Home » Eclipse Projects » Commercial » Open-jACOB - The M$ Access replacement for the Web
Open-jACOB - The M$ Access replacement for the Web [message #11624] Mon, 27 November 2006 08:06
Tarragon Software is pleased to release the jACOB Framework under GPL. The primary goal of
the jACOB Framework is to handle web applications with CRUD (create, retrieve, update,
delete) with little or no Java programming. There is no need to tell the application how
to retrieve or display the data. Instead, the developer creates the Web-UI with a point
and click Eclipse UI-Designer.
greetings
Andreas Herz
See: http://www.openjacob.org
Previous Topic:Open-jACOB - The M$ Access replacement for the Web
Next Topic:BEA releases BEA Workshop Studio 3.3
Current Time: Sun Jul 13 13:32:01 EDT 2025
Powered by FUDForum. Page generated in 0.03846 seconds
