Home » Newcomers » Newcomers » Overriding $user in Java templates
Overriding $user in Java templates [message #11568] Fri, 21 January 2005 23:49 Go to next message
Originally posted by: dmerrillq.usaq.netq
Eclipse's default java class template includes the template variable $user,
which it's resolving to my machine name, presumably since that's the name I
use to log into my laptop. Maybe it's not cool that I do that, but I'm the
only user of this machine, I've done it for a long time, and by now there's
*tons* of stuff attached to that "name", so I don't want to change that.
Given that, what's the most sensible thing to do so this gets
mapped onto some other string I can control. I could
change all templates to include that as literal text, but it seems like it'd
be better to be able to change it in one place and effect all templates.
I see in the help that "You can insert your own template variables, which
then evaluate to the name of the variable itself." If I'm reading that
right, it means I could define $DaveMerrill, and it would resolve to
'DaveMerrill'. Seems lame, since a) I'd rather a space between first and
last name, and b) the whole point is to change the *value* of that variable,
which isn't possible. I must not understand how this works. Does it mean
that I could use $author (say), and somewhere else, global to Eclipse and
permanent until I change it, set the string it resolves to? If that, how
would I set this up and manage it?
Clue, anyone? Other ideas?
Thanks, as always,
Dave Merrill
Re: Overriding $user in Java templates [message #13318 is a reply to message #11568] Mon, 24 January 2005 04:23 Go to previous messageGo to next message
The ${author} property is taken from the java property obtained by calling
System.getProperty("user.name");
So, you can either start eclipse with -vmargs -Duser.name="Dave Merril"
or modify the template directly to include your name verbatim.
HTH, tom
> Thanks, as always,
> Dave Merrill
Re: Overriding $user in Java templates [message #13343 is a reply to message #11568] Mon, 24 January 2005 04:29 Go to previous messageGo to next message
Simply start Eclipse with VM argument -Duser.name="your name"
Dani
>Thanks, as always,
>Dave Merrill
Re: Overriding $user in Java templates [message #14767 is a reply to message #13318] Mon, 24 January 2005 12:33 Go to previous message
Thanks Tom, just modified my Eclipse shortcut to do that, good to go.
Dave
"Tom Eicher" wrote in message news:ct2eqb$79i$1@www.eclipse.org...
> HTH, tom
$user,
name I
the
there's
it'd
which
variable,
and
> > Thanks, as always,
> > Dave Merrill
Previous Topic:perspective
Next Topic:First Samle Plugin
Current Time: Sun Aug 31 10:45:24 EDT 2025
Powered by FUDForum. Page generated in 0.29941 seconds
