Eclipse won't start any more [message #127000] |
Fri, 12 December 2003 15:36  |
Originally posted by: mhofmann.uvic.ca
My machine crashed while I was working on a project and now when I try and
restart it I get the Error box and the program aborts.
Here are the entries from the .log file.
!SESSION Dec 12, 2003 12:21:41.888
java.version=1.4.1_01
java.vendor=Apple Computer, Inc.
BootLoader constants: OS=macosx, ARCH=ppc, WS=carbon, NL=en_US
Command-line arguments: -os macosx -ws carbon -arch ppc -psn_0_2883585
-consoleLog -showlocation -data workspace -install file:/usr/local/eclipse/
!ENTRY org.eclipse.core.runtime 4 2 Dec 12, 2003 12:21:41.894
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.core.runtime".
!STACK 0
java.lang.IllegalArgumentException: Element not found:
/SysRequest/build/WEB-INF/classes/sysRequest.
org.eclipse.core.internal.watson.ElementTree.elementNotFound (ElementTree.java:358)
org.eclipse.core.internal.watson.ElementTree.createElement(E lementTree.java:272)
org.eclipse.core.internal.resources.Workspace.createResource (Workspace.java:667)
org.eclipse.core.internal.resources.Workspace.createResource (Workspace.java:638)
org.eclipse.core.internal.resources.Workspace.createResource (Workspace.java:700)
org.eclipse.core.internal.localstore.RefreshLocalVisitor.cre ateResource(RefreshLocalVisitor.java:75)
org.eclipse.core.internal.localstore.RefreshLocalAliasVisito r.createResource(RefreshLocalAliasVisitor.java:27)
org.eclipse.core.internal.localstore.RefreshLocalVisitor.syn chronizeExistence(RefreshLocalVisitor.java:189)
org.eclipse.core.internal.localstore.RefreshLocalVisitor.vis it(RefreshLocalVisitor.java:263)
org.eclipse.core.internal.localstore.UnifiedTree.accept(Unif iedTree.java:71)
org.eclipse.core.internal.localstore.FileSystemResourceManag er.refreshResource(FileSystemResourceManager.java:549)
org.eclipse.core.internal.localstore.FileSystemResourceManag er.refresh(FileSystemResourceManager.java:535)
org.eclipse.core.internal.localstore.FileSystemResourceManag er.refreshRoot(FileSystemResourceManager.java:579)
org.eclipse.core.internal.localstore.FileSystemResourceManag er.refresh(FileSystemResourceManager.java:528)
org.eclipse.core.internal.resources.Resource.refreshLocal(Re source.java:1160)
org.eclipse.core.internal.resources.Workspace.open(Workspace .java:1494)
org.eclipse.core.resources.ResourcesPlugin.startup(Resources Plugin.java:292)
org.eclipse.core.internal.plugins.PluginDescriptor$1.run(Plu ginDescriptor.java:758)
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:1127)
org.eclipse.core.internal.plugins.PluginDescriptor.internalD oPluginActivation(PluginDescriptor.java:770)
org.eclipse.core.internal.plugins.PluginDescriptor.doPluginA ctivation(PluginDescriptor.java:200)
org.eclipse.core.internal.plugins.PluginClassLoader.activate Plugin(PluginClassLoader.java:109)
org.eclipse.core.internal.plugins.PluginClassLoader.internal FindClassParentsSelf(PluginClassLoader.java:181)
org.eclipse.core.internal.boot.DelegatingURLClassLoader.find ClassParentsSelf(DelegatingURLClassLoader.java:490)
org.eclipse.core.internal.boot.DelegatingURLClassLoader.load Class(DelegatingURLClassLoader.java:882)
org.eclipse.core.internal.boot.DelegatingURLClassLoader.acce ss$0(DelegatingURLClassLoader.java:876)
org.eclipse.core.internal.boot.DelegatingURLClassLoader$Dele gateLoader.loadClass(DelegatingURLClassLoader.java:90)
org.eclipse.core.internal.boot.DelegatingURLClassLoader.find ClassPrerequisites(DelegatingURLClassLoader.java:554)
org.eclipse.core.internal.boot.DelegatingURLClassLoader.load Class(DelegatingURLClassLoader.java:890)
org.eclipse.core.internal.boot.DelegatingURLClassLoader.load Class(DelegatingURLClassLoader.java:862)
at java.lang.ClassLoader.loadClass(ClassLoader.java:255)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:315 )
org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:47)
org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.java:858)
at org.eclipse.core.boot.BootLoader.run(BootLoader.java:461)
at org.eclipse.core.launcher.Main.basicRun(Main.java:299)
at org.eclipse.core.launcher.Main.run(Main.java:767)
at org.eclipse.core.launcher.Main.main(Main.java:601)
!SESSION
!ENTRY org.eclipse.core.launcher 4 0 Dec 12, 2003 12:21:42.211
!MESSAGE Exception launching the Eclipse Platform:
!STACK
java.lang.reflect.InvocationTargetException
org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.java:861)
Caused by:
org.eclipse.core.internal.boot.DelegatingURLClassLoader$Dele gatingLoaderException:
"Plug-in "org.eclipse.core.resources" activation failed while loading
class "org.eclipse.core.resources.IResourceChangeListener".
org.eclipse.core.internal.plugins.PluginClassLoader.activate Plugin(PluginClassLoader.java:113)
... 8 more
Re: Eclipse won't start any more [message #127598 is a reply to message #127164] |
Mon, 15 December 2003 12:19  |
Andreas Schmidt wrote:
> Am Fri, 12 Dec 2003 20:36:47 +0000 (UTC) hat Martin Hofmann
> <mhofmann@uvic.ca> geschrieben:
> > and
> Have you tried to delete/rename your workspace? Or use -data to start with
> another workspace directory. If eclipse then starts, you have to import
> your old projects into the new workspace.
OK Thanks. That worked and was fairly painless, fortunately I had not made
too many changes to the default configuration.
Martin
FUDForum. Page generated in 0.06575 seconds
