Home » Newcomers » Newcomers » eclipse on linux!
eclipse on linux! [message #126676] Thu, 29 December 2005 16:27
Originally posted by: nospam.please.com
------=_NextPart_000_0018_01C60C94.C1AEA860
Content-Type: text/plain;
charset="iso-8859-1"
Whenever I run eclipse on a linux box (uname -a output -> Linux =
cluster.xxx.yyy 2.6.9-22.0.1.ELsmp #1 SMP Thu Oct 27 13:14:25 CDT 2005 =
i686 i686 i386 GNU/Linux)
I get the following message:
** (Eclipse:13440): WARNING **: Cannot open font file for font Bitstream =
Vera Sans 10
# An unexpected error has been detected by HotSpot Virtual Machine:
# SIGSEGV (0xb) at pc=3D0x007f0949, pid=3D13440, tid=3D3086956224
# Java VM: Java HotSpot(TM) Client VM (1.5.0_06-b05 mixed mode, sharing)
# Problematic frame:
# C [libc.so.6+0x127949]
# An error report file with more information is saved as =
hs_err_pid13440.log
# If you would like to submit a bug report, please visit:
# http://java.sun.com/webapps/bugreport/crash.jsp
** (eclipse:13439): WARNING **: Cannot open font file for font Bitstream =
Vera Sans 10
Segmentation fault
I forward X display to a PC running Cygwin/X but I know there is no =
problem on that end, because I can run eclipse on another linux box and =
display on this machine fine.
Missing font on the machine running eclipse should not be a problem =
anyhow, since the target machine needs the fonts to display.
Any ideas?
Content-Type: text/html;
<HTML><HEAD>
charset=3Diso-8859-1">
<META content=3D"MSHTML 6.00.2900.2802" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY bgColor=3D#ffffff>
<DIV><FONT face=3DArial size=3D2>Whenever I run eclipse on a linux box =
(uname -a=20
output -&gt; Linux cluster.xxx.yyy 2.6.9-22.0.1.ELsmp #1 SMP Thu Oct 27 =
13:14:25=20
CDT 2005 i686 i686 i386 GNU/Linux)</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT>&nbsp;</DIV>
<DIV><FONT face=3DArial size=3D2>I get the following =
message:</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>** (Eclipse:13440): WARNING **: Cannot =
open font=20
file for font Bitstream Vera Sans 10<BR>#<BR># An unexpected error has =
been=20
detected by HotSpot Virtual Machine:<BR>#<BR>#&nbsp; SIGSEGV (0xb) at=20
pc=3D0x007f0949, pid=3D13440, tid=3D3086956224<BR>#<BR># Java VM: Java =
HotSpot(TM)=20
Client VM (1.5.0_06-b05 mixed mode, sharing)<BR># Problematic =
frame:<BR>#=20
C&nbsp; [libc.so.6+0x127949]<BR>#<BR># An error report file with more=20
information is saved as hs_err_pid13440.log<BR>#<BR># If you would like =
to=20
submit a bug report, please visit:<BR>#&nbsp;&nbsp; <A=20
href=3D"http://java.sun.com/webapps/bugreport/crash.jsp">http://java.sun.=
com/webapps/bugreport/crash.jsp</A><BR>#</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>** (eclipse:13439): WARNING **: Cannot =
open font=20
file for font Bitstream Vera Sans 10<BR>Segmentation =
fault<BR></FONT></DIV>
<DIV><FONT face=3DArial size=3D2>I forward X display to a PC running =
Cygwin/X but I=20
know there is no problem on that end, because I can run eclipse on =
another linux=20
box and display on this machine fine.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Missing font on the machine running =
eclipse should=20
not be a problem anyhow, since the target machine needs the fonts to=20
display.</FONT></DIV>
<DIV>&nbsp;</DIV>
<DIV><FONT face=3DArial size=3D2>Any ideas?</DIV></FONT>
<DIV><FONT face=3DArial size=3D2></FONT>&nbsp;</DIV></BODY></HTML>
------=_NextPart_000_0018_01C60C94.C1AEA860--
Previous Topic:'workspace in use - choose a different one'
Next Topic:Workspace folder reassign fails
Current Time: Wed Jul 16 02:16:49 EDT 2025
Powered by FUDForum. Page generated in 0.07175 seconds
