Home » Newcomers » Newcomers » Invocation Target Exception
Invocation Target Exception [message #127399] Tue, 03 January 2006 02:49 Go to next message
Originally posted by: jfallsen.start.no
i get this error what's wrong
IWAV0055I Java Bean Testing started with the main
methodjava.lang.reflect.InvocationTargetException
org.eclipse.ve.internal.java.vce.launcher.remotevm.JavaBeans Launcher.main(JavaBeansLauncher.java:86)
Caused by: java.lang.NoClassDefFoundError:
org/springframework/beans/factory/xml/XmlBeanFactory
at Testing.main(Testing.java:19)
... 5 more
IWAV0052E Invocation Target Exception creating Testing
Best Regards
Jan Fredrik Fallsen
Re: Invocation Target Exception [message #127401 is a reply to message #127399] Tue, 03 January 2006 02:58 Go to previous message
Originally posted by: osadeh.gmail.com
See the NoClassDefFoundError for
org/springframework/beans/factory/xml/XmlBeanFactory class
This class is not in your application classpath. If you're running a
main() from within Eclipse, make sure the jar is added to the classpath
in your Run/Debug configuration; if you're testing a plugin, make sure
the jar is exported with your plugin and included in the classpath
(Build/Runtime tabs of plugin.xml).
HTH,
Oren
Jan Fredrik Fallsen wrote:
> Hi
> at
> at
> at
> ... 5 more
> Best Regards
> Jan Fredrik Fallsen
Previous Topic:Server Error "OutputPropertiesFactory"
Next Topic:Error log
Current Time: Fri Jul 18 04:43:46 EDT 2025
Powered by FUDForum. Page generated in 0.52870 seconds
