Home » Eclipse Projects » Equinox » org.eclipse.test with dependency on org.eclipse.ui
org.eclipse.test with dependency on org.eclipse.ui [message #127733] Thu, 19 March 2009 03:39 Go to next message
We would like to use the eclipse test framework to run our unit tests
during the automated headless builds. org.eclipse.test offers two
testrunners (as ant targets): core-test and ui-test. For many of our
projects the core-test will suffice since these apps do not have uis.
Unfortunately, the bundle org.eclipse.test has a dependency on
org.eclipse.ui. That means that we have to set up a lot of bundles to
get the test to run.
Would it be possible to refactor org.eclipse.test into two bundles where
one of them has no dependency to org.eclipse.ui?
Peter
Re: org.eclipse.test with dependency on org.eclipse.ui [message #127759 is a reply to message #127733] Thu, 19 March 2009 10:53 Go to previous message
You can open an enhancement request at https://bugs.eclipse.org/bugs
Eclipse Platform (start with UI).
If you refactor it yourself and prove that it still works (the automated
test framework has to continue to run) that would raise its priority.
PW
Paul Webster
Previous Topic:How To Get Example SecurePreferencesFactory to work
Next Topic:manifest.mf file
Current Time: Wed Jul 16 20:14:49 EDT 2025
Powered by FUDForum. Page generated in 0.05906 seconds
