Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » org.eclipse.emf.teneo.hibernate: invalid mapping
org.eclipse.emf.teneo.hibernate: invalid mapping [message #127137] |
Mon, 14 July 2008 09:36  |
Hello!
I have a problem to initialize my HbDataStore from an EPackage:
Exception:
15:14:23 ERROR org.hibernate.util.XMLHelper ==> Error parsing XML: XML
String(1809) The content of element type "subclass" must match
" (meta*,tuplizer*,synchronize*,(property|many-to-one|one-to-o ne|component|dynamic-component|any|map|set|list|bag|idbag|ar ray|primitive-array)*,join*,subclass*,loader?,sql-insert?,sq l-update?,sql-delete?,resultset*,(query|sql-query)*) ".
org.hibernate.MappingException: invalid mapping
at org.hibernate.cfg.Configuration.addXML(Configuration.java:38 2)
org.eclipse.emf.teneo.hibernate.HbSessionDataStore.mapModel( HbSessionDataStore.java:156)
org.eclipse.emf.teneo.hibernate.HbSessionDataStore.initializ e(HbSessionDataStore.java:73)
XML cutting:
<!DOCTYPE hibernate-mapping PUBLIC "-//Hibernate/Hibernate Mapping DTD
3.0//EN" "http://hibernate.sourceforge.net/hibernate-mapping-3.0.dtd">
<subclass name="test.ServerPublisher" entity-name="ServerPublisher"
abstract="true" lazy="false" extends="MessageReceiver"
discriminator-value="ServerPublisher">
Re: org.eclipse.emf.teneo.hibernate: invalid mapping [message #127154 is a reply to message #127137] |
Tue, 15 July 2008 06:56  |
Hi Alexey,
Can you post the complete subclass part? It goes wrong somewhere inside.
I also crossposted to the emf newsgroup as this is the place where support is given for Teneo (since
the Eclipse 3.4 release).
gr. Martin
Alexey Dubrovskiy wrote:
> Hello!
> Exception:
> at
> at
> XML cutting:
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: org.eclipse.emf.teneo.hibernate: invalid mapping [message #620115 is a reply to message #127137] |
Hi Alexey,
gr. Martin
> Hello!
> Exception:
> at
> at
> XML cutting:
The Netherlands
Current Time: Sun Jul 27 06:17:34 EDT 2025
Powered by FUDForum. Page generated in 0.03874 seconds
