Home » Archived » BIRT » Report Item Extension
Report Item Extension [message #126654] Wed, 08 February 2006 22:33 Go to next message
Does anyone know if the report item extension mechanism the same for BIRT
2.0 as for BIRT 1.0. I see that the BIRT 1.0 documentation does a good job
of explaining the mechanism for extending a report item. I want to confirm
that it is not substantially changed for BIRT 2.0.
Re: Report Item Extension [message #126767 is a reply to message #126654] Thu, 09 February 2006 02:28 Go to previous messageGo to next message
Where did you find the 1.0 documentation from?
"Terry Partridge" <terrypartridge@fairisaac.com> wrote in message
news:e5cb3d7e844263a289b3074eecdae60d$1@www.eclipse.org...
Re: Report Item Extension [message #128694 is a reply to message #126767] Sat, 11 February 2006 13:05 Go to previous messageGo to next message
I found it at http://help.eclipse.org/help31/index.jsp. I assumed because
the copyright on this document was 2005 that it was for BIRT 1.0, also
this help is a bit different from the BIRT 2.0 help, which has a 2006
copyright.
Look under the "Extending BIRT"->"Overview of the extension
framework"->"Understanding a report item extension" section.
This section is not contained in the BIRT 2.0 documentation.
Re: Report Item Extension [message #129152 is a reply to message #128694] Mon, 13 February 2006 10:11 Go to previous message
That field guide is essentially the one that Actuate is working on to
publish as a book. I am working on the sample item in there, and adding
some significant capabilities to it right now. So much of the mentions of
the sample will change, as well as a little bit of wordier english put in
about the various extension points.
From what I can tell, that is the BIRT 2.0 framework to plug it in. My only
issue is that it's really light on the areas of fetching actual data
elements from the data set, and adding scripting support to your extensions.
"TerryPartridge" <terrypartridge@fairisaac.com> wrote in message
news:8689df16269f4dd830e82329dc0984b8$1@www.eclipse.org...
>the copyright on this document was 2005 that it was for BIRT 1.0, also this
>help is a bit different from the BIRT 2.0 help, which has a 2006 copyright.
Previous Topic:Could you give me an Report Engine API example?
Next Topic:drill-through - passing a detail from one report as an input parameter for another report
Current Time: Mon Jul 21 22:03:39 EDT 2025
Powered by FUDForum. Page generated in 0.05536 seconds
