Cannot see the connection during creation [message #11685] |
Mon, 01 July 2002 03:00  |
i'm trying to create a connection between two editparts on my editor, and
during the creation i can see the connection only when the cursor is above
the target of the connection. i have defined connection anchors for my
editparts and when i see the connection (i.e., the cursor is above the
target), the connection look fine and exactly the way i want it.
any ideas
thanks
yoav
Re: Cannot see the connection during creation [message #12226 is a reply to message #12223] |
Wed, 03 July 2002 14:00  |
Originally posted by: none.ibm.com
I do not have the June 4th code on my machine. Can you reproduce this with
the Logic example?
"Yoav Rubin" <yoav@il.ibm.com> wrote in message
news:afv5is$am0$1@rogue.oti.com...
> all i can see after i select the source of the connection , and during the
> cursor move is a point near the cursor, and no line to represent the
> connection. i've looked into GEF sources, but i couldn't find any idea
> what am i doing wrong, i've setted the sourceEditPart of the request to
> the actuall edit part, and it is returning the appropriate anchor (and
> these methods are called, i have verified it), but still, i get the same
> dot. any idea?
> Randy Hudson wrote:
> > See AbstractConnectionCreationTool:
> > protected void showSourceFeedback()...
FUDForum. Page generated in 0.04059 seconds
