VE install and run problem [message #127187] |
Thu, 29 June 2006 20:13  |
Originally posted by: info.elzk.sk
I have unstall eclipse 3.1.2, emf-sdo-xsd-SDK-2.2.0RC9a.zip,
GEF-ALL-3.1.1.zip, VE-SDK-1.1.0.1.zip.
On my computer is Windows XP+SP2, j2re-1_4_2_12-windows-i586-p.exe and
j2sdk-1_4_2_12-windows-i586-p.exe installed.
Any plug-in(EMF,GEF,VE) is enabled.
If I create new Java Project and in Package explorer select "new" (from
right mouse click menu) then is not in this section "Visual Class".
If I click(right mouse button) on .java file in Package explorer and
select "Open with" then is not in this section "Visual editor".
I cannot run Visual Editor. Please help.
Re: VE install and run problem [message #127475 is a reply to message #127449] |
Mon, 03 July 2006 08:38  |
Originally posted by: jamesrome.gmail.com
Jeff Myers wrote, On 7/2/2006 9:59 PM:
> Jim,
> You may have to reset the Java perspective in order to get the VE to
> show up in the New menu. In the Java perspective, go to Window->Reset
> Perspective.
> Hope this helps,
> - Jeff
That worked :-)
It seems to me that this should happen automatically when one installs the
Callisto tools. I surely would not have figured this out on my own.
Jim
Re: VE install and run problem [message #613424 is a reply to message #127187] |
Thu, 29 June 2006 20:35  |
In message is a bug.. correct is: "I have INSTALL..."
And when i select in package explorer "New"->"Other"->Java then is not in
this section VE.
Please help me run VE.
Thanks.
Re: VE install and run problem [message #613425 is a reply to message #127200] |
Fri, 30 June 2006 05:17  |
Originally posted by: radams.omf.net
hi Peter,
I'm a newbie myself...but try using the toolbar. There is a small green
(with a white C and +)....click the downarrow beside it and see if visual
class is there. Hope this works.
Randy
Re: VE install and run problem [message #613428 is a reply to message #127187] |
Fri, 30 June 2006 09:48  |
Peter,
VE 1.1.0.1 requires EMF 2.1, and will not work with 2.2.0RC9a. So
either install EMF 2.1, or install VE 1.2 which will be released later
today (which works with EMF 2.2)
Hope this helps,
- Jeff
Re: VE install and run problem [message #613436 is a reply to message #127299] |
Sun, 02 July 2006 15:54  |
There is a bug here in the Callisto 3.2. It works fine on Windows. But on
Linux (several different machines), there is no "Visual Class" entry when
you right click on the Project and do "New". I do see the Vicual Class if
I click next to the C, but this is very unobvious, and I spent a lot of
time updating classes, or trying to to fix this.
Why isn't the choice in the "New" menu? I am teaching a class on this in a
week, and want to make it as easy as possible for the HS kids.
Re: VE install and run problem [message #613437 is a reply to message #127418] |
Sun, 02 July 2006 15:57  |
This is a bug. In the Help page it says
"In the Java perspective, click File > New > Visual Class. The New Java Visual
Class wizard opens." This only happens in Windows for me.
Jim Rome wrote, On 7/2/2006 3:54 PM:
> on Linux (several different machines), there is no "Visual Class" entry
> when you right click on the Project and do "New". I do see the Vicual
> Class if I click next to the C, but this is very unobvious, and I spent
> a lot of time updating classes, or trying to to fix this.
> a week, and want to make it as easy as possible for the HS kids.
Re: VE install and run problem [message #613441 is a reply to message #127449] |
> Jim,
> Perspective.
> Hope this helps,
> - Jeff
That worked :-)
Jim
FUDForum. Page generated in 0.07024 seconds
