Home » Language IDEs » Java Development Tools (JDT) » Upgrade from Eclipse 2.0 to 2.1 loses JUnit
Upgrade from Eclipse 2.0 to 2.1 loses JUnit [message #11603] Thu, 01 May 2003 23:08 Go to next message
Originally posted by: robert.welbourn.com
I upgraded from Eclipse 2.0 to 2.1, but in the process I seem to have
broken anything that used JUnit. For example, the import declaration
import junit.framework.TestCase;
results in the error message "the import junit cannot be resolved"
Most likely this is some form of classpath problem. Can anyone point me
in the right direction to fix this?
Rob
Re: Upgrade from Eclipse 2.0 to 2.1 loses JUnit [message #11673 is a reply to message #11603] Fri, 02 May 2003 00:28 Go to previous messageGo to next message
make sure you have the right junit jar in your project's classpath. With
version 2.1, you want the one in $eclipse/plugins/org.junit_3.8.1 where
$eclipse represents the eclipse installation directory. The version of
junit changed from 3.7 to 3.8.1, so your eclipse 2.0 projects are probably
looking for $eclipse/plugins/org.junit_3.7
Leon Webster
"Rob Welbourn" <robert@welbourn.com> wrote in message
news:b8snfl$hr$1@rogue.oti.com...
> Rob
Re: Upgrade from Eclipse 2.0 to 2.1 loses JUnit [message #12332 is a reply to message #11673] Fri, 02 May 2003 10:50 Go to previous message
Leon,
Thanks - that did the trick.
Rob
Previous Topic:How to disable project building after import
Next Topic:How JavaEditor example can extend CompilationUnitEditor
Current Time: Wed Jul 30 21:30:55 EDT 2025
Powered by FUDForum. Page generated in 0.04236 seconds
