Home » Eclipse Projects » Subversive » I am unable to compare branched code with latest trunk code
I am unable to compare branched code with latest trunk code [message #11680] Tue, 15 January 2008 09:51 Go to next message
I am using the Subversive plugins 0.7.0.v20071222 on Eclipse 3.4M4.
My SVN repository has the ordinary structire
<url>/trunk/mypluginproj/...
<url>/tags/20071201/mypluginproj/...
<url>/tags/20071202/mypluginproj/...
<url>/branches/from20071202/mypluginproj/...
when I check out the project from the branch (and the branch was created
from a tag meant to be a snapshot of some days ago)
I am unable to compare a resource in the project with the resource as it
currently exist under trunk.
can anyone please explain this behavior - which I find limiting when
trying to backport from trunk to a branch - ?
Re: I am unable to compare branched code with latest trunk code [message #11752 is a reply to message #11680] Wed, 16 January 2008 11:57 Go to previous message
Originally posted by: alexander.gurov.polarion.org
Hi Edoardo,
Current Subversive version has some issues with the compare functionality.
We've reworked this code according to changes in the SVN 1.5. Also we have
fixed some issues which are related not only to the client library but to
Subversive itself.
Build which contains these changes will be available at the end of this
week.
With the SVN 1.4 compatible connectors compare will not work for folders.
SVN 1.5 compatible connectors allow to compare folders also. But please
note that these connectors are not stable and SVN 1.5 working copy format
is not compatible with SVN 1.4 one.
Previous Topic:Re: new Subversive breaks Buckminster support
Next Topic:Multiple project tag creation issue
Current Time: Sun Jul 13 11:49:17 EDT 2025
Powered by FUDForum. Page generated in 0.03881 seconds
