Home » Language IDEs » C / C++ IDE (CDT) » CDT and SDL howto ??
CDT and SDL howto ?? [message #127108] |
Sat, 13 November 2004 20:25  |
Originally posted by: efthym.gmx.net
Hi all,
I just installed Eclipse with CDT and i'm trying to compile some program=
s =
that include the SDL library with no luck. Tried including =
/usr/include/SDL and the sdl-config --cflags and sdl-config --libs. =
Searching on eclipse.org (or anywhere else) didn't reveal anything.
Am i missing something ? What should I check for ?
Anybody that has had success with this PLEASE HELP !
I'm using eclipse 3.0.1 with cdt 2.0.2.
Thanx in advance
Re: CDT and SDL howto ?? [message #127563 is a reply to message #127500] |
Wed, 17 November 2004 13:44   |
Originally posted by: dschaefe.ca.ibm.com
"Martin Wood" <martin@ideaworks3d.com> wrote in message
news:cnftoj$249$1@www.eclipse.org...
> thinking about it, this seems to imply that the option of adding an
external include path doesnt have any effect for
> an unmanaged build. (I tried using the same setup as you and got the same
results)
You are correct, as far as the build goes. The Include Paths in the
properties of standard make are used by CDT's internal parser for all our
parser based features such as search, content assist, etc.
> I havent tried this using a managed build, which I think would work using
the external paths because the managed build
> manager would just write this into the makefile.
I have successfully used managed make with SDL. Simply put the output of
sdl-config in the right spots in the managed make properties. This stuff
should be pretty static anyway.
Doug
> so i think it all makes sense.
> martin
> Martin Wood wrote:
> > Try using
> > #include <SDL/SDL.h>
> > which means you shouldnt need to add the external include path in the
> > project properties (assuming the /usr/include is in your default include
> > path)
> > good luck
> > martin
> > Efthym wrote:
> >> Hi Doug,
> >> I tried the Managed Make project but couldn't get anywhere with that.
> >> In the Unmanaged Make Project, i put the includes under
> >> Project->Properties->Include Paths->Add external include. There I put
> >> "/usr/include/SDL". After that, the path is shown in the C/C++
> >> Project View .
> >> In the makefile I have "SDL_CFLAGS := $(shell sdl-config --cflags)" and
> >> "SDL_LDFLAGS := $(shell sdl-config --libs)"
> >> There is only one main.cpp file in my project which "include <SDL.h>".
> >> When I try to compile, I keep getting a "SDL.h: No such file or
> >> directory". All the rest of the errors I think are caused because of
> >> this).
> >> I hope this helps.
> >> Thanx
> >> Efthym
Re: CDT and SDL howto ?? [message #127576 is a reply to message #127563] |
Wed, 17 November 2004 14:08   |
External includes dont work even in managed builds. I used
'$(shell sdl-config --cflags)' in the Build->Compiler->Miscellaneous and=
'$(shell sdl-config --libs)' in Build->Linker->Miscellaneous
(is this right ??)
As for the includes, they dont seem to work even if managed build is use=
d.
If set the relative path in the include statement, the file is found. I'=
m =
using an external library SDLGUI. So I have
'#include <SDL/SDLGUI.h>'
and the compiler stops complaining about the missing file. but then I ge=
t
arraysR.o(.text+0x35): In function `cont()':
: undefined reference to `SDLGUI::GetItem(int)'
The GetItem() method is public in the SDLGUI.h . For some reason though=
it doesn't find it. This goes for all methods in SDLGUI that are =
referenced in arraysR.cpp.
Maybe I'm missing something.
Efthymios
On Wed, 17 Nov 2004 13:44:55 -0500, Doug Schaefer <dschaefe@ca.ibm.com> =
>> an unmanaged build. (I tried using the same setup as you and got the =
>> same
> results)
> properties of standard make are used by CDT's internal parser for all =
our
>> I havent tried this using a managed build, which I think would work =
>> using
> I have successfully used managed make with SDL. Simply put the output =
of
> sdl-config in the right spots in the managed make properties. This stu=
ff
> Cheers,
> Doug
>> martin
>> Martin Wood wrote:
>> > Try using
>> > which means you shouldnt need to add the external include path in t=
he
>> > project properties (assuming the /usr/include is in your default =
>> include
>> > path)
>> > good luck
>> > martin
>> > Efthym wrote:
>> >> Hi Doug,
>> >> I tried the Managed Make project but couldn't get anywhere with th=
at.
>> >> Project->Properties->Include Paths->Add external include. There I =
put
>> >> Project View .
>> >> In the makefile I have "SDL_CFLAGS :=3D $(shell sdl-config --cflag=
s)" =
>> and
>> >> "SDL_LDFLAGS :=3D $(shell sdl-config --libs)"
>> >> There is only one main.cpp file in my project which "include =
>> <SDL.h>".
>> >> directory". All the rest of the errors I think are caused because =
of
>> >> this).
>> >> I hope this helps.
>> >> Thanx
>> >> Efthym
Re: CDT and SDL howto ?? [message #128117 is a reply to message #127576] |
Sun, 21 November 2004 17:15   |
Efthym,
That's a linker error. If we are talking about a managed build project,
have you set the library paths (or specified the libraries to link
against) for the linker tool? It's worth taking a look.
Sean
> (is this right ??)
> As for the includes, they dont seem to work even if managed build is used.
> I'm using an external library SDLGUI. So I have
> and the compiler stops complaining about the missing file. but then I get
> though it doesn't find it. This goes for all methods in SDLGUI that
> are referenced in arraysR.cpp.
> Efthymios
>>> same
>> results)
>>> using
>> Cheers,
>> Doug
>>> martin
>>> Martin Wood wrote:
>>> > Try using
>>> include
>>> > path)
>>> > good luck
>>> > martin
>>> > Efthym wrote:
>>> >> Hi Doug,
>>> >> Project View .
>>> --cflags)" and
>>> <SDL.h>".
>>> >> this).
>>> >> I hope this helps.
>>> >> Thanx
>>> >> Efthym
Re: CDT and SDL howto ?? [message #128130 is a reply to message #128117] |
Sun, 21 November 2004 21:20   |
Hi Sean,
can you be more specific please. I'm kinda new at this. This is a manage=
d =
project.
I tried adding libSDL.a libSDLmain.a with the '-l' option. Is this corre=
ct =
? This is what I get
Building target: ArraysRevisited
g++ -L/usr/lib -lSDL -lpthread -o ArraysRevisited arraysR.o =
-l/usr/lib/libSDL.a -l/usr/lib/libSDLmain.a
/usr/bin/ld: cannot find -l/usr/lib/libSDL.a
collect2: ld returned 1 exit status
I checked and the file is there. Still stuck ....
Efthym
On Sun, 21 Nov 2004 17:15:04 -0500, Sean Evoy <sevoy@ca.ibm.com> wrote:
> Efthym,
> That's a linker error. If we are talking about a managed build project=
> have you set the library paths (or specified the libraries to link =
> Sean
>> '$(shell sdl-config --cflags)' in the Build->Compiler->Miscellaneous =
and
>> (is this right ??)
>> As for the includes, they dont seem to work even if managed build is=
>> used.
>> If set the relative path in the include statement, the file is found.=
>> and the compiler stops complaining about the missing file. but then I=
>> get
>> The GetItem() method is public in the SDLGUI.h . For some reason =
>> though it doesn't find it. This goes for all methods in SDLGUI that =
>> Efthymios
>> On Wed, 17 Nov 2004 13:44:55 -0500, Doug Schaefer =
>>>> thinking about it, this seems to imply that the option of adding an=
>>>> an unmanaged build. (I tried using the same setup as you and got th=
e =
>>>> same
>>> results)
>>> properties of standard make are used by CDT's internal parser for al=
l =
>>> our
>>>> I havent tried this using a managed build, which I think would work=
>>>> using
>>> I have successfully used managed make with SDL. Simply put the outpu=
t =
>>> of
>>> sdl-config in the right spots in the managed make properties. This =
>>> stuff
>>> Cheers,
>>> Doug
>>>> martin
>>>> Martin Wood wrote:
>>>> > Try using
>>>> > which means you shouldnt need to add the external include path in=
>>>> the
>>>> include
>>>> > path)
>>>> > good luck
>>>> > martin
>>>> > Efthym wrote:
>>>> >> Hi Doug,
>>>> >> I tried the Managed Make project but couldn't get anywhere with =
>>>> that.
>>>> >> Project->Properties->Include Paths->Add external include. There =
I =
>>>> put
>>>> >> Project View .
>>>> >> In the makefile I have "SDL_CFLAGS :=3D $(shell sdl-config =
>>>> --cflags)" and
>>>> <SDL.h>".
>>>> >> directory". All the rest of the errors I think are caused becaus=
e =
>>>> of
>>>> >> this).
>>>> >> I hope this helps.
>>>> >> Thanx
>>>> >> Efthym
Re: CDT and SDL howto ?? [message #128408 is a reply to message #128130] |
Tue, 23 November 2004 13:47   |
Hi Efthym,
When you pass a library to the linker, you typically break the
specification in two.
The first part is to specify the path to the libraries using the -L
flag, as you have done in the example output with "-L/usr/lib". This
tell the linker to add "/usr/lib" to its internal list of search
directories.
The second part is to specify the libraries themselves. Here, you use
the flag -l<name> and the linker adds the prefix "lib" and the extension
".a". In the output below, "-lSDL" will be expanded by the linker to
libSDL.a so you should not specify the full name. What is the argument
"-l/usr/lib/libSDLmain.a" for? If you have to link that library too, you
should add "SDLmain" to the list of libraries in the linker tool settings.
Anyway, let me know if this suggestion helped.
Sean
Efthym wrote:
> Hi Sean,
> managed project.
> correct ? This is what I get
> Efthym
>> Efthym,
>> project, have you set the library paths (or specified the libraries
>> to link against) for the linker tool? It's worth taking a look.
>> Sean
>>> (is this right ??)
>>> is used.
>>> found. I'm using an external library SDLGUI. So I have
>>> I get
>>> Efthymios
>>>>> the same
>>>> results)
>>>> all our
>>>>> work using
>>>> output of
>>>> stuff
>>>> Cheers,
>>>> Doug
>>>>> martin
>>>>> Martin Wood wrote:
>>>>> > Try using
>>>>> in the
>>>>> default include
>>>>> > path)
>>>>> > good luck
>>>>> > martin
>>>>> > Efthym wrote:
>>>>> >> Hi Doug,
>>>>> that.
>>>>> I put
>>>>> >> Project View .
>>>>> --cflags)" and
>>>>> <SDL.h>".
>>>>> because of
>>>>> >> this).
>>>>> >> I hope this helps.
>>>>> >> Thanx
>>>>> >> Efthym
Re: CDT and SDL howto ?? [message #128448 is a reply to message #128408] |
Tue, 23 November 2004 17:22  |
Thanx for the tip Sean,
I'll try it and let you know
Efthym
On Tue, 23 Nov 2004 13:47:13 -0500, Sean Evoy <sevoy@ca.ibm.com> wrote:
> Hi Efthym,
> When you pass a library to the linker, you typically break the =
> The first part is to specify the path to the libraries using the -L =
> flag, as you have done in the example output with "-L/usr/lib". This =
> tell the linker to add "/usr/lib" to its internal list of search =
> directories.
> The second part is to specify the libraries themselves. Here, you use =
> the flag -l<name> and the linker adds the prefix "lib" and the extensi=
on =
> ".a". In the output below, "-lSDL" will be expanded by the linker to =
> libSDL.a so you should not specify the full name. What is the argument=
> "-l/usr/lib/libSDLmain.a" for? If you have to link that library too, y=
ou =
> should add "SDLmain" to the list of libraries in the linker tool =
> settings.
> Sean
> Efthym wrote:
>> Hi Sean,
>> can you be more specific please. I'm kinda new at this. This is a =
>> managed project.
>> I tried adding libSDL.a libSDLmain.a with the '-l' option. Is this =
>> Efthym
>> On Sun, 21 Nov 2004 17:15:04 -0500, Sean Evoy <sevoy@ca.ibm.com> =
>> wrote:
>>> Efthym,
>>> That's a linker error. If we are talking about a managed build =
>>> project, have you set the library paths (or specified the libraries=
>>> Sean
>>>> '$(shell sdl-config --cflags)' in the Build->Compiler->Miscellaneou=
s =
>>>> and
>>>> (is this right ??)
>>>> As for the includes, they dont seem to work even if managed build =
>>>> is used.
>>>> If set the relative path in the include statement, the file is =
>>>> and the compiler stops complaining about the missing file. but then=
>>>> I get
>>>> though it doesn't find it. This goes for all methods in SDLGUI tha=
t =
>>>> Efthymios
>>>>>> thinking about it, this seems to imply that the option of adding =
an
>>>>>> an unmanaged build. (I tried using the same setup as you and got =
>>>>>> the same
>>>>> results)
>>>>> You are correct, as far as the build goes. The Include Paths in th=
e
>>>>> properties of standard make are used by CDT's internal parser for =
>>>>> all our
>>>>>> I havent tried this using a managed build, which I think would =
>>>>>> work using
>>>>> I have successfully used managed make with SDL. Simply put the =
>>>>> output of
>>>>> sdl-config in the right spots in the managed make properties. This=
>>>>> stuff
>>>>> Cheers,
>>>>> Doug
>>>>>> martin
>>>>>> Martin Wood wrote:
>>>>>> > Try using
>>>>>> > which means you shouldnt need to add the external include path =
>>>>>> in the
>>>>>> > project properties (assuming the /usr/include is in your =
>>>>>> default include
>>>>>> > path)
>>>>>> > good luck
>>>>>> > martin
>>>>>> > Efthym wrote:
>>>>>> >> Hi Doug,
>>>>>> >> I tried the Managed Make project but couldn't get anywhere wit=
h =
>>>>>> that.
>>>>>> >> Project->Properties->Include Paths->Add external include. Ther=
e =
>>>>>> I put
>>>>>> >> "/usr/include/SDL". After that, the path is shown in the C/C++=
>>>>>> >> Project View .
>>>>>> --cflags)" and
>>>>>> <SDL.h>".
>>>>>> >> When I try to compile, I keep getting a "SDL.h: No such file o=
r
>>>>>> >> directory". All the rest of the errors I think are caused =
>>>>>> because of
>>>>>> >> this).
>>>>>> >> I hope this helps.
>>>>>> >> Thanx
>>>>>> >> Efthym
Current Time: Fri Jul 18 00:38:52 EDT 2025
Powered by FUDForum. Page generated in 0.09999 seconds
