Home » Language IDEs » C / C++ IDE (CDT) » make file for library
make file for library [message #127408] Tue, 16 November 2004 17:51 Go to next message
I have written a simple C++ class.
I want it to server as a library (not an executable) on both windows and
linux platforms. Currently the make file is written as for creating an
executable (below). How can I modify it so that it creates a library.
MyTest.exe : MyTest.o
g++ -o MyTest.exe MyTest.o
MyTest.o : MyTest.cpp
g++ -c MyTest.cpp
all : MyTest.exe
clean :
-rm MyTest.exe MyTest.o
Re: make file for library [message #127652 is a reply to message #127408] Thu, 18 November 2004 04:24 Go to previous messageGo to next message
> g++ -c MyTest.cpp
> all : MyTest.exe
> clean :
Here is makefile for library
libMyTest.a : MyTest.o
ar -rc libMyTest.a MyTest.o
g++ -c MyTest.cpp
all : MyTest.a
clean :
-rm libMyTest.a MyTest.o
CC Vural
Re: make file for library [message #127665 is a reply to message #127408] Thu, 18 November 2004 05:12 Go to previous messageGo to next message
Originally posted by: johan.nosp.m.appeal.se
Creating libraries in a platform independent fashion is a mess.
You could use Libtool (which will probably force you into Automake and Autoconf
as well), but that isn't without a certain threshold either.
Anyway, you'll probably have to study to build your cross platform library.
Good luck :-).
Regards //Johan
> g++ -c MyTest.cpp
> all : MyTest.exe
> clean :
Re: make file for library [message #127745 is a reply to message #127652] Thu, 18 November 2004 14:56 Go to previous messageGo to next message
CC,
Thank you , but it doesn't seem to work
It doesn't like the 2nd line, but it doesn't say why,
there is just a red X on the left.
Does that line look correct to you?
>> g++ -c MyTest.cpp
>> all : MyTest.exe
>> clean :
> g++ -c MyTest.cpp
> all : MyTest.a
> clean :
> CC Vural
makefile:2: *** missing separator. Stop. [message #127770 is a reply to message #127745] Thu, 18 November 2004 15:09 Go to previous messageGo to next message
oh, here's the error:
make -k all
(I was looking under the Problems tab, this is in the Console tab)
What does this mean?
Googling doesn't help much
Re: makefile:2: *** missing separator. Stop. [message #127822 is a reply to message #127770] Fri, 19 November 2004 02:24 Go to previous messageGo to next message
> make -k all
Use "TAB" at the begining of the second line.
CC Vural
Re: make file for library [message #127962 is a reply to message #127652] Fri, 19 November 2004 13:16 Go to previous messageGo to next message
SCons is capable of building on multiple platforms.
I wrote a SCons Builder Plugin for Eclipse. Although I use only Linux it
should work on Windows, too. Fell free to give it a try.
For more information see
http://nic-nac-project.de/~lothar/eclipse/update/SConsBuilde rPlugin.html
The plugin is registed at http://eclipse-plugins.2y.net.
If you like it you can rate it at
http://eclipse-plugins.2y.net/eclipse/plugin_details.
Lothar
thank you very much [message #127986 is a reply to message #127822] Fri, 19 November 2004 18:31 Go to previous message
Previous Topic:change background color
Next Topic:upgrade to RedHat Fedora Core 3 broke Eclipse 3.0
Current Time: Sun Jul 27 01:41:59 EDT 2025
Powered by FUDForum. Page generated in 0.06935 seconds
