Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Teneo and Hibernate's Session.load() issue
Teneo and Hibernate's Session.load() issue [message #127675] Tue, 29 July 2008 11:59 Go to next message
Hi.
I have EMF model, which defines only one class "A", without any
attrinutes. I map this to DB using Teneo/Hibernate:
session.beginTransaction();
A a = TestFactory.eINSTANCE.createA();
Long aId = (Long) session.save(a);
session.getTransaction().commit();
Ok. Then I try to load this object from DB:
A a2 = (A) session.load("A", aId);
Works fine. But I need to load objects from DB not by EMF name, but by
interface/instance name/class. Hibernate provides me with such method:
A a3 = (A) session.load(A.class, aId);
But it fails with:
org.hibernate.MappingException: Unknown entity: test.A
So I look into generated "hibernate.hbm.xml":
<class name="test.impl.AImpl" entity-name="A" ...
So what do I think? Maybe Teneo places invalid value into "entity-name"
attribute for class mapping, so I cannot load classes by interface, and
have to provide name string w/o package specification? Of cource, I can
always get this string by traversing through EPackage.Registry, but its
very perfomance damaging option.
Thanks.
Re: Teneo and Hibernate's Session.load() issue [message #127688 is a reply to message #127675] Tue, 29 July 2008 12:12 Go to previous messageGo to next message
Hi Mikhail,
You can control the entity-name in different ways (see the documentation on www.elver.org) for more
information. Teneo uses the hibernate entity-mapping because it makes it possible to support
dynamic-emf.
From a design point of view I find it nicer to use model concepts such as the eclassname than the
java implementation names. Having said that I fully understand that there are different views on this.
If a mapping has the entity-name set then hibernate throws errors when trying to use the classname
(as you try to do).
To disable the use of the entity-name there is a hidden feature (not tested) which you can enable as
follows.
1) Create your own class which inherits from org.eclipse.emf.teneo.hibernate.mapper.MappingContext
2) Override one method: forceUseOfInstance and let it return true.
3) Then do this:
dataStore.getExtensionManager().registerExtension(MappingCon text.class.getName(),
MyGreatMappingContext.class.getName();
before calling initialize on the datastore.
If you have time can you enter a bugzilla to make this option driven? Then I can add testcases for
this also.
btw, support for Teneo is given on the EMF newsgroup to which I cross-posted.
gr. Martin
Mikhail Kadan wrote:
> Hi.
> But it fails with:
> Thanks.
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Teneo and Hibernate's Session.load() issue [message #127728 is a reply to message #127688] Wed, 30 July 2008 04:21 Go to previous messageGo to next message
I've tried this and I got:
org.hibernate.HibernateException: Could not build tuplizer
[org.eclipse.emf.teneo.hibernate.tuplizer.EMFTuplizer]
org.hibernate.tuple.entity.EntityEntityModeToTuplizerMapping .buildEntityTuplizer(EntityEntityModeToTuplizerMapping.java: 110)
org.hibernate.tuple.entity.EntityEntityModeToTuplizerMapping . <init>(EntityEntityModeToTuplizerMapping.java:48)
org.hibernate.tuple.entity.EntityMetamodel.<init>(EntityMetamodel.java:295)
org.hibernate.persister.entity.AbstractEntityPersister.<init >(AbstractEntityPersister.java:434)
org.hibernate.persister.entity.JoinedSubclassEntityPersister . <init>(JoinedSubclassEntityPersister.java:91)
org.hibernate.persister.PersisterFactory.createClassPersiste r(PersisterFactory.java:58)
org.hibernate.impl.SessionFactoryImpl.<init>(SessionFactoryImpl.java:226)
org.hibernate.cfg.Configuration.buildSessionFactory(Configur ation.java:1294)
org.eclipse.emf.teneo.hibernate.HbSessionDataStore.buildSess ionFactory(HbSessionDataStore.java:162)
org.eclipse.emf.teneo.hibernate.HbSessionDataStore.initializ e(HbSessionDataStore.java:82)
at teneo.Application.start(Application.java:42)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:382)
at org.eclipse.equinox.launcher.Main.main(Main.java:1212)
Caused by: java.lang.reflect.InvocationTargetException
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Nativ e Method)
sun.reflect.NativeConstructorAccessorImpl.newInstance(Native ConstructorAccessorImpl.java:39)
sun.reflect.DelegatingConstructorAccessorImpl.newInstance(De legatingConstructorAccessorImpl.java:27)
at java.lang.reflect.Constructor.newInstance(Constructor.java:4 94)
org.hibernate.tuple.entity.EntityEntityModeToTuplizerMapping .buildEntityTuplizer(EntityEntityModeToTuplizerMapping.java: 107)
... 23 more
Caused by: java.lang.NullPointerException
org.eclipse.emf.teneo.util.StoreUtil.getEStructuralFeature(S toreUtil.java:360)
org.eclipse.emf.teneo.hibernate.HbUtil.getPropertyAccessor(H bUtil.java:123)
org.eclipse.emf.teneo.hibernate.tuplizer.EMFTuplizer.getProp ertyAccessor(EMFTuplizer.java:262)
org.eclipse.emf.teneo.hibernate.tuplizer.EMFTuplizer.buildPr opertyGetter(EMFTuplizer.java:138)
org.hibernate.tuple.entity.AbstractEntityTuplizer.<init>(AbstractEntityTuplizer.java:125)
org.eclipse.emf.teneo.hibernate.tuplizer.EMFTuplizer.<init>(EMFTuplizer.java:76)
... 28 more
Re: Teneo and Hibernate's Session.load() issue [message #127741 is a reply to message #127728] Wed, 30 July 2008 04:29 Go to previous message
Yes an untested/hidden feature.... :-(. Can you enter a bugzilla for this? I will do a new build in
a few days (around the weekend) for this and some other open issues.
gr. Martin
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 23 more
> at
> at
> at
> at
> at
> at
> ... 28 more
The Netherlands
Re: Teneo and Hibernate's Session.load() issue [message #620159 is a reply to message #127675] Tue, 29 July 2008 12:12 Go to previous message
Hi Mikhail,
dynamic-emf.
(as you try to do).
follows.
3) Then do this:
this also.
gr. Martin
> Hi.
> But it fails with:
> Thanks.
The Netherlands
Re: Teneo and Hibernate's Session.load() issue [message #620162 is a reply to message #127688] Wed, 30 July 2008 04:21 Go to previous message
... 23 more
... 28 more
Re: Teneo and Hibernate's Session.load() issue [message #620163 is a reply to message #127728] Wed, 30 July 2008 04:29 Go to previous message
gr. Martin
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 23 more
> at
> at
> at
> at
> at
> at
> ... 28 more
The Netherlands
Previous Topic:[EMF Compare] How to deactivate
Next Topic:[Teneo] Cascade deletes causing not null constraint violations.
Current Time: Sun Jul 27 12:42:03 EDT 2025
Powered by FUDForum. Page generated in 0.03710 seconds
