Home » Newcomers » Newcomers » Line Numbering Not working?
Line Numbering Not working? [message #126994] Fri, 30 December 2005 17:45 Go to next message
Originally posted by: russray1761.charter.net
I am using Eclipse 3.2. I am trying to setup my environment. Under the
Window>Perferences>General>Editors>Text Editors I select the option Show
line numbers and click apply. The results is nothing happens and there is
no error in the log file. When I click on the print margin. It works
fine.
Any hints from the community?
Thanks in advance.
Russ
Re: Line Numbering Not working? [message #127021 is a reply to message #126994] Fri, 30 December 2005 22:11 Go to previous messageGo to next message
Try to close the editor and open it again.
Cliff Liang
"Russ Ray" <russray1761@charter.net>
??????:aa91e907bef8f5fe4916e9e2cbf050cf$1@www.eclipse.org...
>fine.
> Thanks in advance.
> Russ
Re: Line Numbering Not working? [message #127542 is a reply to message #126994] Wed, 04 January 2006 06:23 Go to previous message
> Show line numbers and click apply. The results is nothing happens and
> there is no error in the log file. When I click on the print margin.
> It works fine.
This should work (and does for Java and text editors, just tested it) -
what kind of editor are you using?
-tom
Previous Topic:Eclipse SDK 3.1.1 - Missing icons and button text in IDE
Next Topic:Start-up problem with CDT/gdb
Current Time: Sun Jul 27 06:30:58 EDT 2025
Powered by FUDForum. Page generated in 0.08551 seconds
