of this. Wasn't declarative services all about lazy registration?
>>>> What's the concept of delayed service for then? Am I missing
>>>> something here?
>>> Cheers,
Re: [DS] Why is it necessary to activate bundles offering services? [message #128188 is a reply to message #128065] Tue, 31 March 2009 10:47 Go to previous message
Eike,
thanks for comment. This is indeed quite interesting: it would imply
that, if properly defined, eager start of our bundles won't cost that
much :D (I didn't know, but it seems, according to the slides Stefan
pointed out, creating the classloader is a bit expensive).
ViK.
Eike Stepper escribió:
> Hi Vik,
> Cheers
> /Eike
> http://thegordian.blogspot.com
>> Hi everyone,
>> Thanks in advance,
>> Víctor.
Previous Topic:equinox and p2 Aha! Moment Needed
Next Topic:any pointers on setting up a Tomcat/OSGI dev environemnt?
Current Time: Thu Jul 17 22:35:22 EDT 2025
Powered by FUDForum. Page generated in 0.12071 seconds
